Old 10-07-2016, 04:23 PM   #51
John V, outside agitator
Originally Posted by Vincent Gagnon View Post
Wrong bushing guys.
Picky picky picky..You think your so smrat, eh?
Since when has that stopped anybody from pontificating?
You pay attention to all that snow ahead.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 10-12-2016, 05:10 PM   #52
Fretka
Fretka's Avatar
Thanks for looking into more then rear axle placement.
Here's an update:
Installed adjustable panhard today, no changes. As mentioned before - new shock absorbers, springs have a preload so that won't be a game changer anymore. Ofcourse it's good news now that my axle at least is in the middle of the car, less stress for driveshaft for sure.
Took it for a spin - think it depends on tarmac, but more or less I have the same vibrations then before. More vibrations when slipping wheels on straight line, less when going sideways. Most turns felt okay, but some (which were bassicly the same speed and angle) had a TERRIBLE wheel hop. Let it go when a hop like that appeared.
But when turning slowly with welded diff you can feel that the rear axle is hopping already, kind of hard to describe this in english, maybe I will take a video of it.
Anyways, from now on I'm even more confident that those are worn bushings, have to install poly ones for sure. (Thanks to everyone who yelled that it must be rear axle angle. I still can't see how it would affect so bad wheel hop)
I will keep this updated, but since I want IRS for back I might not do a thing to this one aswell. Will see.
By the way - is the 960 IRS axle plug and play fit or cutting and welding is done?
Thanks in advance.
Mexipoku - custom low budget suspension solutions
Fretka is offline   Reply With Quote
Old 10-12-2016, 06:07 PM   #53
odinthewanderer
...man, i thought you were talking about a 240 as well....
ask me what kind of stupid i am today?
92 240 wagon, aw70, (driver) new mexico clean!
92 745tic mild stuff done(driver) for sale?
92 245 modified (sold)
77 244 dl (almost done with resto... on hiatus)
91 245 m47, rust bucket winter beater (driver)
90 234 aw70, side swiped winter beater (driver)
72 ford highboy, farm rig
95 lt1 caprice woody (family truckster)
odinthewanderer is offline   Reply With Quote
Old 10-13-2016, 12:13 AM   #54
Vincent Gagnon
Vincent Gagnon's Avatar
Thanks in advance.
Take a look at this.
http://forums.turbobricks.com/showthread.php?t=316000
Old 10-13-2016, 10:54 AM   #55
Fretka
Fretka's Avatar
Thank you.
And yes, more power is coming, since it has EDEM cam, 16t, LS2 injectors, only MS2 is waiting in corner to be installed ha.
Old 10-13-2016, 06:54 PM   #56
LC4CARL
Aero challenged
LC4CARL's Avatar
Originally Posted by odinthewanderer View Post
When i first got into these cars, i put full poly in the back, which is a mistake unless you just want to drift and do burn outs, made my car worthless in snow and rain.
I've been thinking about this, but can't figure it out.
Off-road we like tall sidewalls and loose suspensions for articulation and therefore traction (keeping the tires on the ground). But on the street, the priority shifts to a more controlled ride.
Is the poly-bushed rear end one step too far, from a compliance stand point, that wet traction is compromised?
Built-not-bought: PDXdl Resto-Mod.
#carlfeague on IG.
Old 10-13-2016, 07:02 PM   #57
LC4CARL
Aero challenged
LC4CARL's Avatar
Just found this on Ben's site:
In order to get proper articulation and to not over constrain the rear axle Volvo put voids into the rubber bushings, while this works to allow the axle to rotate back and forth with travel it makes the bushing weak and prone to ripping and destruction. Our competitors offer a polyurethane bushing to replace this Volvo bushing. While this bushing is much more durable it is also very poorly designed product that is not well suited to is installed application. The polyurethane bushings will deal with vertical travel reasonably well but they do not respond to body roll or one wheel bumps correctly. They do not pivot in the body roll direction! What this does is it causes the rear suspension to bind. When the rear suspension binds it lifts the rear wheel off the ground and reduces grip levels, reducing traction accelerating out of corners, and causing a shift in handling balance to over steer.
Very interesting.
Old 10-14-2016, 12:18 AM   #58
doucheNozzle
doucheNozzle's Avatar
Very interesting.
Old news.
'99 V70 NAA - So Slow
'04 V70 T5A - Feels Fast
Old 10-14-2016, 11:40 AM   #59
Texas240
Prius Owner
Texas240's Avatar
Originally Posted by doucheNozzle View Post
Old news.
Still not funny
93 245 LS Engine Swap Project
Old 10-15-2016, 01:38 AM   #60
LC4CARL
Aero challenged
LC4CARL's Avatar
Old news.
It's always great to be among friends sharing a common interest.
Old 05-21-2017, 05:01 PM   #61
Fretka
Fretka's Avatar
In case someone's wondering, bushings was the problem.
Old 05-23-2017, 04:03 AM   #62
Otto Mattik
Otto Mattik's Avatar
Originally Posted by mopar318 View Post
Maybe you tire **** is rubbing because you have a stock panhard bar and are lowered 8". It sounds like your geometry is all out of whack and your u joints are hammering themselves apart.
Lsd doesn't lock the wheels. That's why it is called a limited slip.
Several threads about (homemade) adjustable panhard bars
Originally posted by Jack
______________________
Old 05-27-2017, 11:44 AM   #63
Otto Mattik
https://losangeles.craigslist.org/sf...142570091.html
Yes I know it's not close, but some good photos in the ad
Old 05-29-2017, 09:26 AM   #64
lookforjoe
lookforjoe's Avatar
Great that you found resolution, and that you posted back to not leave the thread hanging as often happens. Which bushings specifically fixed the issue? Any pics of the hammered ones?
My XR July2013 - 446AWHP @ 8K rpm
Old 06-10-2017, 09:51 PM   #65
Fretka
Fretka's Avatar
To be honest, old bushings did not look that bad. The ones on the main axle were pretty bad, others seemed fine to me! Replaced all of them together, so can't really tell which ones exactly caused it to hop so badly.
Old 06-12-2017, 01:25 PM   #66
Benjam83
Moar Volvos than Queen B
Likely a tolerance stack-up issue. A tired bushing with some play here...a tired bushing with some play there...
If you end up changing out 3 or 4 pairs of bushings, all of that play in the respective bushings will add up...
All new bushings feel so nice....it probably almost drives as good as new...almost.
Ben
12 WRX Hatchback
10 Subaru Outback
93 245 m47
Benjam83 is offline   Reply With Quote
Old 11-06-2017, 04:16 PM   #67
Fretka
Fretka's Avatar
Sadly have to come back to this thread. Pretty annoying wheel hop has appeared lately. Was driving semi-slicks all around and hop appeared. Swapped them for regular street tyres since old ones wore out and it remained the same.
I wouldn't bother if the hop would appear only when losing traction on straight line, but it breaks and cracks badly when turning sharply with welded diff (when parking, for example). I will check all the bolts and nuts since I haven't done that since poly install. Don't think that shock absorbers could go bad so fast aswell. Will check all of the mounting spots on floor aswell, because that cracking on tight turns makes me cringe and think that my floor has cracked somewhere.
Will update this soon
Old 11-07-2017, 09:17 AM   #68
Disco Inferno
Disco Inferno's Avatar
Replace the welded diff with an LSD
Originally Posted by badvlvo View Post
Oh look, a tire review on TB. In true TB fashion it's about used tires. Used Chinese tires.
Duuuuddee.....weed snot a drug
____caligamerbong___--''"
Originally Posted by coonmanx View Post
I'm going with Windows 9.
Disco Inferno is offline   Reply With Quote
Old 11-07-2017, 09:45 AM   #69
Louis95
Louis95's Avatar
Eh, okay, one more time.
Yes, I admit that first thing I need is adjustable panhard. Think I mentioned before that that's what I'm going to do next.
I guess the questions where stupid enough to get stupid answers.
I'll update this when the wheel hop will be gone, just in case someone here drives welded diff and custom springs, because can't afford Kalphenke coilovers for 1,4$ and aftermarket LSD for 500$.
if there is any play in the panhard you will have hop, if your diff is not center you will have hop, if you're diff is welded you will have hop. if you have a stock panhard being that low your diff is probably like 2 inches to the side, also it no longer points perfectly, straight this will mess up driveshaft angle, and cause hop.
had same thing on my 745, IPD panhard, fixed. but it will always be there around tight corners.
Dreaming of turbo sounds.
Insta: WallrusVB / #shwagan
Feedback: http://forums.turbobricks.com/showthread.php?t=337302
Louis95 is offline   Reply With Quote
Old 11-07-2017, 03:37 PM   #70
Fretka
Fretka's Avatar
Panhard is adjustable and diff is centered. I know how welded differential reacts and this is way too much since I have experience with it in different ****ty missiles, even with stock bushings on different kinds of suspension setups. Have to admit, that not that experienced with Volvo's dead axles.
I will take it to proper alignment place at my friends and check if there are any subframe (or call it floor in this case, whatever you like) cracks, because those cracking hopping sounds are pretty evil if you ask me.
There are not many decent LSD options on budget if you ask me. What was it, Quaife who supports this? Anyone else? Something about 600eur I suppose, right? Might consider it to next season though ..
Old 11-07-2017, 03:38 PM   #71
mck1117
https://www.summitracing.com/ga/part...a588/overview/
mck1117 is offline   Reply With Quote
Old 11-11-2017, 07:19 PM   #72
Fretka
Fretka's Avatar
Did a little inspection today:
  • Did not find any cracks in metal all around the axle
  • Seems like there is a little play in one of panhard bars heim joints
  • No bolt or nut is loose on the axle
  • There is a little in-out play in both axle bearings, but it has been there for ages, so I still don't want to put the blame on those
Guess I'll start with new heim joints in panhard bar :?
Old 11-11-2017, 09:05 PM   #73
Gussie
'91 944, dead 1041 axle, B200FT turbo-back 70mm pipe, 16t turbo, 0,8bar boost, welded diff I would say that car is lowered about 120mm by original height, so rear axle is offset really badly.
I've done many cars with welded diffs, custom spring, shock absorber setups and it hasn't been so terrible like this. Allthough none of those cars had dead axle.
I honestly forgot about this kind of movement when lowering dead axle. Will look into it, thank you.
I've never seen anyone call this sort of assembly a dead axle. Instead, it's routinely called a live axle. Cultural thing? Sarcasm?
A video would be great.
Gussie is online now   Reply With Quote
Old 11-12-2017, 05:05 AM   #74
Fretka
Fretka's Avatar
Hmm, thanks for correcting. After a bit of googling around, you sound right and I've been wrong the whole time. Probably because I live in freaking post soviet country and a lot of people can't understand **** in english
