Old 04-05-2015, 05:25 PM   #1
PromiseRing
Banned
Default Strut Bearing Failing?
Mods please move to maintenance and non performance.
1993 244, 140,000 miles.
I've developed this low speed clunky vibration over bumps from the front end of my car. It's noticeable on the left side. Upon jacking it up, all control arm bushings seem in-tact and without play. I tightened the crossmember bolts very tight as well. Ball joints were replaced a year or so ago, but with cheap parts so I'm not sure on the quality. I know I need a passenger side outer tie rod as well.
While in the air if i hit the 12 o'clock position on the tire it makes a vibrating noise similar to the one I hear on bumps. If I compress the spring by hand and hit the tire, the noise almost goes away. Is this a sign of a failing strut bearing? The right side of the car made no noise when I hit the tire.
Old 04-05-2015, 07:01 PM   #2
PromiseRing
Banned
Don't wheel bearings rarely fail in the front on these?
Old 04-05-2015, 07:11 PM   #3
brickyard92
Regular Contributor
brickyard92's Avatar
Check your brake pads to see if the spring retainer is on.Sometime its the brake pads rattling.
brickyard92 is offline   Reply With Quote
Old 04-05-2015, 07:11 PM   #4
towerymt
the real Towery
towerymt's Avatar
Strut gland nut tight?
If you pop the cap off the strut mount and wedge your finger between the nut and the opening in the strut mount, then bounce your weight on the fender, you might be able to feel movement of the nut indicating either it's loose or the bearing has play. Just a thought, I've done that with camber plates when trying to identify an audible clunk. Sometimes I've found the nut to be slightly loose...mark nut & shaft with a felt tip pen and blip the nut tight with an impact and see if the line moves.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Old 04-05-2015, 07:16 PM   #5
PromiseRing
Banned
Before I made this thread I ran the gland nut down with an impact. It did move a little bit but that's normal with 300+ ft/lbs I assume. The noise still persists even after tightening that nut.
Old 04-05-2015, 07:43 PM   #6
cleanflametrap
cleanflametrap's Avatar
Strictly by listening to your video I would pop the cap off of the spindle, not the strut mount, pull the cotter pin and give the spindle nut a right hand turn.
-Art
Old 04-05-2015, 07:53 PM   #7
PromiseRing
Banned
I plead ignorance
Are you saying pull the wheel off, pop the cap off that exposes the nut where the wheel bearing is, and tighten it down?
Old 04-05-2015, 08:02 PM   #8
smokeyfan1000
Guest
wheel brg either failed or needs adjusting I suspect.
When is the last time the wheel brgs were removed, cleaned and repacked with grease?..............
Never?
Old 04-05-2015, 08:32 PM   #9
Josh
WHITEGOLDTEETHNOFLOSS
Sounds like a loose wheel bearing.
Instagram: josh_keck
Josh is offline   Reply With Quote
Old 04-05-2015, 08:42 PM   #10
PromiseRing
Banned
Never?
Not since I've owned the car at least. If I go as far as pulling the hearing would it be smarter to just replace it? I can pack the bearing though.
Old 04-05-2015, 09:08 PM   #11
mopar318
mopar318's Avatar
Sounds like the shock is loose inside of the strut tube.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 04-05-2015, 09:23 PM   #12
PromiseRing
Banned
It might also be worth noting that there's a clunk while turning at a dead stop in either direction (play in the steering wheel) but i believe the outer tie rod is to blame for that.
Old 04-05-2015, 10:19 PM   #13
centason
CNT-FAI
centason's Avatar
There may be play in your upper strut area. Just enough to allow play between the shock nut and the upper spring seat. Like your upper strut assembly may be tight, but there is still play. Take the nut off, add a few washers, and then tighten everything back up.
Member: TBCCS
"The kind of man who wants the government to adopt and enforce his ideas is always the kind of man whose ideas are idiotic." -H. L. Mencken
Any forums history.
Old 04-05-2015, 10:31 PM   #14
towerymt
the real Towery
towerymt's Avatar
That's not the gland nut.
What holds the strut insert in the tube is the gland nut.
Old 04-05-2015, 10:58 PM   #15
PromiseRing
Banned
Wait..how do you know what Nut I'm talking about? I popped the cap off the nut (by the rubber strut mounts..?) and tightened that nut. That ones not the gland nut?
Old 04-05-2015, 10:58 PM   #16
centason
CNT-FAI
centason's Avatar
This. If the top nut is still loose on top of your strut mount, that's your issue like I said. There's play there, it's going to clunk going over even a small bump. That split second that shock and spring unloads, clunk.
Old 04-05-2015, 11:00 PM   #17
PromiseRing
Banned
The top one under the cap is the one I ran down with the impact. I thought that was the gland nut.
Old 04-05-2015, 11:05 PM   #18
centason
CNT-FAI
centason's Avatar
No. That nut keeps the whole upper assembly together, and if there is a little play, when the whole spring and shock unload, it will clunk. Try adding a few washer and see if that takes up the play.
Old 04-06-2015, 12:16 AM   #19
PromiseRing
Banned
Add wAsher's under the top nut? Will do. But what's a gland nut?
Old 04-06-2015, 12:37 AM   #20
smokeyfan1000
Guest
If you replace the TWO bearings per frt wheels, you also need to replace the race for each bearing.
Just how much natural mechanical skills do you possess? Because installing the races STRAIGHT in the hubs , with out damaging the races.... may be above your skill level (judging by how you've never done a wheel brg replacement)
Old 04-06-2015, 01:12 AM   #21
PromiseRing
Banned
I don't want to replace anything that I don't KNOW is bad..so I'll see if I can't tighten the gland nut (once I figure out what it is) and shim up the top nut.
I have the skill to replace the bearing, I believe. I'd just need to read up on it.
Old 04-06-2015, 01:39 AM   #22
towerymt
the real Towery
towerymt's Avatar
Because the strut gland nut is not tightened with an impact. Special tool, pipe wrench, channel locks, etc. But not impact.
Old 04-06-2015, 01:47 AM   #23
PromiseRing
Banned
Yeah I finally realized that after I found out what it was.. I will tighten it tomorrow if I get the chance. It needs to be tightened with the vehicles full weight on the ground, correct?
Old 04-06-2015, 07:11 AM   #24
Urvanej
...It needs to be tightened with the vehicles full weight on the ground, correct?
You can get there better but you get higher torque with spring slightly compressed when the strut is not under spring pressure.
Anyway my bet is wheel bearing.
Urvanej is offline   Reply With Quote
Old 04-06-2015, 09:14 AM   #25
cbevis
Just some guy...
cbevis's Avatar
I've lost two...
FEEDBACK
cbevis is offline   Reply With Quote
