Old 01-15-2007, 12:54 AM   #1
DavoS40
DavoS40's Avatar
Default 242 Build
The project originally started out as a 245 then in 2003 I decided to switch to a 242. I've been working on it off and on when I'm home from school the past couple years. I'm just going to start off with the work that's taken place since springbreak 2005.
Engine:
B21FT
-align honed mains, decked for .030 squish
-2nd oversize stock pistons, balanced
-stock rods resized, cyrotreated, new hardware, balanced
-reground crank, balanced
-bmw oil piston squirters
-meling oil pump
Cylinder Head:
-398 SCP
-port & polished, unshrouded exhaust valves
-40mm exhaust valves, stock intake valves
-K cam
Turbo Setup:
-Holset HY35
-Powerstroke intercooler
-SS header from Jonathan(Stereophile33)
-XS RFL blow off valve
-3 inch exhaust (half of it from Doug's old car!)
Suspension/Brakes:
-front coilovers 315 lb springs
-rear coilovers 250lb springs
-revalved/shortened Bilsteins (towery's specs)
-Kaphlenke camber plates
-IPD adjustable torque rods
-adjustable panhard rod (homemade)
-poly bushings from Dale (245gti)
-new rotors, calipers, pads, ss lines, master cylinder, junction block
Driveline:
-93 Cobra T5 tranny
-Pro5.0 short shifter
-custom Spec stage 2+ clutch/pp (Volvo pp and clutch with the T5 spline)
-3 inch aluminum driveshaft
Fuel/Ignition:
-MS'nS
-EDIS with Ford coil pack
-Ford CFI injector's
-walbro pump
B21 block fresh from the machine shop
Notice the spots machined for the squirters
Sprayed the garage down with a hose to keep the dust down
Test fitting the squirters
rods, pistons, oil pump installed
finished short block
the light! (40mm exhaust valve)
seam welding
painted bay
preparing to drop in the motor
ready to go in
motor in, test fitting header with junk head
body still needs a lot of work
engine bay
The new motor has been run through 3 sessions of stealth's run in procedure. When I was almost finished with the 3rd session I blew a freeze plug. I wasn't sure if this was due to the coolant system getting pressurized from a slight leak in the headgasket or if the machine shop installed the freeze plugs incorrectly. The blown freeze plug was replaced with one of the rubber expandable plugs and the head gasket replaced. If another one blows the motor is coming out and all of the plugs are going to be replaced(JB will be involved). The motor did sound great and sounded really smooth after the 2nd session.
I'm heading back to Colorado tomorrow, so I won't see the car for a few months. The plan is to get a bunch of little parts needed while I'm away. Hopefully get the car painted over springbreak or the beginning of summer. Once the body is painted the 93 block cloth interior(that's sitting in the basement) is going in the car. Then a few test drives (I smell Missouri) and if all goes well it'll get registered.
1983 245DL, 2011 WRX, 1978 SR500
DavoS40 is online now   Reply With Quote
Old 01-15-2007, 01:01 AM   #2
Delfosse
VFL
OMG I wet myself!.. that is killer! good lighting on the engine bay pic's!
Delfosse is offline   Reply With Quote
Old 01-15-2007, 01:03 AM   #3
Nick
Nick's Avatar
Gorgeous car! Very nice work!
-Nick
S30 & E30
No mas Volvo.
Nick is offline   Reply With Quote
Old 01-15-2007, 01:06 AM   #4
Tom Wiley
DOnt do anything to the outside!
SLEEPA POWA!
EDIT: I spy Eikers! What rubber are you gonna put on them?
Tom Wiley is offline   Reply With Quote
Old 01-15-2007, 01:25 AM   #5
SLEEPA POWA!
Those aren't crappy eikers, they are the real things.
BTW, way to go davo!
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 01-15-2007, 01:56 AM   #6
DavoS40
DavoS40's Avatar
Thanks for all the complements guys!
SLEEPA POWA!
Originally that's the attitude the project took on, screw all the looks and just make it fast. Now I'm going for just a great all around car: handles great, plenty of power, nice interior, clean factory looks on the outside but nothing that says look at me.
Old 01-15-2007, 02:06 AM   #7
edicius
Super Moose!
edicius's Avatar
Just a thought, some after-market water pumps if not shaped like the oem blade can cause freeze plugs to pop. Not sure what it has on it but just in case you didn't know
2006 Subaru Sti
edicius is offline   Reply With Quote
Old 01-15-2007, 02:15 AM   #8
DavoS40
DavoS40's Avatar
I read the stories about the stamped impellers and made sure to get the one with cast impeller.
Old 01-15-2007, 09:31 AM   #9
740ATL
Guest
I love everywhere this project is going. Well done.
Old 01-15-2007, 10:09 AM   #10
VQ
Not such a PRVert Anymore
VQ's Avatar
Amazing, the work put into that is huge!
VQ is offline   Reply With Quote
Old 01-15-2007, 10:16 AM   #11
suterman
suterman's Avatar
Now THATS what I'm talking about!
1985 Bedford cf. B230e aw71L
1990 240 turbo. b230ft m47 chips
suterman is offline   Reply With Quote
Old 01-15-2007, 12:31 PM   #12
oldschoolvolvo
oldschoolvolvo's Avatar
very nice work!
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 01-23-2007, 12:56 AM   #13
Homer
OEMplus++
Homer's Avatar
Very nice Dave. I've seen the car in person and "helped" a bit. I like where it is going and can't wait to ride around in it. This project is being done like it should, on a budget nonetheless.
The lighting is very high tech too!
-Jacob:
2006 A4 - Comfy DD
Need something TIG welded? Give me a shout.
Old 01-23-2007, 01:02 AM   #14
str8krewzn
str8krewzn's Avatar
What did you do for a WG?
str8krewzn is offline   Reply With Quote
Old 01-23-2007, 01:09 AM   #15
oxity
oxity's Avatar
awesome awesome, yah im curious about the wastegate and manifold myself
oxity is offline   Reply With Quote
Old 01-23-2007, 01:15 AM   #16
stylngle2003
stylngle2003's Avatar
i see an internal flapper on the back of the turbo
-Billy
Volvoless for the first time since 1990...
2002 Toyota Avalon XLS (comfy gradma car)
1996 Chevrolet Tahoe LS 2WD (hauls ass)
1990 Mazda Miata (track toy)
stylngle2003 is offline   Reply With Quote
Old 01-23-2007, 01:18 AM   #17
impulse922
this project has been in the dark, this the first time you've posted anything on it?
-Matt
'90 780 and '03 s60 T5M
impulse922 is offline   Reply With Quote
Old 01-23-2007, 03:57 AM   #18
DavoS40
DavoS40's Avatar
Without the parts hook up and the motivation to do it clean it wouldn't be where it is now man!
I've made a few threads about it in the past, but not since last summer when I totally tore it down.
Two summers ago I ran the stock wastegate and it held a consistent 19psi(which it was I think the original actuator opens up at). Now I ported the hell out of the wastegate, and I'm planning on fabricating something similiar to atp's ultimate wastegate over springbreak with an internal wastegate I can get different springs for. Eventually I'll get a the header setup for twin wastegates with a nice twin scroll turbo.
Last edited by DavoS40; 01-23-2007 at 11:18 AM.. Reason: grammer, i was tanked when i originally wrote this
Old 01-23-2007, 01:46 PM   #19
homer1300
homer1300's Avatar
is that block orange? or is that just a bad digital camera?
1983 244 Turbo
1995 944 Turbo
homer1300 is offline   Reply With Quote
Old 01-23-2007, 01:58 PM   #20
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
You and Lee really make me miss 240's (and REALLY hate living in smog states)
amazing job man!
Old 01-23-2007, 05:50 PM   #21
Blackbrick
Grandpa
Another beautiful 242 in the making. kudos man.
Doug, life will get a lot easier when you get out of Cali.
Blackbrick is offline   Reply With Quote
Old 01-23-2007, 06:06 PM   #22
Hank Scorpio
Not sure I am now :*( /thread jack
Old 01-23-2007, 06:21 PM   #23
Chrisco
WRC addict
Chrisco's Avatar
that engine bay looks godly
MODS: Bilstein HDs, Lesjöfors springs, sways, poly bushings, 2.5" exhaust, header, short throw shifter, Recaros, MS
and a V70R
1981-1982 Euro style 242, with GLT trim, rules over all other 240's.
All other 240's quake in fear at the '81-'82 242GLT, they go weak at the knees & collapse due to an uncontrollable adulation that's near idolatry.
Chrisco is offline   Reply With Quote
Old 01-23-2007, 06:26 PM   #24
DavoS40
DavoS40's Avatar
It's chevy red-orange it turned out more orange than I wanted though.
amazing job man!
Thanks dude, it was your old project that really got me motivated to take it this far!
Thanks, when are we going to get some updates on your 242?
Old 01-23-2007, 07:18 PM   #25
Big Lan
Face in the carpet
Big Lan's Avatar
Your engine gives me big wood.
He's turned it into a 120 wagon
Start new thread now! Must hear details! Can't wait month to talk! Unless you're still going to hooters...
03 GMC Sonoma | 95 Miata | 90 Miata | 88 Tbird Sport | 83 245ti | 71 Grand Prix | 67 122s
"At every light it's automatic - burn rubber!" - E-40
Originally Posted by Crazychopstick View Post
Extreme! It's no coincidence that Lan rhymes with Man.
Live for today, because tomorrow's ****ed.
Big Lan is offline   Reply With Quote
