Old 06-09-2017, 12:18 PM   #26
JohnMc
JohnMc's Avatar
Don't get butt-hurt but can you tell me why you'd leave a gauge installed on something like the fuel pressure that you set and forget? I have done a lotta carb set ups and maybe I'm just dumb--many say that is the case and I tend to agree with them--but what good is a gauge under a closed hood? Or a guage left in line..one more cut, 2 more clamps, one more potential thing to bounce around and break.?
I am confuse.
'Cause it looks cool?
I have a gauge on the turbo wagon, MS already told me that the fuel system was running out of flow (an increasingly steep top edge end of the fuel map) but the fuel gauge showed it in a much more direct manner. On the dyno, as the boost rose, so did the fuel pressure, until it hit full boost, at which point it started oscillating and dropping.
Of course, it's a mechanical gauge, under the hood, really not of much use when driving around, if I'm running short of fuel then the WB O2 gauge will let me know.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 06-09-2017, 01:07 PM   #27
MikeJr.
Gloss Boss
MikeJr.'s Avatar
I don't.
It violates everything we know about electric pumps...
They like to push..
they don't like heat.
should be low as possible.
1,2, 3 ....just-a like-a dat.
I suppose it could have been worse...they could have mounted it even high and attached to exhaust manifold..
Ok good to know. I want to say I already knew that and maybe forgot.
Old 06-09-2017, 01:25 PM   #28
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Old 06-09-2017, 01:29 PM   #29
MikeJr.
Gloss Boss
MikeJr.'s Avatar
I have another question. Does it matter how the supply line going into the carbs is oriented? I see a lot of them that the line goes into the T on the first carb, then over to the second, and that's what the kit instructions say to do, but does that starve the second carb of fuel? Should it go into a T fitting separate from the first carb, like between the two, then equally divide into both carbs? Like in hiperfautos pic
And this is the way I see most configured, and the way they say to do it in the kit
Old 06-09-2017, 01:56 PM   #30
JohnMc
JohnMc's Avatar
It doesn't really matter, unless you're running out of fuel (or flow rate), at which point one of the carbs might go dry before the other.
Within the range of acceptable pressures, the carb really won't care about 6 psi vs 4 psi vs 3 psi. The way it meters fuel is utterly independent of the fuel pressure going into them. The float valves control how much fuel goes into the carb (fills to bowls to a certain specific level) and the bowls themselves are vented to outside air so the jets are not affected by incoming fuel pressure at all.
As long as it's not too high - which can force the float valves open and flood the carb (gas will come out the bowl vent and into the air cleaner, down onto the alternator and exhaust manifold, woot) or too low, in which case there might not be enough fuel flow to keep up with the carbs on extended WOT.
Old 06-09-2017, 02:10 PM   #31
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Oh ok makes sense.
Here is another example I found (non-Volvo)
I like this set up. I was thinking about using common plenum to a fresh air supply behind the grille somewhere.
Old 06-09-2017, 02:14 PM   #32
zdriver123
zdriver123's Avatar
Originally Posted by MikeJr. View Post
Oh ok makes sense.
It looks very close to the box that Pipercross makes.
http://www.burtonpower.com/parts-by-...?appl_carb=540
zdriver123 is offline   Reply With Quote
Old 06-09-2017, 02:27 PM   #33
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Yeah I like the Pipercross one better. Looks like it would have better clearance.
Old 06-09-2017, 02:30 PM   #34
The other one is made by Borla.
https://www.borlainduction.com/air-boxes.html
Old 06-09-2017, 02:47 PM   #35
1971Gold142
1971Gold142's Avatar
I am confuse.
I can take constructive criticism so no prob and a good question. The Filter King doesn't have any way of showing what fuel pressure you are running so I had to have a guage to set it. I could remove it now that I have it set but I like it and also lets me know if I have a fuel supply issue down the road...
71' 142E
1971Gold142 is offline   Reply With Quote
Old 06-09-2017, 02:47 PM   #36
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Very nice
Old 06-09-2017, 03:04 PM   #37
Borla bought TWM Induction a few years ago. They used to make very nice stuff including 3/8" stainless steel linkage for DCOEs that Pierce Manifolds now carries, except for a neat shaft mounted return spring setup. Now I have to call Borla and talk to the former owner of TWM to get them.
Old 06-09-2017, 03:15 PM   #38
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Those are nice. How much do they run?
Old 06-09-2017, 03:17 PM   #39
MikeJr.
Gloss Boss
MikeJr.'s Avatar
A little off topic, but I came across this as I was image surfing
Anybody wanna by a brand new set of weber DCOE 45s?
Old 06-09-2017, 04:23 PM   #40
The 3/8" SS linkage kits are ~$105 and the return spring kit is another $48. The car pictured is an 1800E, so a bottom mount cable linkage kit was also required to the tune of ~$45 as well as a custom throttle cable made from teflon lined braided steel hose and reusable end fittings which was then covered in fire sleeve.
Edit:
The car pictured is a '69 that was converted to cable linkage.
Old 06-09-2017, 09:15 PM   #41
Hotdoggin
Hotdoggin's Avatar
This makes me feel in adult, mature ways. What a sick thing to make. Jesus.
1978 245DL - B21 Penta carb powered!
1982 244T - Crushed
1983 245DL - SOLD
1984 244DL - Crushed
1984 245DL - Sitting in someone's yard
1991 740SE - girlfriend's car
2008 S60 2.5T - Money drainer
Hotdoggin is offline   Reply With Quote
Old 06-09-2017, 10:46 PM   #42
bongo
if you have a return line, or are willing to run one try something like these guys make http://pmocarb.com/
bongo is offline   Reply With Quote
Old 06-09-2017, 11:46 PM   #43
matt b
Found a guy that is running a Carter electric fuel pump with a Weber 38DGAS. He said it runs great with that pump. I like how he mounted it in the stock location. Looks to be a 6-8 psi pump. Also it looks like you could use AN fittings if you wanted
http://www.jegs.com/i/Carter/180/P4600HP/10002/-1
They also have a 4-6 psi pump that may also work.
http://www.jegs.com/i/Carter/180/P40...W1GBoCjzHw_wcB
And they also sell a kit
http://www.jegs.com/i/Carter/180/P4070K/10002/-1
I had an identical set up. It overpowered the carbs, as John mentioned, the location wasn't great (even though it did look cool) and the pump is REALLY loud. Obnoxiously loud.
Old 06-10-2017, 10:05 AM   #44
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Good to know
I think I'm just going to go with what John v and Jared recommended.
Old 06-10-2017, 01:27 PM   #45
matt b
http://www.jenvey.co.uk/products2/tw...mm-pair-tbpxxi
And with the British pound dropping against the dollar, that's just $500 for the pair. Grab some green tops, some minor odds and ends and you have a sweet looking EFI set up for less than $800.
Old 06-10-2017, 01:46 PM   #46
Shifted
C&M '17 Survivor
Shifted's Avatar
Those are damn nice...
Originally Posted by ME II View Post
Without mistakes there is no learning.
"Ego is the anesthesia that deadens the pain of stupidity" - Rick Rigsby
Shifted is offline   Reply With Quote
Old 08-04-2017, 08:31 AM   #47
MikeJr.
Gloss Boss
MikeJr.'s Avatar
I got one of the Facet pumps from NAPA, and I'm trying to figure out a place to put it. I haven't crawled under the car yet and looked, but I've been looking at some pictures online, and I'm thinking about mounting it here...
What do you guys think? It'd be slightly higher than the outlet coming out of the tank.
Old 08-04-2017, 08:44 AM   #48
JohnMc
JohnMc's Avatar
I pondered DCOE throttle bodies for the PV long and hard... then I ended up getting a 245 and doing fuel injectioney stuffs with that instead.
Old 08-04-2017, 01:06 PM   #49
That's close to where I mounted the Facet pump on this 1800. I used rivnuts since there's no access to the back side of that panel. It's close, but there is no contact with the suspension bits.
Old 08-04-2017, 03:36 PM   #50
MikeJr.
Gloss Boss
MikeJr.'s Avatar
That's perfect man! Thank you!
