Old 09-06-2019, 05:40 PM   #1
xmlhack
xmlhack's Avatar
Default no power at fuel pump - 1972 142e
tried to start the car for the first time ever, and the new fuel pump issnt getting power. where do i look for the fuse and/or relay?
72 Volvo 142E
xmlhack is offline   Reply With Quote
Old 09-06-2019, 07:05 PM   #2
The FI relays are on the right inner fender near the hood hinge. Power for both the main and fuel pump relays comes from the junction block near the battery. Power for the fuel pump goes through a fuse in the small fuse box near the headlight relay on the left inner fender. That fuse may be your problem.
The main relay is activated by a yellow wire that is connected to the (+) side of the coil. The fuel pump relay should run for 1 second when the ignition is turned on.
Old 09-07-2019, 12:02 PM   #3
xmlhack
xmlhack's Avatar
thanks for the tips. i've seen that junction block. it looked broken. i will pull the battery and check that out. My Haynes describes the poles for checking the relays. I've seen the fuse box for the pump. it has a thumb screw on the face. i'll check that too. i hope to be driving it soon.
