Since my P1800 has a 1984 B23F in it I thought I would post it here.
I recently purchased the car, and have been having some fun with it. The stock B20 fuel injected motor had been replaced with the B23F. This was done some time back in 2000, and the install was very clean. But there was some issues when I got it. It had a Weber 32/36 DGV carb on a very nicely made intake manifold. With this it also had the stock fuel injection distributor, with no working vacuum advance. This made the car very doggish on the freeway, especially in 5th gear. In the spirit of wanting to make things go faster I decided I wanted to put quad Mikunis on it. I was told that they would not fit. This made me determined, and instead I fitted much larger dual 45 DCOEs to a Mangoletsi intake manifold. I also installed a 123 ignition distributor so that I can run it on pure mechanical advance.
The car runs like a top, and is quite quick. It sits on a set of 240 turbo wheels, IPD springs, IPD sway bars, and energy suspension full poly kit. The car is in the body shop right now getting the rust fixed in it.
with the single DGV
Upgraded with dual 45 DCOEs
The breather and dipstick had to modified. The dipstick was easy, I just cut the bracket, rotated the stick and re-welded it. The breather I am still not confident about. I cleaned that nightmare of an oil trap out, and stuck a Chevy PCV filter to the top of it. Right now it just vents to air. It hasn't started leaking, or consuming oil.
with the single DGV
