Old 08-09-2018, 05:35 PM   #1
6thousandths
Default 92 244 1JZ and IRS track car
I have started work on a new build, this is my first volvo, other than our 2012 C30 (which is a stock R-design polestar tune). I plan to build this for drifting and other weekend activities.
I can take more pictures if anybody would want to see something specific
This may be an unconventional brick but I decided to share it anyway.
The day I picked it up, blown engine, massive knocking due to oil starvaion:
Here is the front end stripped, with a complete s14 240sx front subframe and steering rack modified to fit. Also is a brake master/booster, and clutch master from a Z32 300zx. This setup fits s14 coilovers really well. I think the caster will be a degree or two less but should function well regaurdless.
Engine and transmission installed, 1jzgte VVTI with R154 from a JDM toyota chaser. This engine was previously in my infiniti M30 track car
Fitting the rear subframe now, going to be a challenge to make it fit right and drive well, I will be using a C-channel installed across the frame rails. I am working on this now
This is how it sits right now. I am getting a tube bender and will be building a front end this weekend hopefully.
6thousandths is offline   Reply With Quote
Old 08-09-2018, 05:40 PM   #2
6thousandths
I think I posted this in the wrong section...
Old 08-10-2018, 03:42 PM   #3
SlowRide
Cold War Crumple Zones
SlowRide's Avatar
I think so too, but it feels so right
- Justin
1980 242 DL
240 Junk for Sale
Feedback
SlowRide is offline   Reply With Quote
Old 08-10-2018, 04:20 PM   #4
TurboDenny
Why am I here?
I like this. This is good.
Instagram: @itstotesdenny
Old 08-10-2018, 04:32 PM   #5
poulrais
poulrais's Avatar
Start a build thread and I'll subscribe for sure!
1990, Volvo 740 16v +T
Old 08-10-2018, 07:53 PM   #6
HiSPL
HiSPL's Avatar
What IRS are you using?
Need pics of rear end.....
Beets taste like buttfeet.
Old 08-10-2018, 11:00 PM   #7
6thousandths
Rear end is from an S14 also I'll get some shots
Old 08-10-2018, 11:01 PM   #8
6thousandths
Can a moderator move this post to the build thread section? I can also make a new post I have more pics to post now
Old 08-10-2018, 11:09 PM   #9
6thousandths
Never mind I saw it was moved already
Old 08-11-2018, 09:32 AM   #10
Jack
junkman
Jack's Avatar
I have a narrowed 300zx irs on a late model 140 (basically a 240)
- center is narrowed. it uses 300 control arms and spindles with a ford 9inch
whats your IRS ?
I love you even more Jack.
Old 08-11-2018, 01:32 PM   #11
6thousandths
whats your IRS ?
This sounds like a cool set up, I am using an s14 rear subframe frame and arms/diff
Old 08-11-2018, 10:10 PM   #12
DocterHow
Can we get some more info on that s14 front suspension setup? And are you going to run a s14 angle kit?
'82 242 LS Swap | '90 240 Wagon | '91 1.9L Turbo Miata
DocterHow is offline   Reply With Quote
Old 08-12-2018, 03:24 AM   #13
6thousandths
It has modified knuckles +20mm rack spacer done by Future Fabrication here in Arizona.
I am using Powered by Max tie rods, also Tein s14 coilovers.
I drilled and reinforced new holes in the front frame rail for the subframe, the volvo rails are slightly wider than the 240sx so I decided to strengthen it a bit since the holes were pretty close to the very edge of the rail if that makes sense.
Old 08-12-2018, 04:40 AM   #14
GTFOUR
GTFOUR's Avatar
Following this build, i was thinking about putting an irs to my 245 since a long time ago, coming from a bmw. Its going to be very inspirational this thread
GTFOUR is offline   Reply With Quote
Old 08-13-2018, 06:31 PM   #15
brickcupra
Default ijz 242.
Hi im working with a wagon with the 7mgte amd the r 154 trans. Fits almost perfect in the tunnel , except for the right side that needs a little banging with a hammer to separate part of the body. I used a mustang shift lever for easier grab and i made it short shifter using the lower part of a toyota tacoma 5 speed
Good luck
DZ
brickcupra is offline   Reply With Quote
Old 08-14-2018, 01:27 AM   #16
6thousandths
Good luck
DZ
Thanks, that sounds cool.
I was able to locate the engine as I needed to so the R154 I have lines up well with the existing trans hole and tunnel. Sounds like you have the older model R154? might be some kind of difference
Old 08-14-2018, 01:39 AM   #17
6thousandths
Old nasty tank, is this worth saving or should I order a new one? Might use a fuel cell too, but I want the gauge to work. Ive had too many cars guessing if there is fuel or not
here are the studs I am going to use. The shoulder is 20mm, and length is about 80MM. 16x2.00 threads
Tonight I got the main C-channel in place and tacked in. I will be using this to locate the subframe, which will actually sit about 4" lower than this I think.
I had to cut out a good amount of the existing frame rail, because the bracket for one of the suspension links was part of the chassis there.
Subframe assembled and ready to test fit this week
Cut away alot of the sheet metal near the jack points in the front of the wheel well. There is so much nasty oil and grease underneath these cars...
more pictures to come soon
Old 08-14-2018, 02:48 PM   #18
SML
SML's Avatar
NICE! This is exactly what I'm doing! Not really, but close enough! I'm using S13 front and rear subframes and a 5.3 LS under a 122S. Either way, it's encouraging to see other people have the same thought. I have to harvest my Z32 soon. It's next under the knife, then those parts will be going under the Volvo!
SML is offline   Reply With Quote
Old 08-14-2018, 06:20 PM   #19
6thousandths
Some more pictures of the front end here:
Old 08-14-2018, 06:26 PM   #20
6thousandths
unrelated, I recently finished my wifes pink Tacoma engine swap from an is300:
Old 08-14-2018, 06:30 PM   #21
white855T
With an r154 or auto?
Old 08-14-2018, 06:32 PM   #22
6thousandths
Its using the stock 5-speed trans from the tacome (W59) and a 5speed SC300 bellhousing.
It all actually fit in there really well
Old 08-14-2018, 07:39 PM   #23
brickcupra
Default R 154 trans
Hi, well the trans is from a turbo 87 and it sits forward closer to the front due to the coolant hosing running in back of the head. I measured everything twice before doing the motor mounts as I had already purchased the stang lever and played with the measurements so i had an idea where it was gonna fall . Is already done and it feels like factory after 4 attempts but well worth the pain cause i was not gonna spent 200 bucks in a short shifter.
thanks for replying !!!
Old 08-14-2018, 07:51 PM   #24
brickcupra
Default Tacoma.
Hi , on the tacoma swap. Did u used the same IS 300 pcm to run the engine?
I know they use a transponder to start so I wonder how u did it. Clean job too.
My car is here in turbo bricks. ( brickcupra)
I just have not posted any new pictures cause I dont know how because they changed the format
VIVA LA TOYOTA !!!
Dz
Old 08-14-2018, 08:09 PM   #25
6thousandths
VIVA LA TOYOTA !!!
Dz
I had it on the stock IS ecu originally, but it was having some unknown problems, possibly related to the immobilizer like you said. It is now on a 2JZ-GE Aristo ECU and running without problems
