Old 03-18-2010, 08:40 PM   #51
Window tipping.
Not as much fun as cow tipping,but you don't have to be drunk to do it.
82 245 GLT Paint 14
Old 03-18-2010, 08:51 PM   #52
And the front.
82 245 GLT Paint 15
Old 03-18-2010, 09:00 PM   #53
Window track seal is removed.
82 245 GLT Paint 16
Old 03-18-2010, 09:46 PM   #54
And replaced with temporary material.
82 245 GLT Paint 18
Old 03-18-2010, 11:48 PM   #55
Door latch surrounds unclip in the front,and lift out.
82 245 GLT Paint 18
Old 03-19-2010, 12:02 AM   #56
Power door lock & window connectors are behind the paper wind seal at the bottom of the 'B' pillar.
82 245 GLT Paint 19
Old 03-25-2010, 10:19 PM   #57
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
More!
Isaac
1995 940 Turbo:
531 head, Holset HE351 @ 20 psi, Emusa External Wastegate w/screamer, Mild Steel Header, 4" Downpipe, Ostrich Emulator, IPD Turbo Cam, TTR Cam Gear, Big Piping and Intercooler, 3" Exhaust, V8 T5 soon, Synapse Synchronic BOV, AEM Wideband, 18" Pegasus, B&G Springs, Billy HD's, Chassis Bracing, Sumimoto HTR ZIII 225/40/18
Sir Psycho is offline   Reply With Quote
Old 03-25-2010, 10:35 PM   #58
If you don't want overspray, dust and paint on it bag it or remove it from the car.
82 245 GLT Paint 20
Old 03-25-2010, 10:54 PM   #59
Got the commandos off today.
The front narrow top bumper filler trim clips had to be picked apart from the inside after the bumper was removed with a needle nose pliers to release the aluminum strips without bending them.
The integral rubber filler trim tabs [teats] of the bumper filler trim need to be wetted,wiggled,and stuffed through the holes so they don't rip off.
On the back there are 2 corner brackets with 10mm nuts inside just below the tail lights,a galvanized strip, 3 clips across the center,and 2 more integral rubber tabs at each end through the body.
82 245 GLT Paint 21
Old 03-26-2010, 10:43 PM   #60
Why looky here, it seems the original owner was an OCD College Professor type,
and got his hands on an IPD catalog.
SS Flex lines,and fancy rotors.
82 245 GLT Paint 22
Not to mention the 28mm bar I bought in the IPD Group Buy.
Old 03-26-2010, 10:53 PM   #61
doucheNozzle
doucheNozzle's Avatar
Are the rears ATE premium ones as well?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 03-26-2010, 10:55 PM   #62
No they are flat rotors.
Old 03-26-2010, 10:57 PM   #63
Don't try this at home,at least not with a knife that is too sharp.
82 245 GLT Paint 22
Old 03-26-2010, 11:21 PM   #64
Got the Corona rollers on.
Got the rocker trim off.
Rockers sanded where smooth and burgundy scuffed lower where they are textured with Dilute detergent and water.
Wet sanded the body again with 600.
Put some POR metal ready on the bare spots to start burning the rust out of the pores,and pits.
82 245 GLT Paint 23
Notice the spots of tape over the trim holes to keep the water out of the dead end cavities in front of the rear wheels.
It's really pretty straight,and other than the professionally replaced passenger side rear quarter panel & rear door there is no evidence of collision damage.
Old 03-26-2010, 11:58 PM   #65
Vol242vo
Keep it clean...
Vol242vo's Avatar
Lookin' Good!
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 03-29-2010, 02:12 AM   #66
Door opening windlace is removed and labeled to speed reassembly.
Some high solids industrial 2 part brushing epoxy for areas that are hard to spray,and won't be seen.
82 245 GLT Paint 25
Old 03-29-2010, 02:21 AM   #67
Manbeard
#helpbrock2k16
Manbeard's Avatar
i suggest you get a custom license plate for it when you're done. since it'll be the work horse, i say WOODWAGN or GOTWOOD.
cars lookin good so far ken!
2012 tdi
Manbeard is offline   Reply With Quote
Old 03-29-2010, 02:26 AM   #68
Thanks.
Some of that uncured epoxy got on the windlace posing for the pix FTL.
I had to wax and grease remover it.
Old 03-29-2010, 02:28 AM   #69
Manbeard
#helpbrock2k16
Manbeard's Avatar
i know you've most likely mentioned it before, but is this getting a full repaint? or just parts?
Old 03-29-2010, 02:36 AM   #70
FattMatt805
juggalo
FattMatt805's Avatar
lookin good ken.
i still want to know what that intercooler is for...
1998 V70 T5M, 245k 218WHP, 238TQ. 15.19@95mph
1996 855T *CRASHED*
1987 suzuki samurai, stock, rolled twice, removed antiroll bars, 30"AT
1977 F250. 460ci
1957 H.D. Sportster. Mothballed
FattMatt805 is offline   Reply With Quote
Old 03-29-2010, 02:37 AM   #71
Complete, doors off, glass out, and jammed.
Old 03-29-2010, 02:39 AM   #72
Detergent and burgundy [extra fine] scotch pad scuff on the radiator support,and yoke.
82 245 GLT Paint 26
Old 03-29-2010, 02:40 AM   #73
Originally Posted by fattmatt805 View Post
lookin good ken.
Old 03-29-2010, 02:43 AM   #74
thebornotaku
( ͡° ͜ʖ ͡°)
thebornotaku's Avatar
i think the whole world wants to know what Ken's got planned for a huge IC.
2009 Volkswagen Rabbit 2.5 "Snowbunny"
thebornotaku is offline   Reply With Quote
Old 03-29-2010, 02:51 AM   #75
MrSam
Grand Luxe Executive
MrSam's Avatar
Its going to look amazing when you are done Ken. I can't wait to see it.
MrSam is offline   Reply With Quote
