Old 09-04-2019, 01:19 AM   #26
tintintin
You measured +12VDC at the solenoid but yes a bad ground (or feed) could be limiting the current flow. The next test would be to disconnect the feed wire from the solenoid and run a test jumper wire to that terminal direct from the battery +. Try it also with an additional ground jumper to a known good ground. See if that makes the solenoid thunk harder than what you are getting thru the internal circuitry wiring.
Old 09-04-2019, 01:42 AM   #27
ogamer777
Loading...
ogamer777's Avatar
Good idea. I'll give that a go tomorrow.
84 242 DL M46 212000Mi
82 244 GLT (15G) M46 243500Mi 23 Aug 2019
79 242 GT 1 of 600 Aussie RHD BW55 312223Km
83 245 TURBO M46 "117000Mi"
81 264 GLE M46 105k
Feedback thread: http://forums.turbobricks.com/showthread.php?t=322924
ogamer777 is offline   Reply With Quote
Old 09-05-2019, 04:52 PM   #28
Test lamps are $3 at Harbor Freight. A meter is the wrong tool!!
I would first connect the wire to a test lamp and confirm current is making it to the solenoid.
