Old 06-10-2017, 05:55 AM   #51
IWantedAnAE86
Originally Posted by VB242 View Post
This is what I have, it's got a large boss that makes it easy to reclock. I've broken a few engines, transmission, and rear ends with it. I didn't buy it from Walmart but got it from eBay for $50 less.
https://www.walmart.com/ip/91-92-93-...ange/170511878
Hahaha wow, since when did walmart start selling turbos?!?? I may just end up going that route, that's a very decent price. Does it bolt up to the stock turbo manifold, or I think the stock manifold need a little machining to run a t3 flange iirc?
IWantedAnAE86 is offline   Reply With Quote
Old 06-10-2017, 08:25 AM   #52
These Pipes Are Clean!!
I have mine on a 90+ manifold, yes it requires machining flat. I've been on quite the journey with it, I recently Microsquirted the car with much larger injectors only to find the stock fuel system needs an upgrade to max this thing out. I've blown 2 head gaskets this year trying to tune it.
Old 06-10-2017, 11:21 PM   #53
doucheNozzle
doucheNozzle's Avatar
It's a marketplace.
'99 V70 NAA - So Slow
'04 V70 T5A - Feels Fast
Old 06-11-2017, 03:18 AM   #54
IWantedAnAE86
Originally Posted by doucheNozzle View Post
It's a marketplace.
They barely sell sh*t up here in Canada
Old 06-11-2017, 03:21 AM   #55
IWantedAnAE86
Wow! How much power do you think you're putting to the wheels right now? What do you think you'll make after a fuel system upgrade? By the ways how's the quality of that turbo?
Old 06-11-2017, 06:43 AM   #56
doucheNozzle
K.
Old 06-11-2017, 07:12 AM   #57
mark244turbo
mark244turbo's Avatar
An '88 b230ft has 9 mm conrods. It might not be the most suitable engine for a 19T or holset, unless you replace the 9mm conrods with h-beams.
1994 960 B204FT, full options, leather interior (soon to be B234FT)
1991 745 B204GT (Swede Sixteen VT), M46 flywheel/ Diesel-clutch/M90L gearbox, poly bushing, polaris rimms, 23/19 sways.
1986 745 B230FT, MBC@13psi, 302mm V70 brakes, camber mod, poly bushing, 960 braces, 23 mm front sway, MBC@13psi (sold)
1983 244 turbo B21FT/AW71, full RUSToration/new rear (USA-import)
mark244turbo is offline   Reply With Quote
Old 06-11-2017, 07:22 AM   #58
mark244turbo
Originally Posted by gross polluter View Post
The terms K cam and "hot" don't really go together.
Good luck making power past 5600 rpm with that cam.
Some people seem to have no problem making 502 hp @ 6600 rpm with a k-cam
Old 06-11-2017, 09:56 AM   #59
Only 215hp 235 ft lbs, I haven't had any problems with the turbo, I'm shooting for around 300. I was running on lh2.2 for a long time maxing out some brown top injectors.
Old 06-11-2017, 12:31 PM   #60
gross polluter
They see me trollin'
gross polluter's Avatar
Cool. Where's yours?
Old 06-12-2017, 06:21 AM   #61
IWantedAnAE86
He doesn't need one, already shown you that you're wrong, by 1000rpm.
Old 06-12-2017, 06:24 AM   #62
IWantedAnAE86
Come on man get the work done and post us some results! I may be following in your footsteps very soon! 300 should be easily attainable, I've seen them rated up to 400whp (not sure how accurate that is).
Old 06-12-2017, 06:28 AM   #63
IWantedAnAE86
Yeah I was originally planning on throwing in some 13mm rods, but I read a post from another user who made 600hp+ on some cheap Chinese h beams. I may end up going that route as they're extremely affordable (full set for <$150) and if they can hold up to that much power, even tho I don't ever plan on going over 400whp, then why the hell not?
Old 06-12-2017, 08:21 AM   #64
doucheNozzle
Where'd you get 400whp?
Old 06-12-2017, 10:04 AM   #65
gross polluter
So an isolated example of a specific build all of the sudden represents the majority of crap builds on this forum?
I was going to say you must be a special kind of stupid, but then I recall you asking the forum what dimension shim to use when you swap cams. Goes without saying.
Old 06-12-2017, 10:09 AM   #66
240240
I crush everything!
240240's Avatar
Sweedish speedshop tune=/=Tbroke homebrew tune.
I know what I have, and you can buy it here
Old 06-12-2017, 10:12 AM   #67
gross polluter
All the 200whp hoopties on here thinking their stock cracked turbo manifolds are gods gift to mankind because one guy over the sea made 500bhp on one.
It's no wonder nobody puts their crap on a dyno around here. The truth would hurt them too much.
Old 06-12-2017, 10:13 AM   #68
centason
CNT-FAI
centason's Avatar
except in Sweden the exact same setup will make 600hp. Here, you'll barely pull 300. We don't have the magic fart dust.
Member: TBCCS
"Democracy is also a form of worship. It is the worship of Jackals by Jackasses." -H. L. Mencken
Just remember this guys. Im related to cocaine.
Any forums history.
Old 06-12-2017, 07:50 PM   #69
IWantedAnAE86
You were still wrong tho
Old 06-12-2017, 07:52 PM   #70
IWantedAnAE86
Edit: replied to the wrong message.
400whp was if I ever went crazy and decided to slap on a big laggy turbo.
Old 06-12-2017, 08:04 PM   #71
James10952001
By 400whp you're gonna have to build a very stout motor and upgrade virtually every other part of the drivetrain. IMO if you want 400whp buy a modern sports car.
James10952001 is offline   Reply With Quote
Old 06-12-2017, 08:10 PM   #72
gross polluter
You will never make over 230whp on a redblock. Ever.
Old 06-12-2017, 08:53 PM   #73
IWantedAnAE86
That's why I said it'll happen if I ever go crazy
Old 06-12-2017, 08:55 PM   #74
IWantedAnAE86
Yeah, if I ever follow any of your advice
Old 06-12-2017, 09:06 PM   #75
gross polluter
Except I've made over 400hp on a redblock. You haven't. You don't even know how to swap cams. You don't have the aptitude to do it, which is why you and many others have to resort to taking credit for other people's work.
