Old 08-06-2019, 05:50 PM   #51
I have that clutch master. It is a good clutch master.
Old 08-06-2019, 08:54 PM   #52
patrickstar
patrickstar's Avatar
Do you have the STS machining pedal or did you make your own? I feel like I'm missing something somewhere in the pedal assembly, its loose on the pivot
patrickstar is offline   Reply With Quote
Old 08-06-2019, 09:28 PM   #53
I have a lengthened cable pedal at the moment.
If it's loose on the pivot give them a call. That was a pre-production issue. I'm sure they must have sent you the wrong one by accident.
Old 08-06-2019, 11:08 PM   #54
77volvo245
77volvo245's Avatar
are you running the steel sleeve with the plastic bushings from the old pedal?
STSmachining
Old 08-06-2019, 11:53 PM   #55
Vol242vo
Keep it clean...
Vol242vo's Avatar
I need that clutch master, what’s the Wilwood part number/model number?
Progress is looking good!
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 08-07-2019, 10:40 AM   #56
patrickstar
I am running the steel sleeve, but I'm thinking my junkyard pedal assembly was missing the bushings because I don't remember any coming out. I'll take a look today
Originally Posted by Vol242vo View Post
I need that clutch master, whatís the Wilwood part number/model number?
Wilwood 260-15098
Its the 'new' version of the master that @77volvo245 suggests using with his pedal. I had no issues bolting it up, and all the specs are the same
Old 08-10-2019, 10:07 PM   #57
patrickstar
Got quite a bit done today. Started the morning with some tacos from the local taco truck
Cleaned the car out and moved it outside, and had a friend load it up and move it to a local fabrication shop
Once it was there, we got it on the lift and designed a quick and dirty crossmember. Used the stock crossmember with some plasma cut plates. Feels solid, looks good, cheap. I like it.
While my buddy was welding that together, I removed the stock fuel filter and pump and put the C5 corvette filter/regulator in its place.
I thought this was a funny head to head, shouldn't that V8 be in the Camaro?
Removed some minor things that weren't necessary and drained the tank too. Its starting to look like a real car
Old 08-15-2019, 11:44 AM   #58
patrickstar
Probably should have spent this money on more parts... But they were a good deal and I love GTAs.
In other news, searching for a local driveshaft shop who will build me a two piece to my specs. One said they would only do it if I brought the car to them, 160mi away. Any internet suggestions?
Old 08-15-2019, 01:56 PM   #59
yugo4life
yugo4life's Avatar
I love me some GTA's! That's what I was looking for before I got a killer deal on a set of 16X9.5 ARE 398s.
Lord Volvomort - 1984 244 GL - 175k and stock as a rock at the moment
yugo4life is offline   Reply With Quote
Old 08-15-2019, 02:25 PM   #60
RvolvoR
take it to six states in pasco
Old 08-15-2019, 03:05 PM   #61
patrickstar
You're the second person to suggest them, though someone said they'll only do one-piece? At this point, I just want it to move on its own so I might go with a one piece and deal with lowering it later on
Old 08-15-2019, 03:37 PM   #62
RvolvoR
I just had the six states in portland do a 2 piece for my ar5 and 8.8" setup. Took them a stock large diameter drive shaft and they did it all for $360 including parts.
Old 08-15-2019, 03:42 PM   #63
patrickstar
Holy **** man, thank you. I've been told by all my local car friends that no one will do it, its impossible, etc etc.
Now I just need to find a stock large diameter drive shaft to have them modify
Old 08-15-2019, 09:07 PM   #64
culberro
culberro's Avatar
Most delivery trucks are 2 and 3 piece drive lines. 6 States is primarily a truck and industrial supplier. They'll figure it out for you.
Old 08-15-2019, 10:00 PM   #65
77volvo245
77volvo245's Avatar
I taken few drivelines to Six states roughly 140.00 for shorten and balance
Old 08-15-2019, 10:56 PM   #66
patrickstar
And this is using a stock M46/M47 driveshaft? This'll change everything, I got quoted 600+ for a driveshaft from that shop 160mi away.
Old 08-16-2019, 12:50 AM   #67
77volvo245
77volvo245's Avatar
The rear half is the same volvo and the front I had the slip yoke added for my 4l60e
Old 08-16-2019, 10:08 AM   #68
patrickstar
Well thats rad, guess I'll start looking for a manual driveshaft. I was blown away at how tiny the auto driveshaft was
Old 08-19-2019, 10:43 AM   #69
patrickstar
Good sunday at the shop. Engine and transmission came out to install a speed bleeder on the T/O. It went far easier than I expected, so I got everything back in and bolted up hopefully for the last time (for a while)
Installed part of the ICT Billet bracket set, before I realized I ordered the wrong one. I ordered 551396-3, I should have ordered 551397-3. Don't drink and buy. It looks like all I need is spacers to run the Camaro water pump, but I'm going to call today to confirm.
Yeehaw
Old 08-19-2019, 12:25 PM   #70
patrickstar
Do I **** around and buy another 242 for $750? Looks a lot cleaner than mine
Old 08-20-2019, 12:30 AM   #71
Vol242vo
Keep it clean...
Vol242vo's Avatar
Duh.
Seriously though, if you can sit on it, Iím sure you could clean it, get it to a solid stage zero and make a little.
Old 08-20-2019, 10:03 AM   #72
patrickstar
Duh.
I want to go grab it so bad, but $750 would basically complete my car... We'll see, I'm gonna go take a look at it on Friday
Old 08-21-2019, 07:56 PM   #73
SmokesLetsGo
PooPoo Pee Pee
SmokesLetsGo's Avatar
Aw man! I was looking at those and the lady must've sold them to you right before I could swing in...
If trump has to destroy the country to get rid of the juggalos, so be it.
SmokesLetsGo is offline   Reply With Quote
Old 08-21-2019, 08:34 PM   #74
patrickstar
Man, I snagged them right after they went on ebay. Unfortunately, she didn't realize she had 3 fronts and a single rear... so I gotta find another front or another rear.
Old 08-23-2019, 10:14 AM   #75
patrickstar
Small progress yesterday, got all the accessories bolted onto the front. I was waiting on water pump spacers so I could use the Camaro waterpump with truck accessories.
