Old 03-14-2016, 08:15 PM   #176
cwdodson88
A stock C, D or K cam are relatively cheap, it is doable on almost any cam, some just take it better than others. If you have the option a D or K would be best stock grinds IMO. I am currently running a mystery cam, most likely a C cam... works fine. SU HIF carbs are easily modified for blow through.
The Build Thread
SVEA - PUSHROD TURBO!
Old 03-15-2016, 10:20 AM   #177
sspony
sspony's Avatar
So you think a whole different setup with the SU's is better then that accel kit?
Potential, potential, potential....
65' 122s (daily driver)
82' 242 dl
88' 740 "rally wagon"
sspony is offline   Reply With Quote
Old 03-15-2016, 10:41 AM   #178
cwdodson88
not necessarily, but it will be easier to intercool if needed since you can run an air to air intercooler. With that accell kit you would need to run an air to liquid cooler because the cores are much more compact and you can essentially build it into the manifold. Another alternative is water meth injection in order to cool the charge. If your climate sees a lot of 100* days it might be worth while, but at such a low boost level I dont think you will have any problems with the Accell kit.
Old 03-15-2016, 01:45 PM   #179
Hotdoggin
Hotdoggin's Avatar
So wait, water/meth is only a bandaid for an intercooler in this situation?
1978 245DL - B21 Penta carb powered!
1982 244T - Crushed
1983 245DL - SOLD
1984 244DL - Crushed
1984 245DL - Sitting in someone's yard
1991 740SE - girlfriend's car
2008 S60 2.5T - Money drainer
Hotdoggin is offline   Reply With Quote
Old 03-15-2016, 02:25 PM   #180
cwdodson88
Pretty much.. With the kit he has it is taking air/fuel and sucking it out of a carb, compressing it in the turbo and blowing the mix into the intake you really cant put a traditional air to air after the compressor or you just end up storing fuel in the intake plumbing. Due to the short amount of piping a small air to liquid IC could be used in this case since it isnt as big of a storage house for the air fuel mix. Using watermeth would just be a bandaid, but probably a very effective one due to the short piping shot, and lack of space for a liquid heat exchange in the mix.
Old 03-15-2016, 03:39 PM   #181
Hotdoggin
Hotdoggin's Avatar
In what way would you control the injection in this situation? If you're cooling the charge air, would you have to have a constant injection, or a pulsed injection? Watermeth on carbs is kinda weird to me.
Old 03-15-2016, 03:42 PM   #182
cwdodson88
Probably constant injection with a Hobbs switch to come on at a set boost level.
Old 06-10-2016, 07:44 AM   #183
sspony
sspony's Avatar
Bump, time to revive the thread. Due to life I was unable to acquire the kit in March. However I recently was able to contact the owner and will be purchasing it on Tuesday. Plans have changed, as the 122 will no longer be the target vehicle. I'm thinking either an 82' 242 with 302/t5 swap or a 140 series with b20 and t-5 swap. Although realistically it would be best to boost something with forged internals.
Goals: Fun, Unique, Custom/tinker project, no time deadline, budget build, equal to or less then 7.5 second 0-60.
Lets hear some ideas/thoughts on the matter. Whatever it goes in will not be a show piece so modifications to the tunnel/inner fenders/core support are acceptable.
Old 06-14-2016, 05:46 PM   #184
sspony
sspony's Avatar
I now have the turbo kit in my possession. Pics to follow!
Old 06-14-2016, 06:07 PM   #185
cwdodson88
B20 t5 - my vote! I wanna see a BJB20! Looks to me (from my own testing) it will meet all your goals - Fun, check... Unique-yep... Custom/tinker,lots of that... No time deadline, Yippee... Budget, whats that? 0-60, how about ~6 seconds @ 7psi
Old 06-15-2016, 08:26 AM   #186
sspony
sspony's Avatar
So the question is, what piston/crank/rod should I go with. B20 with b21 turbo Pistons? Or do you think a stock b20 bottom end could handle a good bit of hp/boost?
Old 06-15-2016, 10:56 AM   #187
Tfrasca
Tfrasca's Avatar
Do you need a 140 chassis to accept this motor you're planning?
Old 06-15-2016, 11:38 AM   #188
cwdodson88
Either way, with the B21 stuff, you will need to open up the combustion chambers a fair amount to bring your CR down to a manageable level. I'm running 9.5:1 compression, F head with what appeared to be .010 taken off, .030 oversize flat top pistons, stock rods (forged) stock crank (forged 6 bolt) and so far its happy at 12 psi. Hell it was happy at 7 psi, and ran faster than my b18/20 hybrid (8.2:1 CR) at 15 psi. But I changed a few things... Different cam, some timing adjustments, new injectors, decked the block for a piston to head clearance of .030, removed some sharp edges in the combustion chamber.
Old 06-15-2016, 08:49 PM   #189
sspony
sspony's Avatar
Sorry, that would prob be a bit over budget to ship.
Old 06-15-2016, 08:52 PM   #190
sspony
sspony's Avatar
So a b20 6-bolt crank and rods will do. Will the stock Pistons hold up? I'm thinking a 140 would be the best because of the room under the hood. Not keen on cutting my 122 inner fenders.
Old 06-15-2016, 09:09 PM   #191
cwdodson88
The rods, well they're lighter than m rods, may hold up... Only time will tell. Pistons, forged would be better, but I think they'd be fine with a little boost. So far the b18 ones (other than blowing rings) held up fine, no cracks or damage on the tops, lands may be a touch out of spec, but I'm not certain yet.
Old 06-15-2016, 09:11 PM   #192
cwdodson88
Oh, and I didn't have to cut the inner fenders, and only removed the core support because I didn't want to remake the manifold again.
Old 06-15-2016, 09:29 PM   #193
sspony
sspony's Avatar
Remember I'm building a Frankenstein carb turbo motor though. I have a feeling the intake and carb may take some space. I'd really like to use a very small low CFM 4 barrel.
In terms of boost I believe the ch by 350 guys said they we're getting 7-9psi out of this setup in the stock configuration.
Old 06-15-2016, 10:37 PM   #194
cwdodson88
Yeah, but I still have a ton of room between the fi intake and inner fender. The 140 bay is way bigger at the front, but still narrows at runner 3 quite a bit, so I'm just saying not to rule out putting it on a 122
Old 06-16-2016, 07:48 AM   #195
sspony
sspony's Avatar
Ok, we'll keep the option on the table.
So let's go over a bit of the support system for this setup. We had mentioned water meth injection previously. Being that its a standard carb mount I should be able to use a carb spacer for the water meth injection correct? In fact the kit may have come with one. I'm not sure if it's simply a cooled spacer or an injection spacer. I'll check when I get the pics.
Edit* it appears to be a water meth injection spacer.
In regards to timing, should I consider a system like this? Since I'm not running fuel injection I don't plan to run a standalone system. (https://www.msdperformance.com/produ...rip/parts/6462)
Finally what type of adjustable boost controlled fpr should I be looking into?
Any other support systems I'm not thinking of?
Old 06-16-2016, 08:11 AM   #196
sspony
sspony's Avatar
Finally got some pics.
It would appear the plenum with "accel" written on it has coolant ports. I guess that's my inter cooler haha.
Still have not inspected the turbo. May require a rebuild for all I know.
Particularly excited about this. Someone was already running water meth with this setup from the looks of it.
Old 06-16-2016, 10:44 AM   #197
cwdodson88
Cool! I still think that if you can make an adapter for a weber/cannon manifold that will bolt that on there having the turbo downpipe routed either forward towards the radiator or from passenger side>Driver side it would fit on a 122. And you might even be able to put the turbo by the battery box (moving the battery to the trunk) and have the whole thing back there with minimal cutting.
And since the cast piece between the carb/intake dealie and the turbo are removable, you could just use standard intercooler piping to connect them, that way you have more flexibility for where you put the turbo.
Setting that plate up for water injection looks like it would be pretty easy, just need a hobbs switch, solenoid/check valve, and a bottle/pump (windshield washer?)
Old 06-16-2016, 05:02 PM   #198
sspony
sspony's Avatar
I could have an adapter made for the Webber intake. Only problem would be height. That, plus a carb spacer for meth injection, plus the odd accel adapter, plus a carb, plus and air filter is going to get pretty tall. Only one way to find out.
Anyone have a cheap Webber intake? Haha
Old 06-16-2016, 05:06 PM   #199
cwdodson88
I could have an adapter made for the Webber intake. Only problem would be height. That, plus a carb spacer for meth injection, plus the odd accel adapter, plus a carb, plus and air filter is going to get pretty tall. What about a custom mount designed to bolt to the twin s/u intake? Just brainstorming.
Yeah, that might do it. Another thought (dont try this at home kids) would be to separate the carb mount on the Accel kit from the bit that bolts to the intake, and blow into an FI intake manifold, or your SU manifold with a small Y bit attached in there.
Old 06-16-2016, 06:50 PM   #200
sspony
sspony's Avatar
Not my pic, but I suddenly want this coming out the hood of a 140 wagon haha
