Old 11-16-2008, 05:15 PM   #51
carnut1100
carnut1100's Avatar
I think I might have a 240 eggcrate around somewhere...have to have a dig in the shed and see.
Didn't know they were so popular...
1973 164E 1978 244DL 1973 142DL
1979 242 GT 1977 245L van
carnut1100 is offline   Reply With Quote
Old 02-16-2009, 06:12 AM   #52
Fadli85
Fadli85's Avatar
Good choice.
It looks flawless.
Originally Posted by swiftjustice44 View Post
Mind? Heck, it's an honor. Towery's method seems somewhat sturdier, but I didn't want to go the belt route. It's really simple if you have a Dremel and a handful of cut off wheels. Just cut the teeth out of the o.e. grill, cut the mounting tabs off the 89< turbo grill and keep test fitting until it goes in. Towery is right, the 240 frame and grill bend, the 740/760 grill is nearly flat so to make it look right you have to torque the grill in. I found it best to start in the middle where it fit best and work my way to the end. Another angle if you didn't check my build thread.
So finally gave in to swiftjustice's methods, and I have to agree with Redwood, it does look flawless, I didn't have a dremel tool, or any power tools of any kind (pity me) but I do have a mini Hacksaw so I cut the inside of the Black 240 grille, probably from an SE model, I got it for cheap like 10USD so I didn't feel so guilty, haha. Then put the eggcrate insert into the 240 frame held on using self drilling screw and voila, SUCCESS..! I love it more..! much better than the flat & awkward looking 740 grille, it's so nice..! Here are the pics, enjoy..!
Front End shot
Front Quarter shot, look so much better, it sit's flush like stock.
Fadli85 is offline   Reply With Quote
Old 02-16-2009, 06:14 AM   #53
Forg
Forg's Avatar
That looks about a billionty times better than the 740 grille you tried earlier!!
When I'm cruisin' in overdrive ...
Don't have to listen to no run-of-the-mill talk jive.
Shatner: The Colonel is breakdancing ... gimme a break!!
Rollins: Credit terms raised!
Shatner: I can't get behind any of that!
Shatner: I can't get behind so-called singers that can't carry a tune, get paid for talking, how easy is that? Well, maybe I could get behind that ...
Rollins: Well, I can't!!
Forg is offline   Reply With Quote
Old 02-24-2009, 03:25 AM   #54
SlowRide
Cold War Crumple Zones
SlowRide's Avatar
I'm having trouble wrapping my mind around how the eggcrate insert goes into the stock grill...
You cut the slats of the stock grill, then just pushed the eggcrate in?? My brain hurts...
I'll bet it will make total sense when I have both grills in front of me, but until then can someone explain it?
- Justin
1980 242 DL
240 Junk for Sale
Feedback
SlowRide is offline   Reply With Quote
Old 02-24-2009, 06:15 AM   #55
Fadli85
Fadli85's Avatar
Hahaha, sure no problem, You got that right, I cut off all the vertical slats on the stock grille. Then, I removed the 740 eggcrate from it's frame, and trim off it's upper and lower edges, leaving the sides because it will just fill up the stock frame later. The, directly center from the top and bottom of the stock frame, I screw in a self drilling screw from the inside up, so that it would hold the eggcrate exactly in the middle, and at the same time, pushing it outward a little (it needs to because the 740 eggcrate is rather flat). Then, I screw the edges of the eggcrate from the outside in, leaving the screw head just nicely so that it hooks the stock frame from behind. Then you will have the eggcrate position sturdily inside the stock frame.
To finish everything off, I use Araldite quick drying epoxy (it was really quick, 5 minutes tops), and just dab it as you like on the screws against the stock frame so that it would hold permanently. And there you have it, an eggcrate for '86+ front end 240's.
Old 02-24-2009, 08:11 AM   #56
SlowRide
SlowRide's Avatar
Thanks man. That makes perfect sense.
Old 04-20-2009, 09:30 AM   #57
Elvira_745T
Elvira_745T's Avatar
Originally Posted by Fadli85 View Post
Tada! P-chopped!
In order of appearance:
1967 VW Karmann Ghia
1973 Vespa 90 (shhh 135cc)
1986 VW Golf GTI
1992 Volvo 745 Turbo
They all start with a "V" and are European, sweet!
Elvira_745T is offline   Reply With Quote
Old 04-20-2009, 09:39 AM   #58
Fadli85
Fadli85's Avatar
Wow Thanks..! That looks so badass....! all blacked out trim.....So far I only blacked out the headlamp and turnsignal trim, but the rest are still chrome. And I already have chrome lugnuts and hubcaps for the scorpius too..
Old 04-21-2009, 11:41 AM   #59
SlowRide
SlowRide's Avatar
Here is a crappy cell phone pic of mine
Old 04-21-2009, 12:14 PM   #60
Fadli85
Fadli85's Avatar
That's neat...! Well done...!
Old 04-21-2009, 04:08 PM   #61
BRUNOP39
THE FLYMAN VOLVO 245
Default hi
This is my current setup not done yet,,but i guess it looks pretty decent,I think
Bruno
BRUNOP39 is offline   Reply With Quote
Old 04-21-2009, 09:31 PM   #62
Pro Sneaker Peddler
crap unfocused cell phone shot. will post a better one later
Old 04-21-2009, 10:50 PM   #63
Greenhornet95
Greenhornet95's Avatar
DAMN that looks very nice, oh I want the 740 eggcrate so badly now, a local junkyard here sells it for USD 80...!, is it expensive?
Here it is on a 740 front end chopped off...
The one I showed in my post #4 wasn't mine, it was my friends. So basically I still don't have an eggcrate yet.
I will send you 5 US 740 eggcrate grills if you get me the e-code setup off that 740!!!
-Carlo
Volvoless
Greenhornet95 is offline   Reply With Quote
Old 04-22-2009, 04:05 AM   #64
Fadli85
Fadli85's Avatar
I already have it and put it on my car, hmm, interesting deal, but the e-codes are right hand drive, sorry I thought it was LHD earlier.
Bruno nice flat hood grille, how do you space them out? we have plenty of it here, hehehe....
Old 04-22-2009, 12:40 PM   #65
Greenhornet95
I didnt know it made a difference if they were LHD or RHD? maybe the way the wipers lay I suppose...You could get all these sweet USM 7xx egg crates and make some cash selling them to your 7xx buddies over there =D
-Carlo
Old 04-22-2009, 02:22 PM   #66
SlowRide
SlowRide's Avatar
-Carlo
There is a huge difference in the lenses of RHD an LHD lights. Respectively, they point away from the median so as not to blind on coming drivers, if you reverse them, you'll be doing the opposite.
Old 05-31-2018, 07:33 PM   #67
colgate41
colgate41's Avatar
Is there anyway to tell the difference via part numbers or markings, between a 740 egg crate and a 940 egg crate grill?
1991 744 Turbo. Last Volvo left.
colgate41 is offline   Reply With Quote
Old 05-31-2018, 08:21 PM   #68
white855T
It's quite possible they will have a part number which you can cross reference with online volvo parts dealers. Or post a picture of grille.
Buyer/Seller Feedback
Old 05-31-2018, 09:12 PM   #69
swedishK
Design by Beefsma
swedishK's Avatar
shameless plug for grille adapters:
https://forums.tbforums.com/showthread.php?t=338370&
grand luxe touring til i die.
Prof. Dr. Dr. Andrew Schaafsma
...weld the diff, and proceed to everywhere.
swedishK is offline   Reply With Quote
Old 06-01-2018, 09:25 AM   #70
colgate41
colgate41's Avatar
Here are some photos of what I got. Any ideas?
