Old 04-03-2010, 09:12 PM   #126
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
Might be gooed in flip back the seals,and take a look.
Yeah I think it was (hoping it was goo and not the seal) so I cut some of it away but the window still won't budge. I shouldn't need to push hard right?
Isaac
1995 940 Turbo:
531 head, Holset HE351 @ 20 psi, Emusa External Wastegate w/screamer, Mild Steel Header, 4" Downpipe, Ostrich Emulator, IPD Turbo Cam, TTR Cam Gear, Big Piping and Intercooler, 3" Exhaust, V8 T5 soon, Synapse Synchronic BOV, AEM Wideband, 18" Pegasus, B&G Springs, Billy HD's, Chassis Bracing, Sumimoto HTR ZIII 225/40/18
Sir Psycho is offline   Reply With Quote
Old 04-04-2010, 01:31 PM   #127
You need to push slowly but really hard.
Old 04-04-2010, 01:36 PM   #128
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
Okay I'll try that. I'll cut the goo out from the bottom too because that is probably not helping. But I only need to pull back the seal at the top of the windshield correct?
Old 04-04-2010, 01:38 PM   #129
You need to flip back more of the seal until it will move.
Old 04-10-2010, 01:15 AM   #130
Masking off the dash with 5 mil polyethylene sheeting.
Plastic is tucked in behind the rubber strip that acts as a dam for the windshield sealant,
and in front of the dash then trimmed back with a razor blade.
Regular masking tape is run on the plastic to catch the fold,and give the orange painters tape something to stick to.
Special thanks to BoostIT for the information about the Evapo-rust solution.
It is not an acid but appears to be a fairly benign sulphur compound.
POR Metal Ready [Phosphoric acid with Zinc] is shown in the background,along with Isopropyl Alcohol for cleaning and de-greasing.
82 245 GLT Paint 35
Old 04-10-2010, 01:30 AM   #131
Drivers side rear door rust spot needs a little stripping with a small coarse wire wheel.
Then the channel shined up with the large fine wheel to keep the metal as smooth as possible.
82 245 GLT Paint 35
Notice where door has been hacked for speakers.
Old 04-10-2010, 01:45 AM   #132
Here is the welded area from the passenger side quarter panel replacement.
The bondo was an eighth of an inch thick and blistering from the rusty welds.
Again,the small [to keep cutting speed down] coarse brush digs out the bondo and rust then the fine wheel smoothes the metal.
All old bondo is removed.
It looks like the crappy cheap stuff,and it has to be redone anyway.
Smaller coarse brush is shown cleaning after the evapo-rust has dissolved the rust.
82 245 GLT Paint 36
Old 04-10-2010, 01:59 AM   #133
Smoothing across the grinding grain of the previous repair.
82 245 GLT Paint 37
Notice the tan colored epoxy primer sealer indicative of the previous repair in the feathered areas.
Old 04-10-2010, 10:13 PM   #134
pwschuh
Rolling...
Beautiful work.
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 04-11-2010, 11:00 PM   #135
Beautiful work.
Thanks I do what I can.
Old 04-11-2010, 11:05 PM   #136
Found significant rust on the bottom of the rear passenger side door that had already been replaced.
82 245 GLT Paint 44
Hunting the Oakland PnP for a late 940 glass headlight - fog - corner light for my body man I came across a rust free 79 244.
I bought the door I needed from it for $50.
It was well worth it to start with a clean slate.
82 245 GLT Paint 39
Old 04-11-2010, 11:08 PM   #137
MrSam
Grand Luxe Executive
MrSam's Avatar
mmm, I love that color. It will look much better in white though!
MrSam is offline   Reply With Quote
Old 04-11-2010, 11:11 PM   #138
Yep the car had been repainted and had lived in a good environment.
Kind of a non metallic root beer.
Old 04-11-2010, 11:13 PM   #139
Pulling the door seal gently to stretch it a bit,and twisting it removes it intact quickly.
82 245 GLT Paint 40
Old 04-11-2010, 11:20 PM   #140
Drilling out the 140 early 240 plastic trim clips.
82 245 GLT Paint 41
Old 04-11-2010, 11:26 PM   #141
Alcohol, wax & grease remover and a cut down chip brush gets it clean.
82 245 GLT Paint 42
Old 04-11-2010, 11:31 PM   #142
MrSam
MrSam's Avatar
Dave Barton sells those triangle stickers, and lots of other remake 240 factory ones.
New ones would really give it that extra touch of class when you are done.
Old 04-11-2010, 11:32 PM   #143
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
What was wrong with the 244?
Old 04-11-2010, 11:33 PM   #144
It's in the Oakland PnP.
Old 04-11-2010, 11:35 PM   #145
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
Old 04-11-2010, 11:36 PM   #146
Thanks,I agree.
I have some in my sticker stash.
Always good to put it back together so they see it's nice,
but they can't quite figure it out.
Old 04-12-2010, 01:24 AM   #147
Reference picture of the factory duct tape that keeps the trim from chafing the paint.
82 245 GLT Paint 43
Old 04-12-2010, 10:03 PM   #148
The DL early manual window door has a round 7/8 inch hole with no wiring for the windows or power door locks.
The GL doors have a slotted hole to accept the rubber accordion dust boot.
Hogging it out with an old broken drill bit.
82 245 GLT Paint 45
Old 04-12-2010, 10:10 PM   #149
Smoothing,shaping,and deburring the hole inside and out with a 5/8 carborundum stone.
82 245 GLT Paint 46
Edges are painted with a paint touch up bottle and allowed to dry before the shavings are hosed out of the inside of the door.
Old 04-12-2010, 10:19 PM   #150
Empty door shell is balanced on shoulder and bolted back on car.
The old bolt marks on the hinge are used to rough the alignment in.
Power locking,and power window units are then installed.
82 245 GLT Paint 47
