Old 09-08-2019, 04:48 PM   #1
2 old for this
Default Chasing a phantom
1990 turbo wagon likes to die. Tow it home and it starts. Poke around and can not find any thing. Next time it died in the car port. Pushed it out for better access and it started . Any ideas?
Old 09-08-2019, 04:57 PM   #2
Fa182
Stage 1
Fa182's Avatar
I'd start at the crank sensor.
Old 09-08-2019, 04:59 PM   #3
iHateVolvoPeople
+1
Also RSR wiring, and fuel pump relay.
Feedback Thread
Current:
93' 244T M47
90' 744 AW70
95' Camry A140E, 254k
99' Camry A140E. 256k
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
90' 745 NA sold
93' 945T in burgundy
91' 745 Regina AW701 turbo (traded for 96 Camry wagon)
93' 245 M47
Old 09-08-2019, 06:35 PM   #4
Do you have a test lamp?
Old 09-09-2019, 08:03 PM   #5
2 old for this
3 or 4 incandescent 2 led. Digital vom analog vom.
Old 09-09-2019, 08:05 PM   #6
2 old for this
It was changed years back but I don’t remember the vendor. Good thought
Old 09-09-2019, 08:09 PM   #7
2 old for this
Good thought on cps.it was changed years ago but don’t remember the vendor
Old 09-09-2019, 08:13 PM   #8
Ignition amp in the left front fender is another cause of random stalling.
You aren't low on fuel are you? A low tank and a bad intank pump also causes this symptom.
Old 09-09-2019, 08:58 PM   #9
Incandescent lamp between coil negative and ground. Blink?
LED lamp to powerstage "input" wire. Blink?
Old 09-10-2019, 12:26 PM   #10
DET17
Reformed SAABaholic
When no starting, have ye spark?
Old 09-14-2019, 08:52 PM   #11
2 old for this
Maybe found it.it looks like one of the pins on the cps got pushed back. This was on the body harness connected.
Old 09-14-2019, 11:32 PM   #12
Good find. I hope that sorted it out.
Old 09-17-2019, 06:36 AM   #13
DET17
Reformed SAABaholic
These connectors on LH2.4 under hood have bit me several times...... anything that is touched needs confirmation, as they certainly weren't designed for 50 on/off cycles like the GM Weatherpack parts.
