Old 09-29-2018, 05:51 PM   #426
peterwgpa
peterwgpa's Avatar
Link to photo gallery for category from last weekends racing. Just swipe to scroll
http://https://opticalnote.com/p293788502/hb80f11a6
peterwgpa is offline   Reply With Quote
Old 10-09-2018, 04:19 AM   #427
peterwgpa
peterwgpa's Avatar
Couple of pictures credit to Angryman Photography
Old 11-20-2018, 06:49 AM   #428
peterwgpa
peterwgpa's Avatar
After 39 years we took the car back to Bathurst to run last weekend
It was a big thrill for us to actually get it back to the track that wrote her a little chapter in history.
Car ran faultlessly all weekend and we had a couple of runs cut short with red flags but we got two good runs in on Sunday afternoon with some clear space from other cars to build on Saturdays runs.
All I can say is that Spencer Martin running 2.58sec laps in 1979 on Uniroyals was amazing. The track is 400 metres longer now so a 2.58 most likely equals a 3.02ish lap time and I am 7 seconds away from that at present but happy with progress towards that target..
My fastest lap of day was my last one at 3.09.01 and I progressed each outing. Still much to learn and best way to learn is many more laps so will have to get back there again.
Pictures from the event official photographer
Old 11-20-2018, 03:22 PM   #429
quillc
yv1a.com
quillc's Avatar
I love how it almost lifts the inside tire on a sweeping curve.
Chris
www.yv1a.com
Old 12-22-2018, 06:59 AM   #431
peterwgpa
peterwgpa's Avatar
Found full race footage from race 4 from 2018 Muscle car masters
https://www.youtube.com/watch?v=ClooxTjRnhQ
And some in car footage from one of the faster cars in our group at the Bathurst challange
https://www.youtube.com/watch?v=Ecl5alE7N8o
Another in car from one of the faster Datto's - Gets me at the 2 minute mark of the video. Its 360 degree so you can change camera view of footage
https://www.youtube.com/watch?v=FDUFB9Jh-g8
Old 12-22-2018, 09:00 AM   #432
M.H. Yount
M.H. Yount's Avatar
Volvo Safety Car! Enjoyed that race coverage....complete with a bit of the wet stuff at the end.
Old 12-26-2018, 10:46 AM   #433
peterwgpa
peterwgpa's Avatar
We spent boxing day afternoon playing in the shed.
Pulled gearbox to fit new clutch as the old one was on its last legs with clutch plate almost down to rivots. It was just a standard Sachs Clutch and lasted 4 years which is very good given what we have asked of it
We went a bit fancier this time round
Also serviced the M46 whilst we had it out
Old 12-26-2018, 07:04 PM   #434
quillc
yv1a.com
quillc's Avatar
Nice!
Keep an eye on the firewall. With the stiffer clutch, the firewall where the cable housing connects has a tendency to fatigue. The cable usually stretches and breaks before the cable gets ripped through the firewall though. If you have to adjust your clutch over and over, its a good idea that you order a new one....
Clutch engagement should be much more brutal with the five puck. Was too much for my DD, but should be fine for your race car.
Old 12-27-2018, 01:29 AM   #435
peterwgpa
peterwgpa's Avatar
Thx
All good
We have hydraulic clutch setup
Old 12-27-2018, 08:59 PM   #436
quillc
yv1a.com
quillc's Avatar
Originally Posted by peterwgpa View Post
Thx
All good
Even better.
Old 03-15-2019, 08:03 PM   #437
peterwgpa
peterwgpa's Avatar
We got the car back together yesterday after shouting it a little more work to the head and like the way the clutch feels.
The company that did it does their own modified version and they say it falls between a full on button clutch and the standard clutch for feel and I can vouch for that. Mid point be best description
The aftermarket electric fan we have on is way too small and is struggling to cope when we come in after the races and get stuck in traffic or are delayed returning to pits.
I have sourced an 850 fan and intend to slot it into a 740 T fan shroud part number 1317338 and we will run it on high speed. We already have fan switched manually as we had a thermo switch fail. I like the 740 shroud as it mounts straight to 240 radiator using standard mounts
Now to find that 1317338 shroud - Shroud sorted
Old 03-16-2019, 12:50 AM   #438
LC4CARL
Aero challenged
LC4CARL's Avatar
First class.
Life begins at 10PSI.
Old 03-19-2019, 12:42 PM   #439
quillc
yv1a.com
quillc's Avatar
There have been many people that use the 940 fan with integrated shroud. The shroud is wider, but seems to be pretty simple to cut down and bond back together. There is also a nice relay controller that goes with it.
Old 03-20-2019, 07:38 AM   #440
peterwgpa
peterwgpa's Avatar
Thanks Quiilic for info.
I already have the 740t shroud on the way now as well as the hardware to make it happen. It should come together pretty quick. There is a good online article on ozvolvo http://https://ozvolvo.org/discussion/3316/850-electric-fan-in-240
So even I should be able to get it all mounted.
Will get auto electrician to sort wiring whilst they are tidying up a few other jobs.
Old 03-28-2019, 05:59 AM   #441
peterwgpa
peterwgpa's Avatar
Got new fan shroud and the 850 fan fitted ready to put in car
Looking at photos I will reverse bolts on outside so its neater from top
Old 04-29-2019, 08:35 AM   #442
peterwgpa
peterwgpa's Avatar
I have had a question on window channel in my post.
It appears it may have changed part number.
Contact Better Auto rubber and confirm if old part number BR1012 but pretty sure this is new part number but please do research to confirm.
http://https://betterautorubber.com.au/product/hq-hj-hx-hz-wagon-tailgate-bailey-channel-tgbc1007/
Update - Saw a 242 today that used Holden Commodore VB-VL BAiley channel and a way better fit than the stuff I used
Reference to one example Rare spares Holden Bailey Channel VB VC VH VK VL Commodore Front Door Part# RBC1065
And Betta Auto Rubber Categories: VB-VC-VH-VK-VL, VB-VC-VH-VK-VL Door Parts, VB-VC-VH-VK-VL Rubber Seals SKU: BC1008F
Old 07-27-2019, 04:37 PM   #443
peterwgpa
peterwgpa's Avatar
Returned to track for first race meeting after 8 months and car went well but driver very rusty.
850 fan in 740 turbo shroud works a treat. Head temp nearly 10 degress c cooler and water temp stays well under 100 after the race heading back to pit no matter what delays may occur.
Old 07-29-2019, 05:37 AM   #444
peterwgpa
peterwgpa's Avatar
Couple more pictures credit Trapnell Creations
Old 08-15-2019, 08:36 AM   #445
peterwgpa
peterwgpa's Avatar
Got a write up on page 7 of attached
http://https://www.hrcc.org.au/index_htm_files/19%2008%20August%20Historic%20Torque.pdf
Old 08-19-2019, 10:04 PM   #446
volvo264b27e
volvo264b27e's Avatar
Excellent write up and fantastic rebuild of this 1979 Volvo 242GT ex race car .
volvo264b27e
https://www.youtube.com/channel/UCpN...vJQX9WhAbArBrA
https://www.facebook.com/volvo.ovlov.165
1977 Volvo 264GL B27E
volvo264b27e is offline   Reply With Quote
Old 09-05-2019, 01:08 AM   #447
peterwgpa
peterwgpa's Avatar
We raced at Sydney Masterblast last weekend and car went well and we managed to race hard with a number of cars and managed to lower PB lap time as well.
Was also first ever night race which turned out to be a lot of fun
Picture courtesy of Rob Turrisi
[IMG]
Old 09-09-2019, 08:37 PM   #448
Flying Brick Performance
Hi Peter, love the build thread. Was up to after 2am last night reading through it all.
I’ve been toying with some ideas regarding my own build as I want a build for some very specific events and I think I might have just found the inspiration I need. Won’t be the original like yours, but thankfully the rules allow for reproductions.
Will certainly return back to this thread many times over the next little bit.
1979 Volvo 242GT
1986 BMW 325e Turbo Frankenstein
2003 Ford Pursuit Ute Tow Car
Flying Brick Performance is offline   Reply With Quote
Old 09-09-2019, 09:12 PM   #449
peterwgpa
peterwgpa's Avatar
Glad you found it of use
Good luck with your build.
Old 09-12-2019, 04:35 AM   #450
peterwgpa
peterwgpa's Avatar
My Pictures turned up today courtesy of Rob Turrisi
Thought I would share a few
