Old 08-27-2019, 04:31 PM   #1
Fa182
Stage 1
Fa182's Avatar
Default Exciter wire for alternator
Alright so as long as I had my 1997 945T, I have to manually excite the alternator after starting the engine by pressing a button that was added some time ago from the pre-pre owner.
It's just a wire coming from the battery + terminal, through the button and going to the alternator D+ terminal.
Just a quick push and the ABS and SRS lights go off, which then tells me the alternator is charging (they keep lit after starting until I press the button). I can feel the alternator starting up because there is a noticeable short dip in the idle speed.
The battery light goes out as soon as the engine starts though, even if I didn't press the button yet, which is weird maybe?
It seems there is a bad solder joint somewhere I guess? I don't really know much about the cluster, so could anyone help me out or lead me in the right direction what I could do?
I've had a look at the wiring diagram and found that pin 22 on connector C2 is the D+ wire going to the alternator, but it doesn't say where it comes from the cluster going to connector C2.
Thanks!
Old 08-27-2019, 04:48 PM   #2
JohnMc
JohnMc's Avatar
Weird that the alternator light is working. Usually, the exciter circuit is switched 12V+ - to the alt warning light, through it, and then on to the D+ terminal. And that's enough current to fire off the alternator, and once it's fired off, the D+ terminal was 12V+ too, so current no longer wants to flow from switched 12V+ to D+ terminal, so the light goes off.
So you apparently have an alt warning light circuit that works well enough to light the bulb, but not well enough to fire the alternator? It would be interesting to see what a multimeter shows on the D+ terminal when the engine starts up, but before you press your manual excite button.
I had a fault on the printed circuit on my 245, no alt warning light, and if you pulled the D+ wire off, it would read 12, 12.5V, but plugged in it was only 4-ish volts. Some faint amount of current was coming from somewhere on the instrument cluster and making a very low wattage 12V current.
Is it possible for an alternator to go bad in a way that all it needs is more than the normal amount of current to excite it?
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 08-27-2019, 11:31 PM   #3
sbabbs
sbabbs's Avatar
On my 240 it goes from the ignition switch to the starter. I tapped into it when I upgraded from LH 2.2. 2.4 for the 2.4 harness. I know the alternator light stays lit if the diodes are bad in the alternator. OR some other short in the wiring or alternator.
1988 245 White slicktop M47 Wagon! Motor still out of it.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 548K Melted motor..
1995 940 White racing wagoon. T25 .64 a/r m90 to put in
Old 08-28-2019, 09:48 AM   #4
Fa182
Stage 1
Fa182's Avatar
Thanks for the replies so far guys.
So it means the D+ going to the alt through pin 22 at C2 connector (according to the wiring diagram) is just coming from the alt warning light?
It is not visible in the diagram, unless I missed something obvious, but I looked over and over.
John thanks for hint, I will measure the D+ on the alt before pressing the button and see what it says.
Someone said the alt light bulb could be faulty or wrong current or something like that, could that be a reasonable explanation too?
Old 08-28-2019, 10:03 AM   #5
JohnMc
JohnMc's Avatar
Granted, it's a 1995 green manual, not 1997, but I don't think they changed much. And it matches what the 240 does, so it's not something that they were getting too creative with in general.
I didn't find the page for the main wiring diagram, with the wire colors and terminal numbers, but on page 193 they have a 'symbolic' or schematic view of the alternator circuitry (and starter, and a few other pertinent things): http://www.v8volvo.se/mekartips/volv...940%201995.pdf
And, even as it goes through multiple connectors and probably printed circuit boards (on the instrument panel) the circuit really is:
- switched 12V+ from the ignition key
- the charging warning bulb
- the D+ terminal on the alternator
I guess the 'engine not running' picture shows that voltage is somewhat reduced past the warning light, via the resistance of the bulb. And when it's running and charging, that side of the circuit should be up to full system voltage (which stops current flowing through the bulb in any significant amount, turning it off).
Old 08-28-2019, 10:33 AM   #6
Fa182
Stage 1
Fa182's Avatar
Yeah I was looking at the exact 1995 manual, as I didn't find a 1997, but from my previous ventures into the wiring (for retrofitting keyless entry with factory parts for example) they didn't really change anything those last 3 years till 1998 as far as I'm aware. They only changed some thing in the earlier years like 92 or 93 from what I've seen.
I must admit I didn't look at page 193 with the schematic of the power supply, but it's clearer now to me, thanks for that.
What I looked was the combined instrument diagram on page 53 in the pdf, page 85 in the pdf for connector C2 pins (22 for alternator D+) and page 124 for the wiring.
That was very helpful John, thanks. I have some measuring to do now.
Old 08-28-2019, 02:19 PM   #7
If the alternator light bulb was replaced with LED you'll need to add a small resistor to excite the alternator.
Old 08-28-2019, 02:29 PM   #8
Fa182
Stage 1
Fa182's Avatar
Thanks Ian, good tip. It shouldn't be an LED though because it looks just like the other warning lights. But you never know, I have to check.
Old 09-06-2019, 12:31 PM   #9
Fa182
Stage 1
Fa182's Avatar
OK so I'm amazed at my own stupidity here. The battery light does not actually light up at all when turning the key. I don't know what I confused the light with. I guess I just didn't properly look at it. Man oh man.
Anyway, I can't really remember if it ever lit up for as long as I owned the car, but I'd like to think it definitely did at some point when I bought the car.
So I'm gonna replace the bulb first of all, I already ordered some at Skandix when I ordered my new muffler. Gonna try tomorrow.
Maybe it's as easy as this, but then again I would wonder why the PO has made the effort of running an extra wiring circuit + button instead of just replacing the bulb. Who knows though.
Old 09-10-2019, 03:29 AM   #10
Otto Mattik
Otto Mattik's Avatar
Nice illustration, thanks Ian
Originally posted by Jack
_________________________
Feedback Link: http://forums.turbobricks.com/showthread.php?t=323689
Old 09-10-2019, 11:15 AM   #11
Fa182
Stage 1
Fa182's Avatar
Yeah although the post above it is not much help in my case, I want to thank Ian as well, I always find his posts to be the most helpful in any threads across the board.
Anyway, I tried swapping the bulb and also tried different bulb holders. The light still doesn't come on.
I'd really appreciate some further help from some wiring experts...
Here's the diagram of the instrument: http://borich.lesnoe.spb.ru/auto/Vol...202_us_127.pdf
I was studying the wiring diagram in and out and the circuit for the battery light doesn't seem to be very complicated.
It's just the + from connector A2 (that all warning lights and instruments share) and through a diode to C3.
I tried my best measuring all solder points and tried a 12V power source between those points and the light did actually come on. So it seems the circuit is good?
The diode is not getting out of my head though, could they get bad? On the other hand, the light would've not come on if it's bad when I tested it, I guess.
I've yet to measure if there is actually power at C3 (output battery light) when the cluster is in the car and ignition on.
If there is, it could just be something between the cluster and the alt D+, right?
It runs through the big C2 connector in the footwell, so I guess that would be my next thing to check.
Old 09-11-2019, 03:48 PM   #12
You have to also check that the D+ terminal is at ground when the ignition and system is off and when you turn on the key but don't start the car. The D+ provides ground for the 12V that is powering the light bulb and the cluster when turning the key to on. Then as the engine is started the output from the D+ will equal what the alternator is sending to the battery on B+. So the light goes out. That voltage also kick starts the alternator charging which is why it's called the exciter. For just a moment it is open circuit when starting and it has the full 12v applied to start charging.
You can test the battery light by connecting the wire on D+ to the alternator case. turn on the ignition and see if it lights. If it does then you know the ground wire for the alternator case is good and the cirucit from the dash is good. Sometimes with bad diodes the D+ cirucit can do wacky things.
Old 09-11-2019, 03:57 PM   #13
Fa182
Stage 1
Fa182's Avatar
Thanks for your reply!
I hope I understand that correctly: I have to disconnect the red wire coming from the instrument cluster at D+ port on the alternator and just hold it against the alternator case somewhere when the ignition is on?
If it lights up, what am I left with to check or do?
Old 09-11-2019, 04:02 PM   #14
Yes, if it lights up when connected to the alternator case. then the circuit in the dash is good and the case ground wire on the alternator is good. If it doesn't light. You may have a bad bulb. If it doesn't light and you know the bulb is good. Measure to see if you have 12v on the small red wire with the key on. If you do. The the alternator case ground wire could be bad or something inside the alternator is not bringing the D+ terminal to ground so the bulb will light.
Old 09-11-2019, 04:22 PM   #15
Fa182
Stage 1
Fa182's Avatar
Got it, thank you so much, that is very helpful! Certainly did not have the alternator itself in mind.
I already swapped out the bulb and bulb holder for new ones and also checked that the connection for the bulb holder on the PCB is good. Like I said earlier, I did apply a 12V power source when I had the instrument out of the car and the bulb did indeed light up.
Will check again in the next few days.
Old 09-11-2019, 08:51 PM   #16
HighMans
May or may not help, in these cars the connectors (specifically the male ones) are notorious for having issues with the insulation breaking down. When they break down, the connections can become corroded, and there's no hope in putting the connectors back together bar having bare pins connected to each other.
Don't know if this is applicable, but looking the wiring diagram on a '95 940, the driver side 8 pin connector by the fender has the D+ as one of the wires in the connectors. Picture below.
HighMans is offline   Reply With Quote
Old 09-11-2019, 10:00 PM   #17
bobxyz
bobxyz's Avatar
Document page 70-71 (pdf page 37) of this greenbook shows that there is some sort of fuse (part # 11/41, on the back of the cluster board) in the Alt lamp circuit. From your description, it sounds like this fuse is blown.
Old 09-12-2019, 01:38 AM   #18
Fa182
Stage 1
Fa182's Avatar
Thanks for your further replies!
Yeah I saw that fuse 11/41 as well, but in the complete diagram of the instrument, the fuse is before all other warning lights and instruments, not only the alt circuit. So if that has blown, no lights or instruments would come on at all (except the clock) imo.
File Type: jpg Screen Shot 2019-09-12 at 07.34.19.jpg (103.9 KB, 62 views)
Old 09-12-2019, 11:00 AM   #19
bobxyz
bobxyz's Avatar
I'm wondering if there's some way that the alternator is back powering the cluster. Next time the cluster is out, check the resistance across the fuse - should be ~0 ohms.
What exactly are the symptoms? When you first turn on the key, but before starting, what warning lights go on? After you start, but before you press the magic button, what lights go out? After you press the magic button, what lights go out?
Normally, a non-charging alternator turns on a bunch of warning lights in addition to the battery warning light (basically anything shown with a diode in the diagram).
Old 09-12-2019, 12:19 PM   #20
cleanflametrap
cleanflametrap's Avatar
The idea is to provide a means to test the lamps at key on engine stalled for those functions where only a failure would close the circuit.
Just be aware there are other uses in the vehicle for D+ where an indicator of "engine running" is needed. I know little about 940, but in the 240 for example, other functions tie to that line and it isn't shown on the maps for charging the battery. With the key on, engine stalled, I see about 1.8V on the D+ wire (plenty ground to light the lamps) and if I disconnect the alternator's ground wire, it rises to battery voltage.
So when you test by holding the D+ wire on the alternator's housing, you're testing two things at once. If the lights don't come on, try holding the wire to a known ground (I use a jumper wire to the battery negative because the wire doesn't reach anything reliable by itself).
This drawing isn't labeled as such but it is about 240 Volvos.
-Art
Old 09-12-2019, 02:59 PM   #21
Fa182
Stage 1
Fa182's Avatar
I fixed it! Man that feels good!
The battery light now comes on as soon as I switch on the ignition and after starting the car, the battery measures a healthy 14.7 to 14.9 volt which tells me the alt is charging.
What I did today was the following:
After I checked continuity from the output plug of cluster all the way to the alt D+ port through all connectors in between, the only thing left was the instrument panel.
I'm not sure if I made a mistake measuring the first time, but there was no continuity from the last solder point to the port where the plug connects.
I filled it with lots of fresh solder and all of a sudden there was continuity again up to the plug.
It's the circled point on the photo that was the culprit.
Old 09-12-2019, 03:04 PM   #22
Fa182
Stage 1
Fa182's Avatar
Just to answer all open questions here, the following lights came on before starting:
- Lamdba
- Oil pressure
- Brake light
- Parking brake
- ABS
- Belt warning
- SRS
What stayed lit after starting the car:
- ABS
- SRS
After pushing the button, both ABS and SRS went off.
Now the Washer Fluid light and the Bulb Failure lights come on as well, I didn't even know they should've lit up when turning the ignition on
Old 09-12-2019, 03:05 PM   #23
JohnMc
JohnMc's Avatar
Awesome! Same issue I had on my 245 - fault in the printed circuit on the instrument cluster.
I had to use a magnifying glass to find it.
Old 09-12-2019, 03:06 PM   #24
Fa182
Stage 1
Fa182's Avatar
And last thing, thanks to all your helpful replies. I certainly learned a lot through your posts.
Very happy about the amount of help I always get from this forum.
Old 09-12-2019, 03:12 PM   #25
Fa182
Stage 1
Fa182's Avatar
I did that too, but I couldn't really see anything suspicious. In the end, it was the missing continuity between the joint and the plug.
I'll keep the extra circuit for a little while though, just to be on the safe side.
