Old 06-15-2017, 03:30 PM   #1
wagonfan00
#tiltyplategang
Default Accumulator shims too long?
Would the effect of this problem be making me lift off the gas to shift...everything else in the trans seems perfectly fine...it is the only mod ive done to it and so far that seems to make the most sense like the accumulators don't lift enough....but the shims are 1/8" or so shorter than the spring...should i make them shorter?
Current: 1988 745Ti 248k (BC Coilovers, Kalphenke Adj. panhard bar, MBC @ 13psi, custom intake, Hydras) 2002 V70 NA M56 170k (M66 style singlemass flywheel and S60R clutch kit, a lotta poly, BC coilovers, Kaplhenke solid subframe mounts, R brakes and pegs)
Past: 2008 Mini Cooper S Clubman R55 (Stock) 1997 855 T5 300k
wagonfan00 is offline   Reply With Quote
Old 06-15-2017, 03:38 PM   #2
slowmoose
plz bro i hav raygun :(
slowmoose's Avatar
Lift to shift? Kickdown cable adjustment? Someone else will chime in.
91 944T Tropic Green 174K - RIP
91 244M Tropic Green (again) 357K - Sold
88 S10 Tahoe not Tropic Green who cares - Sold
91 945T 264K Black - Sold :/
i own an old crown vic now ;( brb
slowmoose is offline   Reply With Quote
Old 06-15-2017, 03:38 PM   #3
wagonfan00
#tiltyplategang
Kick down cable is loose...forgot to mention that...
Old 06-15-2017, 03:56 PM   #4
J_Jones
J_Jones's Avatar
Why? There's your issue
Old 06-15-2017, 06:05 PM   #5
Broke4speed
Broke4speed's Avatar
You could shim the accumulators solid, it should still shift on time.
1984 B21T (formerly A), AW71(minus L).
Old 06-16-2017, 07:01 AM   #6
wagonfan00
#tiltyplategang
Not really...if i disconnect the cable the car still won't shift unless my foot comes off the throttle....When I did the accumulators the valve body gasket broke so I separated it and replaced the gasket with the Toyota PN as I couldn't find the Volvo PN. I may separate the body and remove the gasket...maybe they aren't exactly the same
Old 06-16-2017, 07:26 AM   #7
J_Jones
J_Jones's Avatar
Before you go tearing into the transmission, why not set your kickdown cable as directed in the manuals and then report back. I wish the best to your clutches after getting beat on with low line pressure, probably already toast.
Old 06-16-2017, 07:58 AM   #8
wagonfan00
#tiltyplategang
I haven't been driving the car for that reason. And when the cable is set to spec I still have the same problem. The low line pressure was used to test to confirm it wasn't the cable.
