Old 05-29-2017, 09:24 PM   #1
mr42ndstblvd
Default mechanical fan vs electric?? with proof?
https://www.youtube.com/watch?v=ZXdLgaFXZzs
so these guys tested mechanical fans on a dyno engine mule.
and there worst fan stole about 30 hp
30 hp is crazy! considering a stock 240 only comes with 120 ish stock.
id honestly like to dyno a redblock with some different fans and see what the deal is.
i can safley say on my next car i will be running electric fans from a ford crown vic.
same fans my buddy uses on his 1500 hp foxbody. if it keeps that cool it will do wonders for my next redblock.
how do you guys feel about these dyno results??
mr42ndstblvd is offline   Reply With Quote
Old 05-29-2017, 09:44 PM   #2
apachechef
Burnt Sierra Madre
Learn about fan clutches
Dammit, Lummert.
Old 05-29-2017, 09:45 PM   #3
mr42ndstblvd
they used a fan with a clutch and it was the worst one in the video
Old 05-29-2017, 09:50 PM   #4
TestPoint
TestPoint's Avatar
But the electrical fans and controllers are cheap do exactly what they are supposed to do.
Read through my experience with fan and controller.
http://forums.turbobricks.com/showpo...4&postcount=14
Ford V8 Conversion Manual -
Old 05-29-2017, 09:54 PM   #5
TurboDenny
Why am I here?
They should have dyno'd with an electric fan drawing 30 amps just to be fair.
'90 245 Daily
Instagram: @itstotesdenny
Old 05-29-2017, 10:10 PM   #6
apachechef
Burnt Sierra Madre
watch again
Old 05-29-2017, 10:36 PM   #7
gsellstr
gsellstr's Avatar
I was gonna say, the clutch was the best in the video, fixed was the worst. Clutch setup was only 7hp or so I thought.
RIP
74 144 B20
90 745Ti
Old 05-29-2017, 11:57 PM   #8
thismachine13
Clutch fan ate 7 lb/ft of torque and 14 hp.
Hopefully I'll have my efan finished in a couple weeks and A cam installed. Between those two tweeks it will feel like completely different car!
Old 05-30-2017, 12:09 AM   #9
BR1CKHOUS3
Issa Brick
BR1CKHOUS3's Avatar
If you go electric...
The most common defense of clutch fans is that they are reliable and easy to service/replace on our Volvos. Just depends on what you want the car to do.
We don't do it for the glory.
Only two ways to find out...18 bolts or 18psi
BR1CKHOUS3 is online now   Reply With Quote
Old 05-30-2017, 07:36 AM   #10
M.H. Yount
M.H. Yount's Avatar
30A @ 12V = .48HP. Say you're getting closer to 14V at the fan -- .56HP. You have some inefficiency in the fan motor and the alternator/belt drive --- but even in the worst case it doesn't take more than a HP or two even with larger electric fans. And, of course, that's only when they're running at full tilt. With variable speed controllers, you're often not even pulling that much when they're running --- I have a 'speed gauge' on mine and it rarely runs at more than 1/3 speed with the A/C off.
Moral of the story -- the switch to electric pretty much eliminates all of the parasitic losses associated with the mechanical fan. Losses from rotating the weight and aero losses that increase significantly with engine speed/air moved. There's a reason that most engines have had electric cooling fans for quite some time. VW broke the ground when they turned the engine sideways in the Rabbit/Golf back in 74/5. Eventually, even the longitudinal folk followed.
Old 05-30-2017, 09:17 AM   #11
JohnLane
As we are pondering losses due to the fan....
Driving down the road even at 30 mph...
If the fan is Yelling it is time to increase the size of the radiator.
The fan should only be needed in traffic or at idle.
I use the thermostatic clutched fan in the rallycar with a 'Be Cool' aluminum radiator. Have heard the fan a few times on stages but temperature has never climbed.
Clutch fan is simple and reliable + it came from the factory with one.
Old 05-30-2017, 10:05 AM   #12
mikep
The MP
mikep's Avatar
I read a similar test a long time ago.
7hp was for an unlocked clutch fan. Way higher loss when that bi-metal spring heats up and locks the hub.
I dunno, I mean, sometimes...Sometimes I miss Smokey.
Originally Posted by churd9 View Post
You can’t indicate a president while in office
Originally Posted by golgothan
I do declare sir, you're trotting out a horse your saddle can not fit.
Old 05-30-2017, 03:51 PM   #13
James10952001
Don't forget that the alternator is only about 50% efficient, and that's before you factor in mechanical losses which are actually quite high for a V-belt. The electric fan is still probably more efficient than the mechanical fan but I doubt the difference is dramatic. Whether driven directly by the engine or electrically the energy to spin the fan still has to come from the engine.
I would love to see a dyno comparison though.
James10952001 is offline   Reply With Quote
Old 05-30-2017, 04:04 PM   #14
Cwazywazy
Cwazywazy's Avatar
Also factor in that the electric fan doesn't run all the time. Only sometimes at idle and if you're cruising on the highway it probably never needs to come on.
Old 05-30-2017, 04:10 PM   #15
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
I can check when I get this light blue 240 sorted out, but unless the clutch is locked up I wouldn't expect it to be more than a couple hp between spinning the fan or not spinning the fan (I'm not going to swap an e-fan on just to see, I'll just remove the fan and run it like that for a pull or two)
Megasquirt Tuning!
Old 05-30-2017, 04:14 PM   #16
James10952001
The mechanical fan doesn't run all the time either, it freewheels with the clutch disengaged. I have seen fan clutches bind up though, and I've seen them refuse to engage at all as well.
Old 05-30-2017, 04:15 PM   #17
thismachine13
This thread is hilarious.
You really think that an efan is going to suck anywhere near 14hp and 7lb/ft of torque? Who is the supplier for what y'all are smokin'?
Old 05-30-2017, 04:24 PM   #18
Broke4speed
Broke4speed's Avatar
Personally, I couldn't stand the sound of that awful clutched fan on my B21A, so I ditched it as soon as I was able.
1984 B21T (formerly A), AW71(minus L).
Broke4speed is online now   Reply With Quote
Old 05-30-2017, 04:39 PM   #19
turbotankshane
this. biggest reason I've ever switched to an efan on anything I've owned
That and I can't leave well enough alone
Old 05-30-2017, 04:55 PM   #20
James10952001
Who said it would?
I only suggested that the mechanical fan in a Volvo likely doesn't pull anywhere near 14HP, it's tiny compared to the mechanical fan in a lot of V6 and V8 domestic cars, and the energy required to spin the electric fan is not free. I have no data to compare but I doubt the difference is huge.
The noise thing has made me consider switching to an electric fan though. The mechanical fan really roars after sitting at a light in warm weather.
Old 05-30-2017, 05:39 PM   #21
apachechef
Burnt Sierra Madre
Originally Posted by James10952001 View Post
Who said it would?
No one said it was free, you just wanted to hear your own voice.
Old 05-30-2017, 05:40 PM   #22
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
THIS.
-Stephen
#mclovethesenuts
Old 05-30-2017, 06:02 PM   #23
culberro
culberro's Avatar
This paper really drives home how inefficient alternators are: http://www.delcoremy.com/documents/h...ite-paper.aspx
Key take-away: design cvt to run the alternator @ 2500rpm at all times.
Old 05-30-2017, 09:36 PM   #24
TurboDenny
Why am I here?
I wasn't arguing that an electric fan wasn't more efficient, just simply wanted to see a dyno comparison.
Old 05-30-2017, 10:45 PM   #25
M.H. Yount
M.H. Yount's Avatar
Understood td - point is, with a bit of math, you can see that the load from the electric fan is relatively insignificant. With mech, you've got aero load when clutch is engaged (they never completely frewheel) and you've got the rotational load of spinning the clutch/fan assembly that's a function of how much it weighs. Perhaps linuxman will get us some numbers on the Volvo-specific unit.
