Old 10-03-2016, 04:47 PM   #26
Lord_Athlon
Sf1k Kryptonite
Lord_Athlon's Avatar
http://www.wolferacecraft.com/pinionangle.aspx
Originally Posted by rvolvor
Old 10-03-2016, 04:48 PM   #27
mopar318
mopar318's Avatar
Maybe you tire **** is rubbing because you have a stock panhard bar and are lowered 8". It sounds like your geometry is all out of whack and your u joints are hammering themselves apart.
Lsd doesn't lock the wheels. That's why it is called a limited slip.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 10-03-2016, 05:07 PM   #28
Fretka
Fretka's Avatar
Originally Posted by Lord_Athlon View Post
I honestly forgot about this kind of movement when lowering dead axle. Will look into it, thank you.
Mexipoku - custom low budget suspension solutions
Fretka is offline   Reply With Quote
Old 10-03-2016, 06:04 PM   #29
Benjam83
Moar Volvos than Queen B
This...very much this...
Ben
12 WRX Hatchback
10 Subaru Outback
93 245 m47
Benjam83 is offline   Reply With Quote
Old 10-03-2016, 06:05 PM   #30
doucheNozzle
doucheNozzle's Avatar
Don't try and tell him what he already knows.
'99 V70 NAA - So Slow
'04 V70 T5A - Feels Fast
Old 10-03-2016, 06:09 PM   #31
chris gilmour
to me, it still sounds like worn bushings. you said yourself, it all worked good at the start of the season.
with the car on the ground, in first gear. lay on the ground near the rear wheel, and rock the car back and forth, look to see how much movement you're seeing with axle roll. you might be getting the wheel hop from the bushings loading up, and letting go as you lose, and gain traction. Like i said earlier, i went with heim joints in my toque rods to get rid of any of that wrap and i the axle doesn't load up at all anymore. i think between bad torque rod bushings or bad main axle bushings thats where you're getting your hop.
im not gonna dwell on whats proper and whats not, but a pan hard bar simply positions your axle laterally.. so i can't see it affecting vertical performance.
chris gilmour is offline   Reply With Quote
Old 10-03-2016, 09:49 PM   #32
Texas240
Prius Owner
Texas240's Avatar
This is getting good. There has been plenty of advice in this thread from more then a few people who have done a various amount of little to huge suspension mods that have all worked.
When it comes to a welded diff you are now changing the rate that each tire spins. In a open diff or a locker the inside and outside tires will spin at different speeds when turning. That welded diff is great for going in straight lines but once you start turning that welded diff becomes not so happy.
So suck up your inflated balls and listen or you going to be figuring this out on your own and will probably never figure it out.
Now back to my pooooooopcooooooorn
93 245 LS Engine Swap Project
Old 10-03-2016, 10:03 PM   #33
Mueller
Mueller's Avatar
Maybe you need more power!
Old 10-03-2016, 10:38 PM   #34
runslikeapenguin
Did you forget about it when I brought it up last page and you said "yeah yeah I know"
runslikeapenguin is offline   Reply With Quote
Old 10-03-2016, 10:44 PM   #35
Texas240
Prius Owner
Texas240's Avatar
No no no, yeah yeah i know
Old 10-03-2016, 11:36 PM   #36
Vincent Gagnon
Vincent Gagnon's Avatar
since LSD locks both wheels 100% when on throttle.
Not necessarly.
Here's a hint: LIMITED slip differential.
Eh, okay, one more time.
because can't afford Kalphenke coilovers for 1,4$
Why would anyone do that?
and aftermarket LSD for 500$.
**** that!
I'll just leave this here
http://www.rallyanarchy.com/phorum/read.php?5,83276
Old 10-04-2016, 03:00 AM   #37
runslikeapenguin
I honestly forgot about the speed changes a drive line will make when the angles are screwed up.
https://youtu.be/gmV4qwLfOMY
Old 10-04-2016, 07:28 AM   #38
poulrais
poulrais's Avatar
That is f*cking good stuff there...
1990, Volvo 740 16v +T
Old 10-04-2016, 07:42 AM   #39
centason
CNT-FAI
centason's Avatar
No rear squat, no launch, no hook, just hop hop hop
Member: TBCCS
"Democracy is also a form of worship. It is the worship of Jackals by Jackasses." -H. L. Mencken
Just remember this guys. Im related to cocaine.
Any forums history.
Old 10-04-2016, 01:33 PM   #40
runslikeapenguin
I keep getting an image of this happening.
https://youtu.be/Qxc7VrXMD1k
Old 10-06-2016, 07:21 PM   #41
haltechsupra
haltechsupra's Avatar
I noticed ( and this may have no relation to your problem) On my car (93 945 t)with 235x35x19 REAR tires, that the tire pressure effected wheel hop really bad. I had a semi bald tire on the passenger side(new tire on drivers rear) on a 3 inch drop, when i put 40 psi in both tires everything was fine, 50 psi in semi bald tire on passenger side, mad wheel hop. Tires are rated at 55psi max. Like I said, just something to think about Since I did not read a mention of this. Cure was to replace tire or lower air pressure to 40/45 psi. Some times the fix is not so complicated.
If you had the audacity , to doubt my veracity, and even to insinuate, that I scrupulously prevaricate ,such an insignificant question. Then you must hallucinate before you comprehend.
haltechsupra is offline   Reply With Quote
Old 10-06-2016, 09:34 PM   #42
LC4CARL
Aero challenged
LC4CARL's Avatar
Wheel hop on a non-leaf spring car is caused by the compression of the bushings with resulting sudden release of the energy?
On my old '79 Mustang, Lakewood made a traction bar for the Fox body. That was long ago, but it did the trick.
Built-not-bought: PDXdl Resto-Mod.
#carlfeague on IG.
Old 10-06-2016, 10:58 PM   #43
odinthewanderer
Not sure what it is worth, but this is my vote. you may need to get more aggressive with trying to rock the car, use your e brake as well as first.
dead bushings are guaranteed undampened play, don't waste your time on anything else until you know they are good.
I would bet if the panhard bushing is bad, then the lower axle bushings are toast (unless they were already replaced)
If you have not done them, now is a good time to do them.
Stiffer springs and shocks will exacerbate any issue with the bushings.
The following advice has already been given, but i will reiterate it.
When i first got into these cars, i put full poly in the back, which is a mistake unless you just want to drift and do burn outs, made my car worthless in snow and rain.
Stay with QUALITY rubber, or go with heim joints.
To me, poly was ok on the the panhard rod though, and seemed OK on the front trailing arm bushing, and front torque rod bushings, but 100% does not belong in the trailing arm/lower axles bushing imo.
+1 on tire pressure as well.
i have been a bit out of the game for a while but i think kaplan has heims for the lower axle to trailing arm bushing, someone else may too.
ask me what kind of stupid i am today?
92 240 wagon, aw70, (driver) new mexico clean!
92 745tic mild stuff done(driver) for sale?
92 245 modified (sold)
77 244 dl (almost done with resto... on hiatus)
91 245 m47, rust bucket winter beater (driver)
90 234 aw70, side swiped winter beater (driver)
72 ford highboy, farm rig
95 lt1 caprice woody (family truckster)
odinthewanderer is offline   Reply With Quote
Old 10-07-2016, 10:15 AM   #44
http://www.kaplhenke.com/collections...rical-bearings
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 10-07-2016, 11:27 AM   #45
culberro
culberro's Avatar
Originally Posted by blkaplan View Post
Here are a few more options besides the stuff from Ben, which is totally fine and will work. I'm just all for more options.
There's Sellholm Tuning in Sweden, ~$255: http://www.sellholmshop.se/bakaxel-b...0-uniball.html
You could also fab your own for cheap if you have the skills. Get the parts from PolyPerformance or someplace similar.
Old 10-07-2016, 11:46 AM   #46
Vincent Gagnon
'91 944,
Wrong bushing guys.
Old 10-07-2016, 12:12 PM   #47
Originally Posted by Vincent Gagnon View Post
Wrong bushing guys.
doh, my bad!!!
Yea for a 940 I would definitely say its in the torque rod bushings. Those things suck.
Old 10-07-2016, 12:59 PM   #48
culberro
culberro's Avatar
Doh! I just figured you had a "proper" car
Old 10-07-2016, 02:45 PM   #49
babbit bearings
Actually this will help.
babbit bearings is offline   Reply With Quote
Old 10-07-2016, 03:09 PM   #50
benski
Post
How so?
