Old 05-12-2019, 01:31 AM   #1
Bricky McBrickface
Default Bricky McBrickface Build Thread
Hey, figured I'd start a build thread and track my progress.
Located in Lethbridge Alberta.
Overall, the car is pretty decent shape.
Plan for the car is to just get it to be a nice clean daily driver cruiser. I wanted a cruising car while I rebuild an engine for my mustang. Once that car is back on the road, then maybe I'll do more heavy modification on this car.
IMG_9604 by Richard Brown, on Flickr
IMG_9606 by Richard Brown, on Flickr
IMG_9614 by Richard Brown, on Flickr
IMG_9628 by Richard Brown, on Flickr
IMG_9652 by Richard Brown, on Flickr
Done so far:
-New taillights (fixed broken lights)
-Headlight bulbs (fixed highbeam issue)
-Acquired and installed rear driver trim
-Air filter replacement
-Acquired and installed license plate lights (not working, wiring needs repair)
-New front speakers
-Door sensors
-LED dome lights
-Oil change
-Seafoam
-Fixed reverse light (didn't replace sensor, was unplugged - wiring needs future attention)
-Recharged AC
-Bought and replaced some interior clips
-New license plate bracket (modified to 2 bolt)
-Painted brake calibers bronze
-New wheels
-E code headlights
To do list:
-Replace hatch. Only real rust on the car, have replacement hatch from older 240. Just need to paint and install.
-Rear gate wiring. No wiper, defrost, unlock, license plate lights. Have passenger IPD harness, planning on making drivers side. Doing at same time as hatch replacement.
-1 door door not central un/locking
-Fix heated seats
-Timing Belt (have parts)
-Rear hatch panel repair
-Polish/paint correction
-Clean/paint parts
-Front lip repair
-Cruise control lever. Previous owner replaced lever with cheaper level w/out cruise, have cruise lever hanging to still allow use. Want to replace with correct lever.
-Odometer fix (have part)
-Rear hatch shocks (have part)
-Reverse light wiring
WTB:
-Cool parts?
Bricky McBrickface is offline   Reply With Quote
Old 05-12-2019, 10:53 AM   #2
Vol242vo
Keep it clean...
Vol242vo's Avatar
Nice 245! Love Sirius'
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 05-12-2019, 11:14 AM   #3
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Originally Posted by Bricky McBrickface View Post
To do list:
-Tune up. I know the injectors and lifters are noisy, but seems a bit excessive? Trying to clean the system out, change oil and then progress deeper.
-Fix heated seats
Redblocks came from the factory with rubber valve hushers. These usually have disintegrated by now and causes a slight increase in valve train noise. They are un-necessary and many leave them out when building engines. These engines sound like sewing machines normally.
Post a vid and someone on here will tell you if yours is normal or not.
Seat heater kits: https://www.wagonmeister.com/seat-heater-kits
Old 05-12-2019, 06:24 PM   #4
Canuck
Frozen Garage Hell
Canuck's Avatar
Well, there is that, or you could always just swing by...I can tell you if your engine is fine. LOL. Welcome to the forum.
- Craig
1966 Canadian (B5234T, C4 up front, Supra out back and a nut in the middle) http://forums.turbobricks.com/showthread.php?t=328003
1981 242 (B230FT, LH 2.4...and a few other things)
YouTube channel covering Canadian build https://www.youtube.com/channel/UCsx...n3CiBQFd4rMyXw
Old 05-12-2019, 06:49 PM   #5
NotSoFresh
NotSoFresh's Avatar
Old 05-12-2019, 09:32 PM   #6
mblue240
mblue240's Avatar
One of the best colors ever used on a 240, but I'm biased. It seems like it's sitting high.
-Michael
Tbricks build
Yep, Michael is right.
Old 05-12-2019, 10:27 PM   #7
2turbotoys
Salaminizer
2turbotoys's Avatar
It's definitely riding high, but looks nice overall!
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 05-12-2019, 11:24 PM   #8
Bricky McBrickface
I'll take you up on that haha, when are you available?
More updates:
I just got the interior detailed. Friends of friends started a mobile detail business, really exceeded my expectations.
Started taking apart my replacement hatch. Removed all components, just need to remove badges and prep for paint.
More photos to come.
Old 05-12-2019, 11:41 PM   #9
Canuck
Frozen Garage Hell
Canuck's Avatar
More updates:
I live in my garage - there most evenings. PM me if you want to drop by.
Old 05-13-2019, 12:42 AM   #10
volvoshredder
volvoshredder's Avatar
Canuck is the guy I was telling you about that lives three blocks from me. Definitely worth a stop by for his expertise and to see his project car.
volvoshredder is offline   Reply With Quote
Old 05-13-2019, 11:07 PM   #11
LC4CARL
Aero challenged
LC4CARL's Avatar
Clean!
Life begins at 10PSI.
Old 05-20-2019, 05:28 AM   #12
Scaramanga
Cool. I like your wheels. Why not just paint them and buy new tires?
Volvo 142 1968, 145 1972, 245 GLT 1991
Scaramanga is offline   Reply With Quote
Old 06-23-2019, 08:49 PM   #13
Bricky McBrickface
Its not the paint that is the issue, they are dented and curbed.
I did pick up new wheels!
Also did a few things:
-New front speakers
-Door sensors
-LED dome lights
-Oil change
-Seafoam
-Recharged AC
-New wheels
IMG_1909 by Richard Brown, on Flickr
IMG_1910 by Richard Brown, on Flickr
IMG_1913 by Richard Brown, on Flickr
IMG_1916 by Richard Brown, on Flickr
IMG_1926 by Richard Brown, on Flickr
IMG_1929 by Richard Brown, on Flickr
IMG_1934 by Richard Brown, on Flickr
IMG_1937 by Richard Brown, on Flickr
IMG_1941 by Richard Brown, on Flickr
IMG_1947 by Richard Brown, on Flickr
IMG_1953 by Richard Brown, on Flickr
IMG_1968 by Richard Brown, on Flickr
Old 09-02-2019, 09:38 PM   #14
Bricky McBrickface
Been very busy at work the last couple months, but found some time to work on the Volvo and continue to strip my mustang parts car.
A few more updates:
- E code headlights, more of a project that I expected... First they came broken from fcpeuro, had a awful experience with shipping and didn't want to send them back for replacements. Repaired them. They also don't work with NA corner lights. Had to make a custom bracket from the corner lights and do significant trimming to the headlights. Also don't use the same bulbs? Had to modify the dust boot to fit with my bulbs/connectors. Still require alignment.
- Amber reflector removal
- Fuel filter - damaged a line, had trim and put barb fitting back in. That was a real treat...
- Flame trap
- Air box - removed heater tube and cut it open for better cold air flow.
- Front brakes - rotor and pads. No more brake vibration.
- Front wheel balance - no more vibration on highway
- Blue lug nuts
- Hella Horns - Doesn't sound like a boat anymore
- Engine bay detail and paint
Before:
IMG_20190817_154449 by Richard Brown, on Flickr
Stock lights
IMG_20190817_155915 by Richard Brown, on Flickr
E-code - tabs don't work with NA corners. Can to trim them off and make my own bracket for corners.
IMG_20190817_160038 by Richard Brown, on Flickr
My custom bracket. A bit roadkill, but used what I had. Worked well.
IMG_20190817_175636 by Richard Brown, on Flickr
IMG_20190817_175839 by Richard Brown, on Flickr
Before:
IMG_20190818_134825 by Richard Brown, on Flickr
IMG_20190818_134831 by Richard Brown, on Flickr
After:
IMG_20190818_144728 by Richard Brown, on Flickr
IMG_20190818_144744 by Richard Brown, on Flickr
Brakes:
Bronze is fancy rust paint. :p
IMG_20190819_113244 by Richard Brown, on Flickr
Hellahorn - not so boaty... Well still a boat, but doesn't have a boat horn anymore.
IMG_20190824_125817 by Richard Brown, on Flickr
IMG_20190824_125916 by Richard Brown, on Flickr
As it sits now! Really happy with how it drives. Would like to improve the starting, it always starts but randomly a little rough? Just going to continue to clean and do preventive maintenance.
Once the mustang is back on the road, then I'd like to do some bigger modifications. Right now this shares daily drive duties with my truck.
IMG_3964 by Richard Brown, on Flickr
IMG_3965 by Richard Brown, on Flickr
IMG_3970 by Richard Brown, on Flickr
IMG_3971 by Richard Brown, on Flickr
IMG_3974 by Richard Brown, on Flickr
IMG_3976 by Richard Brown, on Flickr
IMG_3980 by Richard Brown, on Flickr
IMG_3992 by Richard Brown, on Flickr
Old 09-03-2019, 02:18 AM   #15
Scaramanga
Nice car! Any progress with the hatch?
Old 09-03-2019, 09:23 PM   #16
Bricky McBrickface
Stripped and scuffed. Want to get this parts car out of my garage and then spray it.
Have new shocks and wiring to install with it.
Old 09-03-2019, 11:00 PM   #17
2turbotoys
Salaminizer
2turbotoys's Avatar
It's still https://www.youtube.com/watch?v=zmEbyttnxuY, but looking fresh and clean!
Old 09-04-2019, 12:51 PM   #18
6thousandths
clean car! keep up the lords work
6thousandths is offline   Reply With Quote
Old 12-09-2019, 10:00 PM   #19
Bricky McBrickface
Not much for updates. Have been working on the Mustang - got a large shipment of parts in for it, currently working on some porting/cleanup of the top end.
Anyways, a couple photoshoots of the Volvo I did recently.
IMG_4243 by Richard Brown, on Flickr
IMG_4251 by Richard Brown, on Flickr
IMG_4262 by Richard Brown, on Flickr
IMG_4265 by Richard Brown, on Flickr
IMG_4269 by Richard Brown, on Flickr
IMG_4271 by Richard Brown, on Flickr
IMG_4276 by Richard Brown, on Flickr
IMG_4281 by Richard Brown, on Flickr
IMG_4291 by Richard Brown, on Flickr
IMG_4303 by Richard Brown, on Flickr
IMG_4308 by Richard Brown, on Flickr
IMG_4314 by Richard Brown, on Flickr
IMG_4318 by Richard Brown, on Flickr
IMG_4335 by Richard Brown, on Flickr
IMG_4337 by Richard Brown, on Flickr
Old 12-09-2019, 10:17 PM   #20
oldschoolvolvo
oldschoolvolvo's Avatar
Nice pics! I dig the wheels in the snow pics.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 12-21-2019, 07:48 PM   #21
Bricky McBrickface
Merry Christmas! This is my vision for the car. Lowered, Ford fan wheels, and a roof rack complete with xmas tree
volvowhitebg by Richard Brown, on Flickr
Old 12-22-2019, 11:01 AM   #22
Vol242vo
Keep it clean...
Vol242vo's Avatar
That's cool!
I like how you have paint imperfections on the drivers door and window trim! So true!
Almost looks like Gru (from Minions) is in the back seat facing the rear, laughing.
Old 12-22-2019, 11:04 AM   #23
oldschoolvolvo
hilarious
Are those Foxbody Mustang Cobra wheels?
Old 12-27-2019, 08:36 PM   #24
Bricky McBrickface
That's cool!
I like the imperfections as well. Not scared to drive it
Originally Posted by oldschoolvolvo View Post
hilarious
Similar yes - they are actually thunderbird which 5x108. The hub bore is a bit different, but i need spacers anyways so I'll adapt them.
Old 12-30-2019, 07:47 PM   #25
Bricky McBrickface
FFS. Great start to my morning.
Anyone have a drivers/LH E-code lens?
Knew i should have stuck with the cheap plastic NA headlights.
Of course my security camera was offline when is happened. Rest of the car and truck are untouched though.
Not going to rule out an accidental rock kick up, but seems suspicious and looks like my landscape rocks...
IMG_20191230_054950 by Richard Brown, on Flickr
IMG_20191230_054956 by Richard Brown, on Flickr
IMG_20191230_143829 by Richard Brown, on Flickr
