Lonelydonkey
- May 26, 2014
- British Columbia
Hello,
New to the forum. Can't wait to get started. We have had lots of Volvos in the past from 1960 544 to our latest 1990 740 Regina/Rex Wagon. This 1990 is the first we've had with so many sensors and computer controls. Have played around replacing parts and brought it from a shaky shaking, rough running, gas guzzling disappointment to 11.5 Km per Liter, smooth running, joy to drive vehicle. We have what seems like one last issue that we would like to solve.
On rainy days it will start OK, but you can't touch the accelerator without it just about dying. In fact, it will die if you press the peddle for any more than a second or so. It takes just a minute to warm up and the problem goes away and car runs perfectly. So far, we have replaced the following: MAP, O2, Radio Suppression Relay, IAC, Fuel Pump and Relay, Manifold gasket, Engine Temp Sensor, Various vacuum hoses. Spark plugs and wires (BeckArnley?)
We haven't replaced the distributor cap and rotor. Could that be it?
We would be most appreciative of any help or ideas.
Many thanks in advance
Lonelydonkey
Lonelydonkey
