Old 12-29-2019, 05:56 PM   #2676
LC4CARL
Aero challenged
LC4CARL's Avatar
New speakers sound great. Maybe I should ditch the spare tire for a sub-woofer cabinet...
@PDXvolvo on IG
Life begins at 10PSI.
Old 12-29-2019, 07:06 PM   #2677
MrBrown
MrBrown's Avatar
Yesssss!!!
GhettoFab build thrizzie
Old 01-03-2020, 11:25 AM   #2678
LC4CARL
Aero challenged
LC4CARL's Avatar
Happy new year!
We have a weekend trip to Leavenworth (+/- 300 miles one-way) planned in a few weeks. Looking forward to it. Hope to see snow.
Then the suspension conversion starts. We have, front: STS housings, Saab inserts, BNE camber plates and SAI correctors. And rear: BNE mounts, IPD panhard rod.
I should probably add bump stops to the front. And the BNE hybrid arms are still outstanding. The IPD units are on sale so I will likely grab a set of those so I can put some miles on the set up before Davis.
What do I need to know about pinion angle?
Old 01-03-2020, 12:14 PM   #2679
Looking good! If you can, getting that bne brake line bracket would make your life easier down the line.
Old 01-03-2020, 01:42 PM   #2680
LC4CARL
Aero challenged
LC4CARL's Avatar
Sort of related: I thought I saw something about converting brakes to a conventional single line set up. Good idea or not-so-much?
Old 01-03-2020, 02:50 PM   #2681
Nope, it's best not to mess with that unless you have the whole system thought out.
Old 01-04-2020, 11:05 PM   #2682
122power
dude
122power's Avatar
I think it would make the car a lot more fun. The M47 is rather agricultural.
‘19 is suspension drop, ‘20 maybe wheels and tires, ‘21 maybe T5.
I’ve got a spare bell housing.
driveshaft with a deeworks adapter needs to be 47" fyi, for t5. Gives you about 1" to 1.25 of slip travel. The mustang is too short.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 01-04-2020, 11:10 PM   #2683
Vol242vo
Keep it clean...
Vol242vo's Avatar
Purdy parts Carl.
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 01-05-2020, 05:02 PM   #2684
LC4CARL
Aero challenged
LC4CARL's Avatar
Noted! Thanks boss.
Old 01-05-2020, 05:03 PM   #2685
LC4CARL
Aero challenged
LC4CARL's Avatar
Originally Posted by Vol242vo View Post
Purdy parts Carl.
Thx! We should hook up at the Leavenworth Drive this summer. Too many VW's there...
Old 01-05-2020, 11:19 PM   #2686
Vol242vo
Keep it clean...
Vol242vo's Avatar
Haha I’d be all for it, we go to Leavenworth pretty often. Best brats on earth, and yes very German over yonder.
Old 01-09-2020, 11:46 PM   #2687
LC4CARL
Aero challenged
LC4CARL's Avatar
Found somebody to pull the broken studs from the spare turbo so I can fit the big waste gate. He’ll also do the 3” down pipe. Pretty excited.
Is the late model manifold worth the trouble? It’s now or never.
Old 01-12-2020, 11:04 PM   #2688
LC4CARL
Aero challenged
LC4CARL's Avatar
Pulling broken studs from the turbo was a fail. Now I have a door stop and a WG for sale.
Picked up this to set up the pinion angle.
Old 01-12-2020, 11:05 PM   #2689
LC4CARL
Aero challenged
LC4CARL's Avatar
This is how we roll...
Old 01-14-2020, 01:43 AM   #2690
LC4CARL
Aero challenged
LC4CARL's Avatar
It may not look like much, but this $100 wheel feels awesome! The steering feels terrific.
Old 01-14-2020, 01:49 AM   #2691
LC4CARL
Aero challenged
LC4CARL's Avatar
Ordered some bump stops and brake line brackets from BNE for the front. Grabbed some IPD rods to tie me over until the BNE hybrid arms arrive. February we install a years worth of parts. That gives me two months until Davis to sort it out.
Old 01-14-2020, 10:15 AM   #2692
Vol242vo
Keep it clean...
Vol242vo's Avatar
Like a boss...
Old 01-26-2020, 05:32 PM   #2693
LC4CARL
Aero challenged
LC4CARL's Avatar
Vancouver to Leavenworth via Yakima on Friday. Home via Snoqualmie Pass today. Car is running great.
Old 01-27-2020, 10:42 PM   #2694
Vol242vo
Keep it clean...
Vol242vo's Avatar
That’s awesome Carl! Hope you had a good time and made it back safe!
Old 01-29-2020, 12:22 AM   #2695
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx boss. She ran great.
Old 01-29-2020, 12:32 AM   #2696
LC4CARL
Aero challenged
LC4CARL's Avatar
And so it begins.
Old 01-30-2020, 12:20 AM   #2697
LC4CARL
Aero challenged
LC4CARL's Avatar
I can’t believe that this is actually happening.
Old 01-30-2020, 01:20 AM   #2698
Old 01-31-2020, 07:29 AM   #2699
Quin
ಠ_ಠ
would you look at that.
Old 01-31-2020, 10:35 AM   #2700
Vol242vo
Keep it clean...
Vol242vo's Avatar
Just look at it...
