Old 08-14-2018, 08:38 PM   #26
white855T
Originally Posted by 6thousandths View Post
I had it on the stock IS ecu originally, but it was having some unknown problems, possibly related to the immobilizer like you said. It is now on a 2JZ-GE Aristo ECU and running without problems
Good info as I did not know this. Might consider a similar swap.
Old 08-14-2018, 09:02 PM   #27
6thousandths
Yes, it makes that engine really easy to swap. I know a lot of people stay away from VVTI but I love it. They are also very cheap to get.
I have heaps of wiring diagrams and documents if anybody is looking to do something similar, both 1JZ and 2JZ GE/GTE
6thousandths is offline   Reply With Quote
Old 08-14-2018, 09:54 PM   #28
Jack
junkman
Jack's Avatar
why do you say the stock tank is nasty?
unless you go with a fuel cell the repops suck - they are thin metal
I love you even more Jack.
Old 08-14-2018, 11:40 PM   #29
6thousandths
Thats what I was kind of getting at, I saw some replacement tanks online but was unsure on quality.
The tank is just rusted a bit and covered with grime, Maybe ill sand blast it and see how it looks. Then paint
Old 08-15-2018, 10:00 AM   #30
Dirty Rick
Dirty Rick's Avatar
4 gal vertical fuel cell, no air bubbles in the fuel. This also makes it easy to flood the inlet of the pump to prevent cavitation (more air bubbles)
https://www.summitracing.com/parts/sum-290110
Unless you want all that weight in the back and like bubbles in your fuel.
Dirty Rick is online now   Reply With Quote
Old 08-15-2018, 05:21 PM   #31
brickcupra
Default PCM
Oh ok nice to hear and I kinda figure that was gonna happen
See ya DZ
brickcupra is offline   Reply With Quote
Old 08-15-2018, 05:35 PM   #32
This tackles a lot of items I'm interested in learning more about. Suuuubbed.
Old 08-20-2018, 01:03 PM   #33
6thousandths
Here is how I plan to mount the subframe
I made some 4" dia standoffs and will weld in a collar for the studs to sit in (not fully welded up yet
these will mount like to, then be welded to the c-channel between the frame rails.
for the front I will make some square boxes once the rear is in the right position, I will also add some tubing to tie the mounting standoffs together and probably some gussets or something.
Currently my welder is not working so this is keeping me from getting too far right now
Old 10-01-2018, 12:30 PM   #34
6thousandths
got the rear subframe in after lots of cutting, it was pretty much a pain in the ass but its in there. Lots of welding to do. I had to take out a pretty good chunk on the frame rails on both sides so that will need to be reinforced.
[IMG][/IMG]
Old 10-01-2018, 01:04 PM   #35
Cool!
Old 10-02-2018, 12:37 PM   #36
Tfrasca
Tfrasca's Avatar
This is awesome. Will be watching with great interest.
Old 10-02-2018, 02:02 PM   #37
6thousandths
I am realizing I will need to tilt the subframe a bit forward, under compression the wheels are wanting to travel backwards relative to the frame. I will be cutting out the tack welds and modifying the mounts a bit to make this happen. You can see in the pics when the car is near the ride height it will sit, the wheels are a little bit back of center to the wheel wells.
and another pic of the subframe mounting set up (needs to be reinforced and fully welded still)
Old 10-02-2018, 02:07 PM   #38
6thousandths
also saw a twin to our c30! it was also an R-design, havent ever seen one in the wild
Old 10-03-2018, 02:38 AM   #39
narancs
narancs's Avatar
Really liking the subframe swaps, especially the rear. It looks a lot simpler and lighter than the IRS volvo used in the 7/9 series.
I did an IRS (from MK1 960) swap in my 940.. gained some weight in the back for sure! I guess it is good for traction... :D
'97 945 T5, mk1 IRS, NA cams, m90, 18T. COP converted Motronic 4.4 + Ostrich not gone.... but "changing"
'95 960 m90, 2.3 T5, VEMS, custom intake manifold... GONE
'97 850 T5m gone :(
narancs is offline   Reply With Quote
Old 10-03-2018, 03:08 PM   #40
6thousandths
I dont think its lighter than the live axle that was in there, but It definitley looks simpler than the other volve IRS setups I have seen. I also happened the have this set up sitting around so decided to go for it!
Old 10-03-2018, 04:17 PM   #41
LC4CARL
Aero challenged
LC4CARL's Avatar
Very cool.
@PDXvolvo on IG
Life begins at 10PSI.
Old 10-03-2018, 08:42 PM   #42
adomz
Volvo 486 owner :D
adomz's Avatar
That looks interesting!
Did i miss or something... What's the IRS off?
Cheers, Adam
Errr.... 242... No engine no cringdingding...
=->Adam's Joint Creations<-=
adomz is offline   Reply With Quote
Old 10-04-2018, 01:23 AM   #43
6thousandths
Cheers, Adam
IRS is from an S14 240sx
Old 10-06-2018, 07:53 AM   #44
adomz
Volvo 486 owner :D
adomz's Avatar
Oh, right. Good idea. I wam planning to use the Lexus LS400 rear for my 242DL whenever i am ready. Should be interesting seeing all work out.
Cheers
Old 10-09-2018, 01:52 PM   #45
6thousandths
Cheers
I would love to see this happen, I saw a truck with this subframe in it one time
Old 10-09-2018, 02:31 PM   #46
Tfrasca
Tfrasca's Avatar
How are you guys picking which IRS you want to use? A reasonably similar track width is obviously a concern. What else?
Old 10-09-2018, 03:15 PM   #47
6thousandths
yes you are correct about the track width. I had this setup already so I chose that. the volvo 240 has a track width of 67.3 (someone correct me if im wrong), and S14 has 68.1 so pretty close. Wheel selection would be important, and what amount of fender/body work you can/want to deal with would be important too
Old 10-09-2018, 07:48 PM   #48
Texas240
Prius Owner
Texas240's Avatar
1) search
2) find online measurements
3) Figure what works best for you and how much skill you want to put into it
93 245 LS Engine Swap Project
Old 10-10-2018, 11:08 AM   #49
SML
SML's Avatar
For me track width was out the window completely. There are like 2 reasonable IRS setups for track widths small enough for a 122. I'm just flaring/cutting fenders to make it fit and that gives me penultimate freedom to choose any IRS I feel like!
I used to be happy. Now I eat healthy.
SML is offline   Reply With Quote
Old 10-10-2018, 11:39 AM   #50
Tfrasca
Tfrasca's Avatar
Originally Posted by Texas240 View Post
1) search
I meant more along the lines of how the suspension kinematics perform, anti-dive/squat, etc.
