Mr.Borrie
The Sneaky F*ing Ukrainian
- Aug 1, 2006
- Netherlands
Ever since the install of the new turbo and the bondo header i had the same issue as i had a year ago.
Car would not spool up further than 5PSI, and like a year ago at idle after a little drive in front of the lights there is a Growl out of the engine and then sounds more aggressive.
To see if the same thing has happened as before i pushed WR hard from the light and yes there she is again boosting up till close 10's making the back all wiggling and tires burn up from launch.
Its so wierd like the chips needs to be learn every change to the engine or maybe its just the crappy motronic Air valve that starts working, who knows.
