Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello Guest, welcome to the initial stages of our new platform! You can find some additional information about where we are in the process of migrating the board and setting up our new software here
Sounds good, I'll post it up. Can't believe I used to complain about performance parts availability for an '87 MR2... This 122 is a whole different beast. No problem finding used stock parts at least.
I picked up the rustiest wagon in Arizona. The PO decided expanding foam would the best choice to solve the issue; it is less than ideal. Runs like a top as my DD though!
For lowering, I whacked a couple coils off & bent half a coil flat, and I bolted the ball joint to the top-side of the control arms to drop it another inch without loosing the travel. Seems to hold up and handle pretty well.
I also own an amazon that's a little rough around the edges. I will most likely chop the coils to about this (photoshopped) height this summer, unless I can find an ebay coilover kit with longer springs than the honda civic kit.
haha ibcmoore, believe me, i have some very rough spots!
All my window seals were trashed (hence the windows being down) and some rust in the floor pan. Typical 122s!!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
