Old 06-13-2017, 08:59 PM   #26
Khrrck
Professional Amateur
I think "playing with the airgap" is your best bet. I didn't read that linked thread too much so I didn't see if anyone specified how much gap they added.
I only have a Bentley manual for 240. It says:
Sensor with 12 tooth wheel (12-window): 0.85mm +/- 0.35mm
Sensor with 48 tooth wheel (1992 and later): 0.6mm +0.2mm -0.3mm
Sensor with 96 tooth wheel (1992 and later): 0.6mm +0.13mm -0.25mm
More appropriate might be the specs from a 740 manual. I suspect they are similar.
'87 240 budget wagon.
Old 06-13-2017, 10:24 PM   #27
Can play the blues
You could leave the 48 tooth ring alone and use the sensor/cover matched for it. Then install a 91-93 speedo in your cluster which is matched to a 48 tooth trigger wheel. I think that should work.
1982 242 turbo. 339k miles. Lots of good changes.
1993 245 Classic, 415k miles, enem V15. 5spd. IPD bars and chassis braces. Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
Old 06-13-2017, 11:04 PM   #28
I'm almost at that point. ^^^^.
Old 06-13-2017, 11:15 PM   #29
gross polluter
They see me trollin'
gross polluter's Avatar
I'm almost at that point. ^^^^ I am kicking myself for listening to turbobrickers and trying to cut windows, add shims, etc. I try to do things cleanly and keep the hack work that wastes my time and $ to a minimum.
And yet you claim to be the pro when it comes to diagnosing elementary electrical issues.
Old 06-14-2017, 02:29 AM   #30
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
I / we cut 3 of 4 windows (12 remaining if you will) and just used the single bolt/blade sensor meant for the alum cover.
It read 2?x too fast with the 2 blade sensor and 12 remaining teeth/windows on the tone ring. 2-blade late sensor is this one:
https://www.fcpeuro.com/products/vol...40-960-s90-v90
Installed this one which has the single blade at the exact same depth as the 2 blades if you will (same distance from the (originally) 48 tooth tone wheel (same diameter wheel between 96T and 48T IIRC):
https://www.fcpeuro.com/products/vol...sor-0265001187
More/maybe most? elegant to use the 1991 240 ABS signal converter relay box or similar and do nothing whatever to the sensor/tone ring/cluster, but neatly trimming 3 of 4 teeth/windows and the single blade sensor worked no fuss whatever in the non-abs 240, but required recombining the parts bin a little and is definitely a long way around the block "hack" if you will, but effective depending what tools/junkpile you have on hand.
Haven't messed with washers or the earlier sensor or any of that...
I neatly filed the tone ring so you couldn't really tell it ever had 48 teeth and had no other scratches or whatever. MUCH easier to R&R those if the diff carrier goes in the freezer for a while and tone ring is warmed. Makes reinstall especially nice if the tone ring sits on the wood stove or is heated and carrier is cold. Reduced the chance of possibly damaging it greatly, especially missing 3 of the 4 teeth!
Labscobe
*squirrel
How PSI a stock can support?
Old 06-14-2017, 12:12 PM   #31
Khrrck
Thanks for the part numbers Kjet. Looks like that second sensor is available on ebay for $80-90. May be NLA elsewhere. Sounds like it's boiling down to ZVOLV having the wrong sensor.
Old 06-14-2017, 12:25 PM   #32
Thanks for the links. I really hope the single blade sensor will be my final solution!
Looks like it's also used as a wheel speed sensor. I should be able to score that sensor somewhere in the yard.
I concur that the tone ring gets fragile once it's been cut up. Mine distorted on me when I tried to get it back on, but I saved it without issue.
Over a year now on the G80 I installed myself without any drama. Just some fun in the rain dumping the clutch going into second gear and breaking the back end free on my stock 240.
Old 06-30-2017, 07:31 PM   #33
swedefiend
This was something that I had problems with myself after putting in an m47.
Tone ring and sensor already on differential swapped in from unknown year. Couldn't ever get things 'squared away', LOL.
Decided to go with a driveshaft sensor. Blew the engine up before I ever got around to that...
Something to consider.
Old 06-30-2017, 07:53 PM   #34
Cwazywazy
Cwazywazy's Avatar
Before you do anything, record a 0-60.
