Old 12-02-2018, 08:08 PM   #51
poulrais
poulrais's Avatar
Originally Posted by DET17 View Post
I didn't realize the T6 could be had with an 81mm bore.... thought only the 5 bangers offered the small bore / more boost capability. Should be an exciting inline 6! Have you fit checked already in the 740 engine bay? A definite improvement on the redblock rear distributor against the darn firewall!
Very interested... .and will follow your progress. I haven't been to Quebec City since... 30 years now! I know the food was spectacular.... and I nearly died skiing Mont Saint-Anne.....
Yep... Same as the 2.3 T5 but with one more hole.
Can wait to drive this thing at 25 PSI of boost with the CD009 tranny.
Quebec City is still a very nice place to visit and have lunch. And though Mont Saint-Anne is a nice skiing venue you can drive 45 mins more and go skiing at Le Massif. This resort is much more developed than it was 30 years ago.
https://www.lemassif.com/en/
1990, Volvo 740 16v +T
Old 12-02-2018, 09:09 PM   #52
DET17
Reformed SAABaholic
Nice! Is that the same cyl. bore L6 engine that LANKKU keeps building over in Finland?
Old 12-02-2018, 09:21 PM   #53
poulrais
poulrais's Avatar
He has tried a few in the past... 2.9 and 2.8L with various heads, cams and pistons combos. Mine is a B6284t from a twin turbo 1999 S80.
Old 12-03-2018, 11:20 PM   #54
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Lookin great!
Old 12-04-2018, 09:36 PM   #55
poulrais
poulrais's Avatar
So... I took some measures of the CD009 + Whiteblock adapter with bellhousing and figured out where the shifter will end up using the Serial Nine shifter relocator system in a Volvo 740. I'm pretty pleased with the results. The distance between the front of the BH and the shifter lever if placed at it's most forward location on the Serial Nine adapter is 30 inches. So this means that you could place the shifter lever at 6 different locations in 1 inch increments between 30 and 35 inches from the face of the bellhousing. The distance between the back face of the block (for a T6 motor) and the middle of the motor mount is 14 1/8". If you add up that measure and the one from the BH front face and the shifter lever you end up with a 44 1/8" between the middle of the motor mount and the shift lever. I placed a measuring tape at 44 1/8" on the engine crossmember aligned with the middle point of the engine mount so the tip of the measuring tapes ends up where the shift lever should be on the transmission tunnel. Here are some pictures:
I also had some concern with the clearance between the shifter relocator mounting on the tranny's shift rod and the Nissan Cdxx driveshaft skip yoke. Well there is plenty of space, at least with this shifter relocation adapter.
I just don't know if these measurements can be applied for a T5 swap. Does the added cylinder of the T6 equate to added length towards the front of the back of the block in relation to the motor mounts?
Old 12-18-2018, 07:18 PM   #56
poulrais
poulrais's Avatar
Got some other parts in... Will finally be able to reassemble the engine and move ahead in the build a little!
Old 06-29-2019, 05:49 PM   #57
poulrais
poulrais's Avatar
Giving the old 740 a little bit of love. It's been there on a standstill resting on the candles for more than a year and a half. I went to the scrap yard this week to pick up a front suspension so I can get some wheels on and get her out of the garage for a much needed wash.
Will finally start working on it again and make some progression on the build.
The rotating assembly is heading to the balancing shop next week.
Old 06-29-2019, 06:32 PM   #58
Broke4speed
Broke4speed's Avatar
Damn, has it been that long?
Old 06-29-2019, 08:29 PM   #59
poulrais
poulrais's Avatar
Yep... Time goes by they say!
I'm looking at this T6 intake mani that Brett Willett is fabricating. Nice piece of art and the price is reasonable.
Still tons of work to do and parts to buy/fabricate but I'm more motivated than ever!
Old 07-03-2019, 04:38 PM   #60
poulrais
poulrais's Avatar
Did a good clean up and drop the mock up engine in...
Old 07-03-2019, 05:27 PM   #61
Hank Scorpio
Here's some motivation from Instagram
Old 07-03-2019, 08:21 PM   #62
poulrais
poulrais's Avatar
Weird dyno pulls but that sounds pretty mad!!
I checked the other vids on his Instagram and he has some traction problems I think!
Old 07-03-2019, 09:39 PM   #63
Hank Scorpio
My guess is they were tuning a specific range or throttle tip in. Sounds wicked and the other videos are mighty impressive.
Old 08-10-2019, 06:31 PM   #64
poulrais
poulrais's Avatar
Working on the brake upgrade...
Old 08-28-2019, 08:11 PM   #65
poulrais
poulrais's Avatar
Ordered my S14 subframe today. Complete with diff, axles control arms and knuckles but no suspension and brake calipers. I'm having someone picking it up tomorrow in Brampton, Ontario. So this IRS swap is happening!
Also ordering my turbo next week. I finally chose to go with this Borg Warner Airwerks S300SX3 Turbo 66mm T4 Twin Scroll 0.91 A/R.
Things are moving slowly but they are moving nonetheless!
Old 09-02-2019, 05:32 PM   #66
poulrais
poulrais's Avatar
My subframe is waiting for a ride from NorthBay, ON to Sherbrooke, QC. Can't wait to have this on the floor of my garage and start to figure out a way to put it under my 740. It looks like it has Nismo control arms. The bushings are going to be replaced by some racing urethane ones. I don't know if it's a limited slip or not either.
Anyone knows if these S14 control arms can take some HP without snapping like pretzels?
Old 01-10-2020, 02:05 PM   #67
poulrais
poulrais's Avatar
Got the valve cover/cam holder ceramic coated.
Old 01-10-2020, 06:35 PM   #68
Tfrasca
Tfrasca's Avatar
This thing is going to rip!
I'll be watching your IRS conversion closely.
Tfrasca is online now   Reply With Quote
Old 01-10-2020, 06:57 PM   #69
poulrais
poulrais's Avatar
Yeah this will be a lot of work but I can't wait to start!
Old 01-14-2020, 10:25 PM   #70
poulrais
poulrais's Avatar
Finally reassembling the motor.
Old 01-17-2020, 10:48 AM   #71
poulrais
poulrais's Avatar
Things are moving...
Old 01-17-2020, 01:57 PM   #72
DET17
Reformed SAABaholic
Bitchin'! Like the look of that inline six.
Hope you have consulted well with Lankku..... he knows how to keep these whiteblocks alive.
Surprised to see just a pair of valve reliefs in the pistons. I've not been up the skirt of a turbo whiteblock yet........ is that standard issue?
Old 01-17-2020, 02:50 PM   #73
poulrais
poulrais's Avatar
Bitchin'! Look the look of that inline six.
I sure hope so!
Old 01-17-2020, 03:48 PM   #74
Stiggy Pop
Stiggy Pop's Avatar
fresh!
'79 242
943 pickup
Old 01-17-2020, 09:13 PM   #75
Vol242vo
Keep it clean...
Vol242vo's Avatar
...and so clean clean.
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
