nohbudi
Jesus Christ...
- Jun 22, 2003
- Toledo, OH
I'm still sad I never got to roll in the oval....
Sweet! You said you took a flat piece of steel and banded it yourself right? Did you bend it first then weld it on or did you bend, weld, bend, weld? Do you have any pics of the finished wheel pre-tire? Awesome work?
Here are some more detailed pics,
Here is the band I rolled, I did it on a tiny slip roll made for sheet metal.
Tacked it together and put it on my friends tire machine to check runout.
Welded on the outside, going to weld the inside tomorrow. I welded it in 3-4 inch strips to try to keep the heat spread around. I also decided to tig this whole wheel, just comes out cleaner.
I don't know what it weighs but I will try to find a scale before I put the tire on.
Well - it's a mystery of life I suppose. Aluminum (at 1/3 the weight of steel) and steel wheels that weigh the same.
There's really no mystery to it. Aluminum may be 1/3 the weight, but it's also got to be at least 3 times as thick to get the same strength out of it. When you compare steel wheels (.060" thick) to a typical cast aluminum wheel (.25" thick or more) it's really no surprise that steel wheels can end up pretty light.
Now, when you start talking about forged wheels, that's an entirely different story. But most aftermarket cast aluminum wheels are not nearly as light as you may think they are, including those 26 pound wheels from IPD.
?" SPUN aluminum wheels" ?
Ah haint never heered o' such a thang; PLEEZ dew advise?
Kin won' dem po boys get's won? Whar?
