TCornish
- Jul 24, 2015
- Salisbury, England.
Hi all,
Sticking this out here, I'm planning on doing the usual turbo swap to my RHD 240 soon, it'll still be a daily driver for sure however, so not looking for massive horses.
Being in the UK there's an abundance of Cossie bits and bobs about, especially regarding T3 turbos. I've trawled through the threads on here, seems everyone is going for a .48 hotside with a 52/60 compressor. I aimed to go for 15G, but with the options available over here regarding the Ford scene, and upgrade options for T3, I've decided to stick with the latter.
Here's what I'm aiming for so far;
B230FK/FT with;
Most likely brown top or VXR injectors.
012 MAF with the 3" throttle body, modified K-jet manifold for EFI. Being fabricated up soon, just need to TIG the intake flange on.
Either V or A cam
Adjustable pulley
3" exhaust.
Ebay or AutoSiliconeHoses intercooler - the latter fits right in the front with no problems.
It'll have the 5 speed manual M90 gearbox bolted to it as well.. So none of this auto nonsense.
Seeing as it's a daily driver, I wont be requiring much of the top end, as in upwards of 5/6000rpm, so some good low to mid-range/low top end would be ideal. I've heard a few bits about this elusive '50 trim' T3 that's about... But school me more if needed. Will the .48 turbine with say a 52/60 compressor side aid this setup, or am I talking bollocks? What would you recommend?
All advice taken on the chin...!
Tim
B230FK/FT with;
Either V or A cam
Adjustable pulley
3" exhaust.
Tim
