Old 09-01-2019, 07:01 PM   #1
todayzbrick12
Default 91 940t crank but no start
She is too nice to crush. And I hate to just part her out. Help me get her running guys at least so someone would take her off my hands.
Taking up space in the garage that is needed for other projects.
Has spark, and fuel. Checked and both fuel pumps are working,
No codes showing up
Have checked things mentioned on step-by-step Volvo with no positive results.
Now do I understand this right. If I have fuel and spark the sensor on tranny is good?
What about he distributor? Those are the only two things besides computers I’m uncertain of.
todayzbrick12 is offline   Reply With Quote
Old 09-01-2019, 07:10 PM   #2
iHateVolvoPeople
Do you have consistent fuel and spark? Backstory on car: has it sat for a long time? Check injector resistor pack, they get corroded. Just because pumps are on doesn’t mean injectors are firing. Radio suppression relay is susceptible to failure as is its wiring. You can temporarily bypass it easily. This RSR relay will cause injectors not to fire.
Feedback Thread
Current:
93' 244T M47
90' 744 AW70
95' Camry A140E, 254k
99' Camry A140E. 256k
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
90' 745 NA sold
93' 945T in burgundy
91' 745 Regina AW701 turbo (traded for 96 Camry wagon)
93' 245 M47
Old 09-01-2019, 08:26 PM   #3
todayzbrick12
I checked for 12v at green wires of injectors and green to injector resistor. Also got 12v at rsr red wire.
Old 09-01-2019, 08:28 PM   #4
iHateVolvoPeople
Does the engine crank healthily like it sounds as if compression is all well? How about mechanical timing?
Old 09-02-2019, 06:14 AM   #5
cleanflametrap
cleanflametrap's Avatar
If at all uncertain about spark, hit it with a spritz of starting fluid. Does "no codes showing up" mean no lights, or just the codes for all is OK?
-Art
cleanflametrap is online now   Reply With Quote
Old 09-10-2019, 09:51 PM   #6
84B23F
84B23F's Avatar
If fuel is entering combustion chambers, and it has spark, then timing belt has slipped, or Cam sprocket is spinning on cam shaft (busted key).
