Old 09-05-2019, 11:20 PM   #26
John V, outside agitator
7.62x39 is AP?
Eventually..That's what he needs a 30rd mag for. Taped to the other for ultra fast swaps..
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 09-06-2019, 12:24 AM   #27
Vincent Gagnon
Vincent Gagnon's Avatar
Member of TBCCS
Old 09-06-2019, 07:28 AM   #28
ogamer777
Loading...
ogamer777's Avatar
Get a carbide tipped drill and drill into the steel drill bit a little then use an easy-out to extract the broken bit.
Or if you can manage it, use that carbide bit and just finish drilling the hole, or at least past the broken steel bit.
84 242 DL M46 212000Mi
82 244 GLT (15G) M46 243500Mi 23 Aug 2019
79 242 GT 1 of 600 Aussie RHD BW55 312223Km
83 245 TURBO M46 "117000Mi"
81 264 GLE M46 105k
Feedback thread: http://forums.turbobricks.com/showthread.php?t=322924
ogamer777 is offline   Reply With Quote
Old 09-06-2019, 11:57 AM   #29
Time to find another 7-9 on CL?
Oh wait the $5 they charge now is more that they're not worth.
740 = 404
940 = 404
Old 09-06-2019, 12:16 PM   #30
RvolvoR
seems like certain aspects of turbobricks never change...carry on
Old 09-06-2019, 12:32 PM   #31
283SD
When you are drilling cast iron the drill bit has to be sharpened different than when drilling steel. You have to grind the leading edge [sharp rake ] parallel to the center line of the drill this prevents the drill from biting in. What you end up doing is scraping away the cast iron rather the the drill trying to screw itself in to the cast iron thus snapping the bit.
Old 09-06-2019, 12:38 PM   #32
iHateVolvoPeople
740 = 404
940 = 404
good....I need to offload about 3-4 cars right now anyway, no room/time/money for all this crap.
Feedback Thread
Current:
93' 244T M47
90' 744 AW70
95' Camry A140E, 254k
99' Camry A140E. 256k
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
90' 745 NA sold
93' 945T in burgundy
91' 745 Regina AW701 turbo (traded for 96 Camry wagon)
93' 245 M47
iHateVolvoPeople is online now   Reply With Quote
Old 09-06-2019, 02:17 PM   #33
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Athlon says hi
Hello My Glorious!
Old 09-06-2019, 02:19 PM   #34
OttoB
Just being simple ingengjörare, I would just weld a AN nipple to pan. If you can't weld, ask welder to do that. It is 15 min job of you bring clean parts.
Old 09-06-2019, 02:30 PM   #35
Spend $20 a week listing four turds on CL?
Shirely you jest?
Old 09-06-2019, 02:39 PM   #36
JohnMc
JohnMc's Avatar
740 = 404
940 = 404
This automotive abortion has a couple of Volvo parts on it: https://springfield.craigslist.org/c...953377273.html
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 09-06-2019, 03:05 PM   #37
iHateVolvoPeople
Shirely you jest?
Nope, I sell all my crap on FB marketplace. Last 2 grandpa series I sold went quick, like 3-5 days I think. And then the $100 945T I sold, got messages saying " does it run?"
Old 09-06-2019, 03:08 PM   #38
iHateVolvoPeople
I'm a dick to people all the time and they still sell. 99% of peoples questions are answered in the ad (or are obvious). If they have a genuine question, then I'm very professional about it.
Old 09-06-2019, 03:24 PM   #39
Vincent Gagnon
Why is this in performance?
Old 09-06-2019, 03:27 PM   #40
iHateVolvoPeople
"Performance and Modification"
I modded my block with a quarter, 2 broken bits, and some JB weld. Car is on jackstands so it's appropriate.
Old 09-06-2019, 06:51 PM   #41
No this drilling the simple hole has been covered 5,387 times. Its simple.Drill a hole..
This is hardly a "modification"..Its drilling a hole..how many times does the same thing need to be proclaimed.
It is like all else in your life a cry for attention..
Be honest...Try it. It's not hard and eventually you get used to it..
Then life will improve.
Old 09-07-2019, 03:13 PM   #42
ogamer777
Loading...
ogamer777's Avatar
He tried modifying the engine block
Old 09-07-2019, 04:02 PM   #43
Which consist of drilling one hole just like the 8,394 other times people have posted threads about drilling 1 hole..
Only difference being they managed to drill one hole and this poor kid can't...
Old 09-07-2019, 05:58 PM   #44
iHateVolvoPeople
Which is it, 5,387 times or 8,394 times? Not so good with numbers? And people let you build their engines smh
At least when I put this engine together and it doesn’t run, I’ll only have myself to blame.
Old 09-07-2019, 07:30 PM   #45
Both close estimates, but complaining about an obvious made up number, made up for illustration of the commoness of this simple job you cannot manage does not distract us from your astounding inability to do even the simplest of tasks without endless crying and subsequent pouting and posing...
obvious ineptitude is obvious..At some point you may financially embrace it and stop puffing your little chest up..and then you may get some respect instead of the near-universal derision you now earn.
Old 09-07-2019, 07:45 PM   #46
vwbusman66
Eisen-Stein
vwbusman66's Avatar
Because you're not an egotistical self-proclaimed "expert" and "perfectionist", right?
Remember that time you f*^ked up a batch of flywheels?
Old 09-07-2019, 07:57 PM   #47
iHateVolvoPeople
I'm gonna be honest with you, I cannot get through an entire one of your posts without opening a beer. You have special powers
and no one is crying about the oil return, it's been done since the following day that I made this thread. Head is put back together and on the block..time goes on.
Now do us all a favor and stop wasting bandwidth with all your **** talking
Old 09-07-2019, 08:05 PM   #48
Actually what I specifically fawked up was not counting the teeth on the flywheels which I had subcontracted the cutting of the teeth which I had given the machinist a sample and written in numbers about 2" high "60-2" and explained and also showed him the indexing of the -2 part and even explained how he could use the sample to first zero the sample in the mill and run the X and Y axis out to establish the beginning point...I thought it was clear, he thought it was clear---the NEXT guy who got the same instructions somehow managed to with same sample and same instructions get it right...
The difference was the first guy was a CNC mill guy 100%, the second guy was a engine builder for 40 years who was ALSO a CNC lathe and mill guy...being an engine builder he was familar with 60-3 and 36-1 TDC sensors and indexing...and he looked at and referenced the sample..
All things an under-derprived snotty boy like you have absolutely no conception of and probably never will because you're more interested in trying to score inter-net points than learn anything from a very costly but very simple mis-communication...something that happened more than 10 years ago...
And which while there were delays everybody got there parts they ordered..
Here let's but this into perspective: what did you learn last time you designed and manufactured a short run series of products for the Volvo aftermarket?
Oh...yeah..
you can't.
Old 09-07-2019, 08:09 PM   #49
Actually little whiny boy that wasting of bandwidth is the very nature of what ALL your posts detailing in gruesome detail whatever it is your latest f**k up is..
Virtually every single thread you've started is a waste of bandwidth about your struggles.
Old 09-07-2019, 08:18 PM   #50
iHateVolvoPeople
Oh...yeah..
you can't.
2 and 1/2 beers for this post. Nice work!
