Old 06-12-2017, 10:20 AM   #1
760brick90
760brick90's Avatar
Default Issues after accumulator mod AW71L
Just finished an accumulator mod on my AW71L and under WOT or close to it, it does not like to shift into 2nd and will not shift into 3rd unless i completely let off. Kickdown is adjusted Loose as a Goose. When refilling the transmission I slightly overfilled it. Can this cause a shifting issue?
90 765 Now dead but living in other TB'r cars
94 964 Why the f*ck did I buy this? Now junked
79 242 Sold
86 744 GLE DD
91 945se (got a wagon again! :D)
760brick90 is offline   Reply With Quote
Old 06-13-2017, 11:09 AM   #2
760brick90
760brick90's Avatar
Update, killed the damn thing
Old 06-13-2017, 11:38 AM   #3
J_Jones
J_Jones's Avatar
Why did you leave the kickdown cable "Loose as a Goose"? Were you trying to kill it with low line pressure?
Old 06-13-2017, 12:40 PM   #4
760brick90
760brick90's Avatar
Kickdown was adjusted normally but still had the same issue. Transmission had 250k, guessing by accidentally dumping the torque converter fluid and having to put new fluid in is what probably killed it. Was able to pick up another aw71l with 120k.
Old 06-13-2017, 07:04 PM   #5
DET17
Reformed SAABaholic
Set the shift cable to OE specs, not by heresay. Pounding my AW71 with the aforementioned mod. Zero issues in 20K miles.
Old 06-13-2017, 08:20 PM   #6
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
its worth noting that if you wait until you notice problems to do the mod, you've waited too long.
Megasquirt Tuning!
Old 06-13-2017, 10:59 PM   #7
turbotankshane
You should have had plenty of time to take a look at your kickdown cable while you were doing the accumulator mod
Old 06-14-2017, 01:21 AM   #8
tintintin
+1. Incorrectly set kickdown cable will often ruin an AT.
Old 06-14-2017, 07:58 AM   #9
760brick90
760brick90's Avatar
Kickdown was adjusted as normal from the beginning and the transmission still would not shift into 3rd unless I completely let off. Trans had NO issues before the mod. I guess it was on the edge if its life cycle and not re-using the old fluid sent it the rest of the way.
Old 06-16-2017, 03:53 PM   #10
wagonfan00
#tiltyplategang
I bought a 130k aw71L and am having the same issues....I'm not driving the car more than a test drive until I resolve it
Current: 1988 745Ti 248k (BC Coilovers, Kalphenke Adj. panhard bar, MBC @ 13psi, custom intake, Hydras) 2002 V70 NA M56 170k (M66 style singlemass flywheel and S60R clutch kit, a lotta poly, BC coilovers, Kaplhenke solid subframe mounts, R brakes and pegs)
Past: 2008 Mini Cooper S Clubman R55 (Stock) 1997 855 T5 300k
wagonfan00 is offline   Reply With Quote
Old 06-16-2017, 04:26 PM   #11
jerryc
jerryc's Avatar
Not clear, did you do the mod or just the trans swap?
What's the female equivalent to a dick pic? twat shot?
There isn't one because dudes aren't grossed out by unsolicited vaginas.
jerryc is offline   Reply With Quote
Old 06-16-2017, 07:59 PM   #12
InTheWhite
InTheWhite's Avatar
I have notised that just a tiny adjust at the cickdown cable do a lot for the character of the gear shift.
I tighten my cabel a bit when I tuned the engine to about 190hk and it shifts gear firmly but not kicking in them. Think this will save the AW71 from slipping clutches and a certain death.
Old 06-17-2017, 11:42 AM   #13
wagonfan00
#tiltyplategang
I did the mod before putting the trans in
Old 06-18-2017, 07:34 PM   #14
760brick90
760brick90's Avatar
Just put in a low mile AW71L and did another accumulator mod. Kickdown was adjusted as spec and she shifts SO much better. At WOT she shifts right at 5900k, barks 2nd with some nice tires and so much nicer to drive. I guess my old trans was done before I even modded it. I also shimmed the accumulators the same size at the springs (no play) and love it
Old 06-19-2017, 09:51 AM   #15
linuxman51
linuxman51's Avatar
cool. grab a seal kit and some high energy frictions and steels and rebuild the old one stronger
Old 06-19-2017, 04:48 PM   #16
Ryan_R
Where are you guys buying AW71 consumables?
Thanks!
-Ryan
Athens, OH
1987 245
1989 245 GL
1989 745 GLE
1991 745 --Regina powered B234F!
1995 945T -- Mildly modded
https://people.ohio.edu/ridgely/e-code.htm
Ryan_R is offline   Reply With Quote
