Sketchysedan
- Feb 20, 2019
I have an ?87 240 turbo that I swapped over to lh2.4. It was running for months with no issues. Went out to start the car the other day and fuel pump did not prime. Was not getting spark either. I tried to check the diagnostic box, but the led would not blink. This made me believe it was an issue with the wiring going to the ecu. I checked all the grounds with a dvom and they are all good. The ecu is getting power. I then thought it could be an issue on the ezk side, so I swapped in a known good power stage and ignition coil, and tried a different crank sensor. I even tried a couple different sets of ecu?s with no luck. Not sure what the next step is in troubleshooting this, let me know if you have any suggestions.
