Old 07-19-2019, 03:02 PM   #26
lunchb0x
Nobodylikesthetunahere
lunchb0x's Avatar
I grabbed the tester and gauge on Amazon last night so I'll have them here this weekend. I figured I might as well keep them for future use.
Originally Posted by 84B23F View Post
A vacuum gauge can measure the fitness of vacuum line from intake to IGN-MOD, when measured at both ends...two tests, one at intake, and the other and end of vacuum line.
That is my exact plan for the gauge.
Thanks for the info on timing advance, I'll give that page a read.
Originally Posted by B Mac66 View Post
Running a stock exhaust is pretty much the equivalent of trying to run a mile while you hold a pillow over your face.....
Originally Posted by gamby242 View Post
Wait a second. Safety on turbobricks?
You're concerned about safety?!?!?
Our cars are held together with zipties and jb weld.
lunchb0x is offline   Reply With Quote
Old 07-20-2019, 04:19 PM   #27
84B23F
84B23F's Avatar
I'd have to visually look, but on throttle body, there may be two ports...one for emission, and the other for IGN-MOD. When engine is at base idle, there should not be a vacuum on IGN-MOD's port on throttle body.
IIRC, from years ago, on distributor based engines, when doing timing, pulling vacuum line off was a prudent measure...so timing was set with no vacuum going to distributor (or IGN-MOD).
I've not examined vacuum ports on throttle body, but I assume the emission port gets vacuum when engine starts up. It's function is to suck gas fumes from charcoal canister.
Hence, each vacuum port may "suck" differently.
Oh this age! How tasteless and ill-bred it is.
-------- Gaius Valerius Catullus
Master Volvo List
Old 07-21-2019, 10:45 PM   #28
lunchb0x
lunchb0x's Avatar
I was able to get everything tested this weekend. I put the vacuum pump on the Ignition Module and it held 15in Hg without loosing any pressure. I also noticed a cracked line on the vacuum pump for the cruise control so I fixed that.
Vacuum at Intake Manifold
Vacuum at Ignition Module
The vacuum line for the Ignition Module is located on the intake manifold on my car. The throttle body has both ports used by the charcoal canister. I've noticed it's that way on friend's 240 as well. The line itself doesn't seem to have enough length to get to the throttle body.
I am hearing what sounds like a rushing of air in near the head next to the fuel rail. I'm not sure if this is just the sound of fuel rushing through the rail or if I have a leak somewhere. I checked all the lines and they seem good, I also sprayed some starter fluid around everything to check for leaks. I am going to pull the breather box out and inspect it. Video for sound reference below.
Old 07-27-2019, 08:12 PM   #29
84B23F
84B23F's Avatar
I've been out of town for a week....
If knock sensor is working...ask others how to test...one might set timing to 15°
IGN-MOD's vacuum sensor appears to be shot, if this Volvo test indicates a failure.
Old 07-28-2019, 10:18 AM   #30
lunchb0x
lunchb0x's Avatar
I picked up an Ignition Module from a board member and it didn't seem resolve the cut out issue. I have not checked yet to see if the timing advance is working with this Ignition Module. I will look up how to test the knock sensor.
When the weather gets a little cooler I'll get back to working on the car.
Old 08-02-2019, 10:04 AM   #31
lunchb0x
lunchb0x's Avatar
I noticed that with the timing set to 15 degrees or higher there is still a cutout but the return to normal is much quicker, only drops about 300rpm. With it below 15 degrees the car cuts out at 2000rpm, like "normal", then drops to ~1000 rpm before it runs to normal.
I checked the wiring on the knock sensor and in doing so I noticed the spade on the knock sensor moves around when touched... One would assume that's not normal. I took a picture of the sensor and it looks like the soldering has broken up.
I am going to grab the knock sensor from a LH 2.2 240 wagon that's at the yard, tomorrow or Sunday. It seems the LH 2.2 knock sensors are hard to come by new.
Old 08-04-2019, 11:56 AM   #32
84B23F
84B23F's Avatar
Originally Posted by lunchb0x View Post
...knock sensor...spade on the knock sensor moves around..
1985 LH 2.2's knock sensor was specific to Vehicle Fitment: Volvo: 242 1983-84 | 244 1983-88 | 245 1983-88. ...Volvo 1317296...$125.00 @ IPD
Cross Reference - Doing quick searches, STANDARD MOTOR KS82 comes up at $150.00 price range.
I suspect someone got "physical" with your knock sensor...two hands should have been used...one to hold spade down, while other to remove terminal.
Old 08-22-2019, 12:17 PM   #33
lunchb0x
lunchb0x's Avatar
So I replaced the knock sensor and nothing has changed... but I had a feeling that was going to be the case.
I set the timing back to factory and noticed that if I start up the car and rev it up so it cuts out and then set timing, once I turn off the car and start it up the timing is lower than what it was previously set at. Not sure if this is due to the cut out or just from me reving the car up and letting it idle before adjusting timing.
Still have not checked fuel pressure, I have been lagging on getting the testing equipment from a friend. I am going to try and get that done ASAP.
Old 08-22-2019, 10:16 PM   #34
84B23F
84B23F's Avatar
...timing back to factory...turn off the car and start it up the timing is lower than what it was previously set at.....
Timing would be controlled via Chrysler Box....I'd have to review its pin-out, but if it is "aware" of engine temperature, this can change timing, or if LH 2.2 is "talking" to it.
Timing is suppose to be done with engine warm, as explained in TP 30432/2; here's a snapshot of instructions.
Older vehicles with a vacuum and mechanical advance, timing is changed by changes in vacuum and changes in RPM. Chrysler Box is doing both also, electronically. Google that TP, and look at charts
Old 08-27-2019, 01:51 PM   #35
84B23F
84B23F's Avatar
timing back to factory...idle.
Never owned a vehicle with LH 2.2, but on schematic, the throttle position sensor (TPS) switch has a wire for "Idle Speed Adjustment Point." TPS does have a wire going to Chrysler box.
SEE: Setting Base Idle Specs and Mixture on Bosch LH2.2-Equipped Cars.
Needless to say, TPS must be set correctly. A tach is required to set idle correctly
Old 08-27-2019, 03:11 PM   #36
lunchb0x
lunchb0x's Avatar
Thanks! I ordered some led diodes so I can make the tool needed so set the base idle after checking the O2 sensor.
Old 08-27-2019, 05:35 PM   #37
84B23F
84B23F's Avatar
Led Test Light 999 5280
Old 08-27-2019, 05:43 PM   #38
84B23F
84B23F's Avatar
"You don't really need the 750 ohm resistor, and its value certainly isn't critical to the function; just protects the LED if you drop the ECU end of the probe on a ground."
Old 08-27-2019, 06:04 PM   #39
lunchb0x
lunchb0x's Avatar
I didn't bother to order the resistors after reading that. I ordered a pack of 100 led diodes so I should be good. I will just have to figure out what to use all the extra led lights on
Old 09-06-2019, 12:53 PM   #40
lunchb0x
lunchb0x's Avatar
So I finally got the fuel pressure measured. Not sure if the idle pressure is within spec I will try to find a manual to get that information. All I did to when checking is hook up the gauge to the car and let it idle up to temp. I did check the fuel pressure when the car cuts out and it did not budge.
I also checked the voltage on the O2 sensor and it appears to be cycling within spec. I noticed that when I rev up the motor and it does the cut out the voltage on the O2 sensor drops to 0.00. I will try adjusting the AMM this weekend following that guide.
Fuel pressure at Idle
Fuel pressure with FPR unplugged
Fuel pressure after a few minutes of the car being turned off
Old 09-06-2019, 01:45 PM   #41
84B23F
84B23F's Avatar
"At full throttle, manifold pressure is close to barometric, so the fuel pressure gauge reads about 2.5 bar (36 psi). At idle, absolute pressure in the manifold is about 0.3 bar (0.7 bar less than barometric). Now the manifold absolute pressure pushing the pressure regulator diaphragm is only 0.3 bar instead of 1 bar. The reduced manifold pressure on the diaphragm allows it to move away from the opening, returning more fuel to the tank, and dropping the gauge fuel pressure in the distributor pipe to about 1.8 bar (2.8 absolute). The relative pressure at the injector tip is still 2.5 bar (2.8 minus 0.3 absolute). That's why fuel delivery per injector is not affected by changes in the manifold absolute pressure."
1.8 bar = 26.1 psi
Old 09-06-2019, 11:08 PM   #42
84B23F
84B23F's Avatar
tachometer will immediately jump to ~1200 RPM ... I can press the gas pedal all I want but the car doesn't respond until the RPM gets down to normal idle and then the car snaps back and drives just fine..I noticed yesterday the car feels as if its lurching when I'm cruising around in higher RPMs while the A/C is on.
Tach Test - Remove wires going to positive side of coil and tape them so they don't ground out, and hook a direct wire from the battery to this coil's post. Each vehicle requires a coil designed for that EFI (ignition side)...check coil's number and see if its for LH 2.2...might ohm spec it also.
Temp Sensor - I'd ohm check it....Volvo had two different temp sensors for EFI side...1984s is different from LH 2.4...don't know which sensor LH 2.2 used When I get a vehicle, that's the first thing that gets replaced. Generally, they tell EFI engine is colder than it is when they fail, which is not what you have reported (like a lean mixture).
Timing, throttle plate, and idle RPM must be set to OEM's spec...as they explain how to do it.
Old 09-07-2019, 01:46 PM   #43
84B23F
84B23F's Avatar
Correction Made - "Tach Test - Remove wire(s) going to positive side of coil and tape them so they don't ground out, and hook a direct wire from the battery to this coil's post."
Old 09-16-2019, 12:35 PM   #44
lunchb0x
lunchb0x's Avatar
I will test this when I get a chance. The tach issue has been pretty intermittent and I haven't seen it in a while.
I pulled and stripped the wiring harness back to the firewall and replaced/repaired a couple wires. The wire for the cluster temp sensor and wire for the oil pressure sensor were degraded inside the harness. I also replaced the coolant temp sensor for the ECU with a bosch oem replacement as it was cheap.
So before doing all this I screwed up and applied power to the ground wire (blue/white) for the IAC when trying to adjust the MAF with the LED tool. I absentmindedly pulled into the wrong wire and I think I fried the IAC as the car died when I did so and would start and idle at like ~200rpm. I picked up an IAC from PnP from a LH 2.2 240.
When I got the car back together with the replacement IAC the car idled at ~1500 rpm. I gave the IAC a few delicate love taps and the idle dropped down where it should be. I had cleaned it with some carb cleaner but it might of still been a little sticky. After driving it around a bit Sunday the car is idling where it should and seems to run fine besides the cutout.
I noticed that when the IAC is unplugged the car does not cut out like it has been. With the IAC plugged back in the car cuts out on first start when rev'd to ~1900 rpm. Still only cutting out once and only after the car is started, does not happen again while running.
When I inspected the harness I did not see any other wires with degraded shielding or breaks. I've also swapped ECU's and ICU's previously and the cut out persists. Is there any other relays or anything that the IAC runs through that can be checked?
Old 09-17-2019, 11:37 PM   #45
84B23F
84B23F's Avatar
......Still only cutting out once and only after the car is started, does not happen again while running.
IAC Unplugged - IAC (Idle Air Control) is for idling...once throttle is pressed downward, and if throttle switch is set correctly, IAC is not operational (no signal sent to IAC). Make sure your throttle switch is operational, as based upon OEM specs. Cutting out at 1900 RPM should have nothing to do with your IAC...your throttle plate is in control of air volume passing into intake.
Cutting Out - AMM and ECU's temp sensor determine amount of fuel going injectors.
I bought a 1990 240, parked it for several months, installed parts, and took injectors to injector shop for flow testing....it runs like it did when new.
So, try this: Techron® Complete Fuel System Cleaner
Techron® Named Best Fuel Additive in Autoweek's 2019 Readers' Choice Awards
https://www.chevronlubricants.com/en...m-cleaner.html
Old 09-19-2019, 09:27 PM   #46
84B23F
84B23F's Avatar
Footnote - IIRC, IAC's trigger signal is a Hz signal, which means an automotive grade multi-meter is required to examine a Hz signal.
If your electrical switch on throttle shaft is set correctly, once peddle is depressed, IAC becomes in-active.
Hence, one could check for and evaluate its Hz signal....but I doubt this is relevant. If IAC was working after peddle was depressed, logically, it would be doing it after engine was warmed up.
Old 09-30-2019, 10:18 PM   #47
lunchb0x
lunchb0x's Avatar
I ran that a fill up or two ago. I am just about empty so I will pick up another one.
I picked up a AMM from PnP, cleaned it up and tossed it in the car. Still getting the cutout. Before swapping the AMM I noticed that when the car is cold the cut out moved up to about 3k RPM but once warmed up it cuts out at 1900 RPM.
I unplugged the battery while doing the MAF and the RPM gauge jumped to around 2k RPM when the key was turned on. With the car started the RPM gauge would not respond at all until warmed up.
I did the Tach test as you mentioned and nothing changed with the RPM gauge. It only responded once the engine was warm.
I've basically replaced everything aside from injectors and hall sensor with new/known good ones. From what I've read the hall sensor doesn't cause a cutout like this, the car dies or doesn't start. Is this the only known way a hall sensor fails?
Also, I hooked up a Noid light to the injector harness and all injectors had the same light and pulse intensity at idle and when revving up. I noticed that when the cut out happens the Noid light went out then came back.
Old 09-30-2019, 10:58 PM   #48
84B23F
84B23F's Avatar
Based upon a diagram, the Chrysler box has one terminal for LH unit...I suspect this might be a tach signal, but it might be in a square wave format. Need a scope to scope this out....point here, is LH unit causing the effect, or is the Chrysler box causing this effect (Noid light went out).
Distributor - Find another one, and change out, if PnP don't charge too much...
Tach - Its negative comes off negative side of coil....If tach's coil wire can be removed from coil, I would remove it...there should be two wires there, one for Chrysler box, and one for tach. Otherwise, disconnect tach's wires, and tape them.
Old 10-01-2019, 07:20 AM   #49
cleanflametrap
cleanflametrap's Avatar
Yes, the LH2.2-paired Chrysler unit improved things over the LH2.0 used the previous year by sending the tach signal from ignition to fuel on a low level voltage (square wave), separate wire. The B23's fuel system got that info through a shielded wire directly from the coil negative.
One issue that has plagued Chrysler/LH2.2 (85-88) cars is that RPM signal being lost where the two harnesses join under the intake manifold -- gray wire I think -- there's a connector that gets grody. If I remember my junkyard trips, the connector has both the gray wire for RPM and orange wire for TPS, but I haven't owned any of these lh2.2 cars either. Somehow I don't think that connector is the OP's issue here.
But, in skimming this thread I want to ask the question about the "fuel cut" assertion. How does one know a cut is fuel and not spark? Aren't the results going to feel the same? Power stops?
So I looked for some indication OP had the timing light running when the cut occurred. That suspicion goes toward your recommendation to get that tach out of the circuit, or swap the dizzy. Ignition cut out maybe?
-Art
cleanflametrap is online now   Reply With Quote
Old 10-24-2019, 10:49 PM   #50
lunchb0x
lunchb0x's Avatar
Thanks for the replies, I really do appreciate the help. I finally got some time work on the Volvo.
I swapped out the distributor with one from a '87 240 and installed a new Hall Sensor on it. The cut still happens, but I noticed the car seems to run a bit better. Before at idle when I'd press the throttle to the floor it would bog out and feel like it wanted to die, now it revs up with no hesitation.
I removed the tach wire from the coil and no change. I also inspected the harness connector under the manifold and it didn't look corroded or oily. I did clean it with some MAF cleaner. I haven't noticed the tach acting funny since, but it was also a random occurrence.
I had my roommate hold a spark plug to the strut tower and spark appears strong and does not cut out when the motor does. When I tested fuel pressure the pressure did not drop when the cut happened. I'm guessing the ECU is cutting the injectors?
