- Dec 25, 2002
- mont, AL
we'll it doesn't bleed over into the other paths so we'll see.
you'll be fine. you'll run into problems elsewhere.
sounds about like what mine should be, didn't find that much gunk and stuff in mine, case looks brand new inside. Though the bit of metallic stuff i found i'm sure has to do with the 3rd gear slip i did have. keep us abreast of the situation. Mine should be tested here in a few weeks. Blocks ready all that's left is a bit of wiring for ms and finishing my cylinder head.
I just hope i didn't drill out the 1-2 and 2-3 shift holes too big. But the tires should be able to take it. Just worried about how the rear end might feel about a shift that harsh.
If I'm following correctly, two of your AW71 rebuilds have now burnt out/failed in a very short time...right?
So...what's causing them to kick the bucket so early? How much boost are you running on the engine, how much power are these boxes being subjected to in order to kill 2 of them in just a couple of months?! Are we talking drag strip launches at 25psi+ with slicks?
I know it's got to be a huge pain in the arse to repeatedly drop transmissions in your driveway, so thanks for the effort thus far. I'm hoping to only have to do it once when the time comes. Working under jack stands FTL.
They can't hack it.. yet. Its not really a matter of boost, the setup made 465rwhp off the nitrous and 500 on
Its after the planatary .once you pull the pump off its after the big drum thats held in by two bolts under the vb. when you pull everything out you will see a shaft i think its the output shaft and it splines into the hub i broke . has violent shifting caused broken hard parts in a aw71 for you yet ?
If you can get an AW71 to hold this kind of power you will be a Volvo wrenching GOD.
