Old 04-13-2018, 08:17 PM   #1
940 16 valve
940 16 valve's Avatar
Default 760 5 cylinder...scratching a 10 year itch
Some history is in my old thread... http://forums.turbobricks.com/showthread.php?t=243308
I've had a lot of fun, and learned a lot turbocharging my beloved 940. 3 years ago I moved back home after finishing school, started a practice, bought a house. Now I have a space to work on my projects!
This is probably the best pic I have of the space. After me and a buddy picked up a tire machine.
I purchased a 89' 760 with the intention of taking the doors which were in better shape for my 940. Then I started dreaming about swapping the IRS, but I also really like the updated dash of the 760, the long hood. The more I thought about it the 760 was in better shape too.
As much as I love my 940, with the turbo and the T5 transmission it's a blast to drive, but it's just not refined. About 10 years ago I convinced my brother to buy a 98' S70T5SE, and I just fell in love with the whiteblock. For a long time I would lurk on threads with RWD swaps. I followed closely threads like Narancs, and yellow t5R, thefullbanana, Canuck, and Lloyddobler in their respective builds..
http://forums.turbobricks.com/showthread.php?t=277359
http://forums.turbobricks.com/showthread.php?t=192209
http://forums.turbobricks.com/showthread.php?t=284730
http://www.calgaryvolvoclub.com/foru...2227&start=585
http://forums.turbobricks.com/showthread.php?t=304073
As well as finding myself reading ever more swedish content through google translate...
I started getting serious about it last winter, and I picked up what I thought was a low mile 2006 B5254T from a crashed XC70. The oil change sticker read about 140xxxkm, but I realized after pulling it and looking back that the car had been imported from the usa. So not the low mileage I was going for, but probably fine for me to get started. The motor sat for the better part of year while I got distracted by other things.
Starting a few months ago I got more serious about collecting parts.
Rather than shorten a pan (which Canuck very graciously offered to help me shorten) I ended up buying Lloyddobler's second one. Lucky for me he had welded up 2 of them! So the original sits on bottom, with the welded one on top for comparison.
Got the engine on a stand.
Flipped it, pulled the pan, and test fitted the oil pickup and engine mounts. At this point it had been nearly a year since a 960 had showed up at the yard, and 2manyturbos came through and hooked me up with some mounts so I could get to fitting.
(My grandpa's antique tool collection the he gifted me in the background)
Pickup too long!
Used metal plated to allow for all 4 bolts to fit
Mildly clogged pcv
Cleaning pan of metal shavings from when it was resurfaced. Doesn't seem to leak!
Not all holes were present on this block. I was missing one for bolting in the middle of the pan, and one that holds a support for the oil pickup tube. Had to drill them, and then tap to M7x1 (apparently a very hard tap size to find indeed!) Had to get it off ebay.
Also had to track down a few oil pan bolts that the 960 pan used, which were not present on the s60 pan which I had bolts from. There is a single bolt that is M7 by I think it was 80mm, where the 4 at the back are 100mm and just won't quite work.
Keeping shaving out of the engine
Ready to be tapped
Tack welded oil pickup
Nearly there
And soldering some resistors per Aaron's helpful instructions from vast
http://vasttuning.com/product/cop-bi...-instructions/
1991 940 - stock b234+t Saab APC at ~14lbs boost http://forums.turbobricks.com/showthread.php?t=243308
t5 swap, wilwoods, Lowered w/ Koni adjustables.
Old 04-13-2018, 08:42 PM   #2
poulrais
poulrais's Avatar
Whiteblock swaps is the flavor of the year I think!
Are you planning on keeping this engine pretty much stock?
Have fun!
1990, Volvo 740 16v +T
Old 04-13-2018, 09:25 PM   #3
940 16 valve
Definitely! I've been watching your and Roger's threads regarding the CD009 transmission adapter, very tempting!
The plan is start out stock and work the bugs out, who knows from there, it's an addiction right?
Old 04-14-2018, 02:59 AM   #4
Pete.M
Slow Member
Pete.M's Avatar
Yes! I've had the itch for over 5 years.
Are you going to wire in the stock ecu and engine loom?
Pete.M is offline   Reply With Quote
Old 04-14-2018, 07:47 AM   #5
DET17
Reformed SAABaholic
I'll also be watching this with interest.... got a B5244T5 on the engine dolly waiting for my 242.
What gearbox behind yours? Staying auto for now?
DET17 is online now   Reply With Quote
Old 04-14-2018, 08:26 AM   #6
poulrais
poulrais's Avatar
The only auto tranny he could "easily" use is the AW30. I don't know why would anyone use that piece of crap on a swap.
Old 04-14-2018, 09:47 AM   #7
Broke4speed
Broke4speed's Avatar
Ow...that hurts, lol :P.
1984 244/ B6304S+T / AW30-40 w/Poi-Shift.
Old 04-15-2018, 08:19 AM   #8
poulrais
poulrais's Avatar
Oh! Sorry about that!
We'll see how long it'll last!
Old 04-15-2018, 10:52 AM   #9
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I'm very curious to watch this. I keep having a real debate about running modded m4.4 or going standalone. The 4.4 is so appealing in regards that so much of the tuning has been paid for by Volvo and not me. I can just focus on tweaking vs starting from the ground up.
The flip side ofcourse being you don't have as much extra potential but for what I want, I'm not sure that's really needed.
Old 04-15-2018, 11:19 AM   #10
240wagonguy
Nice another one. I'll be watching. I got a I6 that'll be going into my 740 soon.
Old 04-15-2018, 08:36 PM   #11
Broke4speed
My goals are far lower than yours, so hopefully it lasts a long time .
Old 04-21-2018, 11:52 PM   #12
940 16 valve
Went to the junkyard last weekend and this weekend to get some parts that were needed to progress this any further. First 960 I've seen in about a year, and thankfully only had 80,000 miles.
I had the same debate between 4.4 and standalone Doug... I decided this seems like the way to go, at the very least to get started, but really people are putting down some impressive numbers with the motronic.
4.4 harness, in process of cutting out un-needed wiring.
I convinced myself that grabbing a few extra pieces off the low mileage car while in there made sense.
as well as a few things I actually needed, like starter/alternator/power steering. I toyed with the idea of using the updated accessories, but seeing these are lower mileage, and it was half off day, I went for it. Also grabbed a bellhousing in case I decide to do the CD009 swap that roger is working on.
Also got this off ebay, since the newer style keys seem to be a problem.
Also got the tabs at the top of this image, which hold the engine mounts in.
And then with those in got the engine prepped for install. Last look at the mounts with plates to adapt them.
4.4 cam sensor in
aaaand, engine going in
Old 04-22-2018, 08:31 AM   #13
poulrais
poulrais's Avatar
This is coming along fine! What are you doing with the twin VVT?
Old 04-29-2018, 02:33 PM   #14
940 16 valve
Not sure about the twin VVT at this point, thinking I'll chat with Vast tuning about it when I get there. Probably just leave it alone to start.
got the accessories installed
And now just toiling over the transmission options... Cd009, or a GS6-37 shipped from sweden, and welded to the volvo bellhousing. Similar gear ratios, advantage that the gs6 can use a volvo driveshaft. Seems like the Cd009 is quite a refinied tranny in it's final version with triple synchros on the first 3 gears...
One of the next things is decoding the wiring. Anyone have suggestions as to where I can find wiring diagrams for a s70turbo with motronic 4.4, as well as for the 760 with prv engine. My least favourite part....the wiring...
Old 05-04-2018, 06:40 AM   #15
DET17
Reformed SAABaholic
Looks like good progress being made. Just remember the absolute rule of HotRodding, as explained by Freiburger:
"It will cost twice as much, take three times as long as you expect".
Considered the DeeWorks T5 adapter? I think you can buy a brand new T5 with Z spec gearing (2.95 first close ratio) for $1200 USD.
Old 05-04-2018, 09:27 AM   #16
240wagonguy
T5z is at 1995 now. Almost not worth it with the TKO being $2600ish. I myself am hunting down a good used 96-04 V6 T5 from a Mustang. Supposed to have all the factory upgrades in it already.
Old 12-27-2018, 12:03 PM   #17
940 16 valve
I hate it when I follow a thread with interest, and then no update for month and months.
Where does the time go...?
Seem to have less car time since my daughter was born.
But some progress
Exhaust side coming along, welded up the piping to the water pump
Welded the oil feed to fit with the turbo flipped for RWD
Not a ton of room for the exhaust with the 5 cyl manifold...
Most of the wiring is in place for motronic 4.4, just need to figure out the power to the 760 fuel pump relay, and run wiring for the COP. Any suggestions on those folks? Ok to ground them to the head?
relocated the battery to the drivers side, and ran wires for alternator/starter
And found some Ferrari Compomotives that I've been looking for for years. They were advertised as 16", but are definitely 15" unfortunately. They just fit.
I like the look in profile
Testing ride height
Clearance to bump stop
Nasty suspension angles. Have to find the compromise between form and function.
And finally, decided that a CD009 isn't in the budget right now, especially since I already have a driveshaft and shifter setup for a T5 transmission in the 940, which will likely get retired once this runs. This is a spare V6 T5 that I plan to use for mockup. I'm considering if a dual mass flywheel will quiet it down, and I think with my power goals I don't need anything more. The T5 is pretty civilized in the 940 now that I have my driveline angles sorted, but at high revs on decel it still rattles. I hate to go to all the trouble of getting the beautiful sound of a 5 cylinder, and then drown it out with the rattle of a T5 transmission.
Old 06-09-2019, 01:09 AM   #18
940 16 valve
Any motronic 4.4 gurus out there? Was working on wiring the fuel pump relay today and am confused about the purpose of wires B19 and B27.
Sounds to me like B27 should trigger the relay, but then what is B19's purpose. The stock 4.4 fuel pump relay is just a simple 4 prong relay.
Old 06-10-2019, 04:07 PM   #19
oldschoolvolvo
oldschoolvolvo's Avatar
Nice work!
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 06-11-2019, 07:12 AM   #20
DET17
Reformed SAABaholic
Check with Lankuu in Finland..... he has apparently mastered these whiteblocks & engine management of same.
Old 06-17-2019, 12:22 AM   #21
940 16 valve
Some more discussion on it here. http://forums.turbobricks.com/showthread.php?t=349620
My brother gave me some help today and we got the .bin from Vast tuning loaded, turned it over and the coils are giving me spark! Just need to wire the fuel pump and it may be time to try starting it!
Old 09-09-2019, 08:28 PM   #22
940 16 valve
So it roared to life for the first time (very briefly) a little over a month ago. Now it's time to sort out the clutch. Those single mass flywheels are hard to find! Anybody have one they want to donate to the cause?
Old 09-12-2019, 12:12 AM   #23
LloydDobler
LloydDobler's Avatar
You can still buy it new if you want to spend 4x TB price. https://www.tascaparts.com/oem-parts...ItM2wtbDUtZ2Fz
Can verify this is a good working part number, it's the one I bought for my C70 manual swap. Technically the 850R flywheel.
'66 122 - Collectible project
'06 V70 2.5T - Mostly Stock Daily Driver
'03 C70 T5M - Modded summer fun car
'05 V50 T5 AWD - Daughter's first car
LloydDobler is offline   Reply With Quote
Old 09-12-2019, 02:56 PM   #24
240wagonguy
Try local indy volvo shops. On a whim I walked into a local shop in town and as luck would have it, the guy just parted a manual 850 and gave me the flywheel for $25!
Old 09-17-2019, 12:13 AM   #25
940 16 valve
I'm surprised it's not NLA! If I go new, I've been eyeing the steel TTV flywheels. With the British pound down it's cheaper that the new one one.
Thanks for the suggestion. I did try the local Volvo shop to no avail. I guess I'll watch the junkyard for a bit and then make a decision.
