Old 03-01-2017, 10:25 AM   #1
IWantedAnAE86
Default Good junkyard turbo for b230ft
Hi guys! I'm planning a build for an '89 740 turbo. And I'm trying to make the the most power that I can on a budget, the build would consist of an '89 b230ft (may upgrade to 13mm rods later if necessary), ported and polished 530 head, V cam, bigger intercooler with necessary piping, and a 3" turbo back exhaust. Now where I'm stuck is what turbo I should choose as the I know the stock turbo is quiet anemic, but I can't afford to buy something brand new to slap in, so I would much prefer something I could pull from a junkyard/pick-n-pull. I would like something that would get me to atleast the 250hp range, but I would love to venture into the 300s. I live in Canada if that helps, should I pull a turbo from something like a Ford 7.3 turbo diesel or would that just be way too big? Sorry if I sound a bit turbo clueless, I've always been an N/A guy. Thank you in advance for your help!
IWantedAnAE86 is offline   Reply With Quote
Old 03-01-2017, 10:47 AM   #2
JPS
when you can make your own header, you could try a TD05 16G from a mitsubitsi EVO
good for a quick spool and 300hp. only problem its not a t3 flange. so its not easy bolt on.
JPS is offline   Reply With Quote
Old 03-01-2017, 11:00 AM   #3
Powder>Paint
15G from an 850 once clocked is capable of 250ish.
Powder>Paint is offline   Reply With Quote
Old 03-01-2017, 11:06 AM   #4
propav8r
F*ck Edgar
propav8r's Avatar
I've got a Holset HE351CW I'd sell for cheap.
If you're pulling a stock diesel turbo in the yard, a good rule of thumb is to double the displacement of the gas motor you want to boost, and look for a stock diesel turbo in that range. The HE351CW is from a 5.9 Cummins and is a little on the large side of that rule of thumb, but people have great results with them.
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 03-01-2017, 11:32 AM   #5
IWantedAnAE86
What would you guys says is the best direct bolt on replacement?
Old 03-01-2017, 02:27 PM   #6
Fumomike
Fumomike's Avatar
15g hotside 19t coldside like mine . Or 15g all around.
Im stuck around 200+ hp because of blown turbo or something of the sort. Gl going past 250. Most people are happy around there but i think you start hitting the limitation of the b230ft tractor motor and ecu. I think its perfect for a budget though.
Fumomike is offline   Reply With Quote
Old 03-01-2017, 03:12 PM   #7
Powder>Paint
15G at 16psi w brown tops is a lot of smiles per mile.
Old 03-01-2017, 04:02 PM   #8
Powder>Paint
Or marry a Ford 60 trim compressor to a volvo garrett hotside. Just did this, and it should flow to the 300-325hp range. Any more that that and it really starts to tax the efficiency of the 60 trim T3.
Thats when you pull an S200 schwitzer airwerks off the shelf...
Old 03-01-2017, 04:13 PM   #9
cosbySweater
cosbySweater's Avatar
Svo 60/63. /Thread
Old 03-01-2017, 07:32 PM   #10
IWantedAnAE86
I like the sound of this, I think I might throw in a 15g for now and get a 19t when I'm willing to do some work on the bottom end.
Old 06-10-2017, 11:39 AM   #11
240240
I crush everything!
240240's Avatar
sounds like a solid plan.
I know what I have, and you can buy it here
Old 06-13-2017, 09:59 AM   #12
240240
I crush everything!
240240's Avatar
or just get a Walmart turbo
