Old 04-14-2017, 12:32 PM   #1
re5pect
Default Garrett T3 (from b204GT) - regeneration or swap?
Hi,
I have b230ft engine with a few mods:
- garret t3 turbo
- 440cc green giants
- custom IC
- 3" MAF
- 3" DP with 2,5" open exhaust.
- stage4 chip
- some more...
My turbo is Garrett T3 from b204gt engine. I need 1,3bar (19psi)of boost.
My garrett needs regeneration. Boost falls from 1,3bar to 0,8bar and the turbocharger has oil leaks...
And now the question. Is that turbocharger worth regeneration?
If it isn't worth it, which turbocharger can I buy?
(I know that Td04hl-19t will be perfect, but to put it I need to change exhaust manifold, DP, oil feed and water feed).
If I buy new turbo, I wanted to put it p&p without many other modifications.
re5pect is offline   Reply With Quote
Old 04-14-2017, 12:34 PM   #2
Pro Sneaker Peddler
Sure it's worth rebuilding. It's also worth upgrading to the ATP Ultimate Wastegate and getting a larger/more modern compressor wheel and housing from a reputablew turbo shop.
Old 04-14-2017, 06:42 PM   #3
re5pect
Thanks
Garrett T3 is comparable with TD04hl-15g/16t/19t? I've no idea how much can I achieve with it.
Any other opinions about this turbo or swap?
Old 04-14-2017, 07:25 PM   #4
Idealgaslaw
Buy a real turbo. Holsets are cheap.
1996 960 - stock
1966 P1800S - garage ornament
1989 244 - dead
Idealgaslaw is offline   Reply With Quote
Old 04-15-2017, 12:29 AM   #5
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Originally Posted by re5pect View Post
Thanks
Not much, move on
'91 744t...it's fast as phuck
Old 04-15-2017, 01:23 AM   #6
JW240
All idiot, no savant
JW240's Avatar
The stock turbo on those has a 60mm od 55 trim compressor wheel in a 0.42a/r housing with integrated CBV. Turbine side is a 0.48 a/r housing with no removable wastegate flange, it is integrated.
With those data you can compare it with other turbos. Size wise I'd say 18t and up is a worthwhile upgrade compared to this b204 unit. In stock form the wastegate is nothing special.
About the low boost, the actuator on those turbos is quite weak. Maybe look into that as well.
240 | 1991 | 326 KKm | B230F+T | Cossie T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12
Old 04-15-2017, 01:29 AM   #7
Wilford Brimley
LOCAL ONLY
On a t3 trim
Old 06-19-2017, 02:19 AM   #8
re5pect
UPDATE
I've ordered new T3 turbo. How much boost can I set with it? 1,3bar is not enough...
Is 1,5bar safe for it?
Old 06-19-2017, 03:32 PM   #9
mark244turbo
mark244turbo's Avatar
Clean the flame trap/oil separator and see if it still leaks oil.
Maybe it's not a turbo problem.
1994 960 B204FT, full options, leather interior (soon to be B234FT)
1991 745 B204GT (Swede Sixteen VT), M46 flywheel/ Diesel-clutch/M90L gearbox, poly bushing, polaris rimms, 23/19 sways.
1986 745 B230FT, MBC@13psi, 302mm V70 brakes, camber mod, poly bushing, 960 braces, 23 mm front sway, MBC@13psi (sold)
1983 244 turbo B21FT/AW71, full RUSToration/new rear (USA-import)
mark244turbo is offline   Reply With Quote
Old 06-19-2017, 03:37 PM   #10
mark244turbo
There's hardly enough room for a stock t3 turbo. Good luck fitting a holset on a b204gt manifold.
Old 06-25-2017, 09:34 PM   #11
nomad1221
Which T3 did you get?
nomad1221 is offline   Reply With Quote
Old 06-28-2017, 05:19 PM   #12
mark244turbo
I have the stock b204gt t3 turbo.
