Old 06-14-2017, 04:11 PM   #1
Uncleknucklez's Avatar
Default IPD torque rods with rubber bushings
Anybody put rubber bushings into IPD rods? Don't really wan't or need hard af poly in there, but would like adjustability.
Are the poly bushings in the rods the same OD?
1986 245
1980 242 Turbo
Old 06-15-2017, 10:53 PM   #2
Volvo244GLE's Avatar
No, the poly bushings in the IPD arms are a considerably smaller overall diameter than stock bushings. Off the top of my head the polly bushings have an OD of 2" and ID of 1". You may be able to find rubber bushings in that size but they would be solid rubber and hence still not flex like the stock rubber bushings do.
244GLE Project - The fun daily driver. Rebuilt B23, ported 405, 37.5 exh. valves, BMW oil squirter's, MS2e, VX3 cam, King Springs, Bilstein HD's, upper+lower chassis braces, 26mm Falcon front sway bar, 21+19=24mm rear sway bar, SAAS bucket seats, hi flow rear muffler, almost every factory option.
164 Project - The impulse buy
242GT Project - who likes rust?
Volvo244GLE is offline   Reply With Quote
Old 06-17-2017, 02:28 PM   #3
Hoggster's Avatar
It would probably be easier (and cheaper) to mod stock control arms to be adjustable. You just need to get a turnbuckle from Pegasus or somewhere and cut and weld it in.
I don't know what size you need, but something like this: https://www.pegasusautoracing.com/pr...?Product=SJ080
Hoggster is offline   Reply With Quote
