Old 05-31-2004, 07:08 PM   #26
916volvosport
916volvosport's Avatar
Originally Posted by mfpmax
World Class T5s come standard in all Mustangs(and some other T5 equipped vehicles) after 1985. So it won't be hard finding them.
The T5Z is a Ford Motorsports aftermarket transmission.
http://www.5speeds.com/t5/index.html
won't be hard finding after someone already pulls it for you and sells it at a markup seriously though, i have not seen a t5 from a v8 at the nor cal valley pick n pulls.. coincidentally 4 getrag 265s and plenty of getrag 262s (4 speed)..
-patg
my car: 1981 240 turbo
myspace
this is my signature
***You Are a Martini***
There's no other way to say it: you're a total lush.
You hold your liquor well, and you hold a lot of it!
What Mixed Drink Are You?
http://www.blogthings.com/whatmixeddrinkareyouquiz/
this is the end my signature
916volvosport is offline   Reply With Quote
Old 06-01-2004, 12:09 AM   #27
reeferman
broad member
reeferman's Avatar
then i dont know what i have 1352-249 330 ftlbs for 300.00 (lucky junk yard find)
i was going to go gatrag but could not find one .
i called every yard with in 100 miles; no getrags, but they all had T-5s
oregon must have less stuck up graypupon eatin BMW drivers and more mulet blowin in the wind budwiser drinkin MUSTANG drivers.
tony
[IMG][/IMG]
reeferman is offline   Reply With Quote
Old 06-01-2004, 01:03 AM   #28
916volvosport
tony
300 bucks for a tranny? heh.. we got 4 trannies for that much
-patg
Old 06-01-2004, 01:24 AM   #29
reeferman
broad member
reeferman's Avatar
cool you can get four crappy trannys for the cost of a good one.
heh
tony
Old 06-01-2004, 01:24 AM   #30
mfpmax
-patg
Yeah, thats what sucks, our yards pull them as well. A friend on here says they have T5s at the lower Cal yards(I think he's in So Cal).
4 Banger T5s are cheaper...but of course have a "sligthly" lower torque rating and different gearing(possibly less desirible). The input shaft is also not the same metal.
A 2.3, but not a Volvo...
Hesh wants some sex!
mfpmax is offline   Reply With Quote
Old 06-01-2004, 01:37 AM   #31
916volvosport
i see 4 cyl t5's all the time.. what's wrong with pulling them myself? just because i save 200 bucks? wowee
-patg
Old 06-02-2004, 08:22 PM   #32
Sean
Junkyard dawg
Sean's Avatar
heh
tony
Doubtful that even one of those getrag 265's is a crappy tranni. They are known for longevity and durability.
I mean seriously don't argue over what you paid, big F***ing deal, sure you can get a good tranni for almost nothing or you can pay a lot for it, all depends on how the cards fall essentially (I got my getrag just rebuild for -$100 (they paid me $100) and they pulled it for me along with some other parts I wanted.)
Both are good trannys, and obviously the price you pay depends merely on what happens to fall into your lap.
Sean
Sean is offline   Reply With Quote
Old 06-03-2004, 06:48 AM   #33
916volvosport
Sean
heh.. didn't fall on my lap.. i bench pressed that sonamabesh in place
Old 07-24-2004, 01:24 AM   #34
dbarton
Bored Member
dbarton's Avatar
Originally Posted by Turborg
I recently installed a T-5z into my 82 242 ti, using the adapter from v-performance and the clutchnet pp and clutch. I am totally impressed with the improvement over the M-46 that I had in there. This transmission requires a much heavier pressure plate than the M-46 or a regular T-5. The T-5z has a 2.95 low gear vs 4.01? for the M-46, and 3.31? for the T-5. I don't think a lady would enjoy driving this setup without the hydro clutch. The close ratio trans is a blast to drive tho. No holes between the gears and it shifts great.
I also need to mention that a lot of the people who have done the T-5 swap have had a few problems. When I first put mine in, I could not shift into reverse without shutting the car off. This eventually improved as the clutch wore til it shifts fine when cold, and as long as you put it in a forward gear first, it shifts to reverse fine when it is hot. I believe this problem can be attributed to the clutchnet clutch being .335 thick, compressing to .315. The Volvo plate is .315. I think the extra .020 of the clutchnet plate is enough to turn the input shaft of the trans, causing the shifting problems til the clutch wears. The one other problem that I have is a vibration under hard decelleration. Since I drive in the mountains a lot, using the engine as a brake, this is especially annoying to me. The guys running the T-5 do not report this vibration however, so it might be a T-5z thing. If I solve the vibration problem, I would have nothing but rave reviews for the conversion!!
I just switched from a two-piece driveshaft to a one-piece, which is what I think most people have done with the T5 swap. I did this to eliminate driveline vibration issues. This change reduced some of the annoying noises, but the vibration/buzzing is still ever present on decel as mentioned above by Turborg. But that is mild compared to below....
There is now a NEW NOISE, but only in 5th gear... Keep in mind: this is in 5th gear ONLY. It's a jackhammer type vibration which can be heard lightly during cruise, but it gets louder as more load is applied. If I give it any boost in 5th, the whole car vibrates pretty violently and I can't see out of the rear view mirrors. This has me puzzled because it doesn't do this in any other gear, so my conclusion is it's the transmission. And I don't see how there is a malfunction in the trans since it only has about 1000 to 1500 miles on it since new. BTW my trans is the T5Z with .63 overdrive 5th. Anyone else have such a noise?
Dave B.
Old 07-24-2004, 04:02 AM   #35
mfpmax
My car does that when I shift into 5th below "45MPH"...I say that cause I did a swap and probably have the wrong speedo gear.
Old 07-24-2004, 10:17 AM   #36
745T+
745T+'s Avatar
Originally Posted by Two 87s
I just bought a manual 240 turbo wagon to replace the 940 turbo sedan that my wife drives. (I'm happy enough with the AW71 in my 764ti for now, but my wife demands a manual transmission.) Well, the clutch pedal is really stiff and engages really close to the floor. This was tuff240's brown wagon that I bought from jackbombay, and tuff240 had put a Centerforce clutch in it a while back. I'm starting to think that clutch may be on it's last legs. (I've already tried adjusting the clutch cable and can't get any better performance from it.)
As far as I'm concerned, that leaves me with a choice. I can either replace the clutch with a stock Volvo clutch or replace the entire transmission with a T5.
Either way, I'll be doing the work myself. I'm sure I can do either one (I've done all my own engine and suspension work for the last few years). The car currently runs a selectable 8/15 psi of boost on the B21FT. I know there's a danger that the M46 will eventually go.
With replacing all of the parts that could possibily be worn on the stock/CF clutch, I'm looking at around $500. With the T5 swap, I'm looking at more like $1500 plus the cost of the tranny. (That includes an aluminum flywheel from v-performance, an aftermarket shifter, bellhousing adapter, throwout bearing, pilot bearing, slider yoke, a custom driveshaft locally (estimated at a conservative $200), clutch, pressure plate, modified fork, and speedometer adapter.) My estimates may be a little high, but that's good, as far as I'm concerned.
So the question is: which should I do? If I can get all the parts together, it seems like an equal amount of labor to do each one, and the T5 swap has been tested quite a bit now. The T5 is more expensive, of course. Is it safer than the risk of sticking with a M46 that has an unknown number of miles left in it?
I'm leaning towards the T5, obviously, but I'd like to hear some thoughts from you guys. We've still got the 950 turbo sedan to drive while the swap is done, but I need to get the whole thing finished in the next two months, since I'm moving at the end of July.
Thanks,
Aaron
A stiff clutch is a symptom of a worn out clutch, and I've heard that Centerforce clutches have a heavy pedal. In addition, the aftermarket clutch cables give a much higher pedal effort. Check the cltuch cable and make sure it is genuine Volvo.
745T+ is online now   Reply With Quote
Old 07-24-2004, 11:53 AM   #37
Two 87s
Holy thread resurrection!
I've got a T5 and the rest of the parts are on their way from John Parker. But I'm moving in a week, so it will be a little while before the T5 is in.
As far as the stiff clutch on the car now, I've been putting up with it. I think it's a worn-out clutch, honestly. The cable is a new Volvo one, and no amount of adjusting helps.
For a comparison, my mother was down here with her 740 with cable-operated M46 last week. That clutch is insanely easy to push to the floor... it's like a hot knife through butter in comparison to my 245, which is more like pushing your foot through wet concrete. It also engages in the first inch or two of travel.
Anyway, I'll be happy to see the T5 in. Hopefully I'll get it done before classes start in August.
Aaron
Two 87s is offline   Reply With Quote
Old 07-24-2004, 11:57 AM   #38
jackbombay
Supremer superior TBOTer
jackbombay's Avatar
I sold him the car and installed the cable and it is genuine Volvo cable and was priced accordingly. The clutch was as stiff when I sold it was when I bought it (I'm not sure how many times I need to say that, having put the last 50,000 miles on the car I am the most qualified person to say this) The clutch was almost brand new (Less than 10,000 miles) when I bought the car and the pedal always required quite a bit of effort. I did not chose the centerforce clutch, I have been in other Volvos with high pressure plate clutches that required way less pedal effort, I would never buy another centerforce clutch for a volvo or any other car.
-Jack
Originally Posted by Kevin Hawkinson View Post
When brains are outlawed, only outlaws will have brains.
Originally Posted by Vincent Gagnon View Post
He is better than us...remember?
That sir is an easy task.
jackbombay is offline   Reply With Quote
Old 07-24-2004, 11:59 AM   #39
jackbombay
jackbombay's Avatar
If I adjusted the clutch so the engagement point was higher then there was no "slack" at the top of the pedal travel, I'm sure this is what you found out, I like a higher engagement point myself as well...
-JAck
Old 07-24-2004, 12:58 PM   #40
dbarton
Bored Member
dbarton's Avatar
Understandable if you're going only 45. Mine vibrates pretty bad at 45 too in 5th, but the engine is probably turning 1500 rpm. I generally don't even shift into 5th until over 60.
The problem I'm having is that the jackhammer vibration continues noticably to at least 100 mph and then begins to diminish.
Dave B.
Old 07-24-2004, 01:37 PM   #41
916volvosport
not sure where you heard about the centerforces stiffness.. i've used the stage 1 and the dual friction plates.. both plates had oem feel to it.. also there were 2 pressure plates available from volvo for the flat flywheel (8.5").. one was super stiff and heavy.. the other was what the aftermarket ones are based on.. most commonly used.. you're right about the clutch cables.. well.. depends on brand.. i used a beck arnley before.. same pedal feel as stock, but the bushing broken where it goes through the hole at the bell housing..
-patg
Old 07-25-2004, 02:10 AM   #42
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Dave, its probably that super tall 5th. Mine is the .8 and if I get into 5th and try to accelerate below 3500rpm it does the same thing too. Actually, even below 4500. Basicly I only shift into 5th (at WOT) at 120
Old 07-25-2004, 03:16 AM   #43
dbarton
Bored Member
dbarton's Avatar
Thanks, Doug, for confirming I'm not the only one. I can imagine that my poly bushings and the solid torque rods contribute to the harshness. The thing that has me puzzled is I can't see Ford allowing their Mustangs to do anything like that in 5th... anyone know if there is something different in a Mustang driveline that somehow quiets the jackhammer in 5th?
It's bad enough that I may need to have the 5th gear changed to a lower ratio (if something like that is possible).
Dave B.
Old 07-25-2004, 08:20 AM   #44
mfpmax
Mustangs(except my POS, only V8s) did have a "Dogbone" dampner at the rear of the drivetrain around the nose of the rear end...not sure if that was its purpose...but my car doesnt' have this since it was a 4 banger.
