Old 09-07-2019, 04:57 PM   #26
JohnLane
Originally Posted by D.E View Post
If you have an impact it’s really quick and easy. Crawl under and zip off the three nuts on each side that hold the bracket to the subframe. Jack the engine up by the oilpan. Undo the M8 bolts holding the brackets to the block. Put the whole assembly in a vice and zip the nuts off. Replace rubber mount and put the whole thing back.
Maybe an hour for both sides including figuring out if the bolts take a 12 or 13mm wrench and then some swearing at that one M8 bolt by the oil filter.
Do be sure to pull the pair of screws holding the fan shroud in and shake it loose from the radiator.
