The internal size of the tank to pump hose is 12mm. Be sure you buy fuel rated hose. A meter length piece of hose is good. When you look at the sending unit from the port under the back storage area. You will see the largest hose has a clamp and runs to the pump. The return hose is smaller. Make sure any clamps you buy are the type for fuel injection hose.
Excellent info. Thanks!
I see three fuel hoses, listed from rear to front:
Feed line 1: about an inch or two long. Looks like an end cap style hose.
Feed line 2: Smaller circumference fuel line. Looks like the return hose as described.
Feed line 3: Larger circumference fuel line, closest to the front of the sending unit. This looks like my send hose as described.
I replaced the fuel sending unit and hose clamps coming from the sender last week. Next time I do this job with another brick owner, I'll be sure to inspect that fuel hose from now on.
I've read the following steps to relieve fuel pressure and replace the hose from the Haynes manual prior to performing this job, and I need to confirm this is the correct procedure:
Disconnect fuse 6 on the fuse panel
Start the car and allow the car to stall
Remove key
Remove gas cap and replace
Disconnect negative battery cable
Remove interior floor panel from above sending unit.
Disconnect ground and electrical wiring harness from sending unit.
Remove sending unit access panel
Remove fuel hose and clamp from sending unit first, main pump second.
Replace fuel hose and clamps from main pump first, sending unit second.
Reassemble access panel sending unit wiring harness, and ground wire.
Replace fuse 6
Reconnect negative battery cable
Start car and ensure no leak.
Reassemble interior floor panel.
