I bought them on ebay, I got 2 set for front. One set slotted and one drilledHA! Where'd you find those Svensky Racing/KVR rotors? Svensky went out of business YEARS ago.
Yes. I had them on my V70T5 for years. Replacement discs aren't easy to come by these days. KVR may still have them, but they're stupid expensive. Brembo or others BBK makers may be able to help in that regard. Nice rotors though.I bought them on ebay, I got 2 set for front. One set slotted and one drilled
Have you use this rotors before?
Subscribed
It's from LMR in sweden
http://www.l-m-r.se/p/volvo/240///styrstangsutvaxling-21-kit.html
I think it's just a universal exchanger with 36 x 3/4" in and out, the kit also contains weld on joints.
Almost complete installed
Anyway; they cost me just a little more than stock S60R discs, so I don't care if I don't find new discs for the rotors when that time comeYes. I had them on my V70T5 for years. Replacement discs aren't easy to come by these days. KVR may still have them, but they're stupid expensive. Brembo or others BBK makers may be able to help in that regard. Nice rotors though.
My idea was to weld a thick plate to the side member(is it right word?) for fastning of the exchanger, don't you think it will work?Don't build a Senna steering!!!
This is NOT a good place to mount the 2:1 steering exchange!!!!!
You have to build a bracket to connect the Housing of the 2:1 steering exchange with the body of car. Otherwise it wont work. The torque is amazing, espacially on Track with Toyo 888. Don't do it. You should fix it inside of the car in the steering column. Here is a good place to fix the black housing of the 2:1 too.
Lovely inlet manifold, would like to have a closer look (into).
regards Kay
