- Stock PSI Or Bust -
- Mar 23, 2007
- Ocean Beach S.F.
Don't forget the nasty black axle grease.
Did you knock the cups back against the circlips?
Zerk in cup can supply all the bearings if the crossbone is drilled thru in both directions. Best way to use those is to remove the zerk fitting after greasing and install plug, until next time.Strange usually the zerk fitting is on the 'cross' not the cup so it supplies all the bearings with one fitting.
U joint itself functions flawlessly. Everything there is smooth.
You didn't answer my question.
It?s decent but the vibration only stared after I separated the halves.How good is your center support mount?
Not yet but I?ll keep that in mind. I?d have to separate that one too to replace the center support bearing.So do you need the drive shaft that I got from you. I still have it if you need it. You probably did this but after you install everything tap around the ujoints, it help seat everything and free it up. Should be no tension if the joints are seated.
Check out my Photo of the drive shaft alignment marks I found on my 88 245 m47 car.
