Old 08-28-2019, 05:23 PM   #26
Marvelous3
Who engineered this?
Marvelous3's Avatar
God ducking damnit! That little **** as fuse in the engine bay. I pulled it out and it didn’t look bad. Threw another fuse in it cause why not and I got the blinks lights back. Cranks and runs now. God ducking damn Volvo. Who engineered that ****?
Old 08-29-2019, 03:38 PM   #27
sbabbs
sbabbs's Avatar
Ha, yeah that is the main fuse to the ECU for those junker 240's.. I've had to replace that fuse holder also as it gets wore out with corrosion and the stupid plastic holder thingy. I just buy a 30 amp same fuse holder from napa and splice it in. You just gotta always remember about it and check it if car don't run.. Same problem with a 2.2 240..
1988 245 White slicktop M47 Wagon! Motor still out of it.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 548K Melted motor..
1995 940 White racing wagoon. T25 .64 a/r m90 to put in
Old 09-02-2019, 05:41 PM   #28
Nagrom
Nagrom's Avatar
https://www.ipdusa.com/products/5731...der-ipd-102452
Nagrom is offline   Reply With Quote
Old 09-09-2019, 02:13 PM   #29
sbabbs
sbabbs's Avatar
Welp rained yesterday and low and behold my 95 940 running like sheet, so swapped out the CPS, had a crack in the usual spot and the fuel pump relay, no fix. Next up check powerstage and plug wires. Crazy..
Old 09-09-2019, 02:24 PM   #30
iHateVolvoPeople
This seems almost more common on 7/9 cars because the dist is right where the hood meets the cowl. It's always water in the plug wire holes for me when it gets wet.
Feedback Thread
Current:
93' 244T M47
90' 744 AW70
95' Camry A140E, 246k
99' Camry A140E.
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
90' 745 NA sold
93' 945T in burgundy
91' 745 Regina AW701 turbo (traded for 96 Camry wagon)
93' 245 M47
