Old 06-18-2017, 01:40 PM   #1
Default Vacuum hose on Chrysler ignition (Ezk ? )
I converted my 87 240 to 117 ezk a while back, I'm not deleting the box from the engine bay for my b230ft swap. There is a little vacuum hose on the Chrysler module, what should I do with it?
VolvoEmpire is offline   Reply With Quote
Old 06-19-2017, 02:06 AM   #2
gross polluter
They see me trollin'
gross polluter's Avatar
Plug the hose where the ignition box used to be, or at the source.
If you're not removing the old box, just leave it plugged in there. No big deal.
Or if you're swapping, don't worry about it. Doesn't matter.
Old 06-19-2017, 11:29 AM   #3
Cwazywazy's Avatar
Get yourself one of these:
