Old 06-21-2012, 08:04 PM   #1
michal740TI
michal740TI's Avatar
Default Compression test results
Car is 1990 744 Turbo with 260K on the engine.Runs good,but out of curiosity I have checked the compression today and found 115,120,100,120.Good or bad?
I guess its time for rebuild. While I am at it (maybe next month),should I get the head shaved for raising the stock compression ratio or should I leave that and get it only resurfaced? My goal HP is somewhere 250-270HP,so I wonder how much power increase could be achieved by shaving some material off the head alone.I'd like to keep my stock pistons and change only the rings and bearings,seals,etc and get the adjustable cam gear and possibly modify the exhaust system to 3'' one.
Possible?
michal740TI is offline   Reply With Quote
Old 06-21-2012, 08:39 PM   #2
Magnum TE
Broke another B230F+T
Magnum TE's Avatar
Bah, this is turbobricks leave it alone toss a bunch of boost at it and have a 93+ B230 junkyard block waiting when you blow this one up. Build the junkyard block while you try to destroy the 260k block with too much boost.
Go with a stg.3 RSI cam
Do a 3" Downpips and a 3" cat, stock back section isn't all that restrictive. Don't waste time/materials on less than 3"
Port your 90+ exhaust manifold, or get a header
Install a wideband O2
Get some LH2.4 chips
NPR intercooler (you've got the pre 92 top hose intercooler so it's close to drop in)
Larger injectors
19T turbo or T3/T4
Tune it
Should put you close to your goal.
Goldie Bricks - '92 940T : B230F+T MSnS-e...
The Gray Car - '92 940T : stock drive-train DD
I have some cool stuff done to my cars
The Gold Car: Owner since 2001
B230F+T MS1nS-E / Ford T5, 1pc DL
ebay FMIC / Mechman Alternator
T3 60/.63 ATP WG / 63#/hr CFI injectors
Full 3" Turbo to tail / IPD TP Cam
IPD bars / Coilovers
Koni Dampners / Lower Chassis brace
NIW-T3 camber plates / Full poly front end
Full Kaplhenke Rear end
-Torque rods -PH Bar -Subframe
Daily Driver
Magnum TE is offline   Reply With Quote
