940 16 valve
- Oct 22, 2005
- Calgary, Alberta
Hi crew
Trying to get a lh2.4 stepped flywheel machined, and I can't for the life of me find a figure for what the stock step should be. I've searched greenbooks, even called volvo; the service advisor told me they don't list a spec, because Volvo suggests replacing the flywheel when it comes time.
I found 25mm mentioned on one forum post, and mine is currently just a bit less than this. My clutch was slipping however, complicated by the fact that it wasn't milled flat when I had it done recently. Not sure that I want to take it to 25mm based on anecdotal numbers.
Does anyone have a source, or a stepped flywheel that they can measure the step on to give me more data.
Thanks!
Thanks!
