Old 06-14-2019, 09:20 AM   #1
apico500
apico500's Avatar
Default Tomahawk replacement 142
I bought from VP new window lift rail channels and rubber strips to replace the rusty ones in my 142. Removed old ones but the new ones fit very loosely and wont hold the window. Is there something else I need to do? Or is the rubber strip too thin?
Volvo 1980 GT Project SOLD
http://forums.turbobricks.com/showth...12#post3961912
apico500 is offline   Reply With Quote
Old 06-14-2019, 10:22 AM   #2
Do you mean the window lift rail channel?
Old 06-14-2019, 10:26 AM   #3
apico500
apico500's Avatar
Yes
Old 06-14-2019, 10:29 AM   #4
You need thicker rubber.
Old 06-14-2019, 10:54 AM   #5
apico500
apico500's Avatar
That is what I got from VP. Any suggestions where to get thicker rubber?
Old 06-14-2019, 11:05 AM   #6
EDPM pond liner, thorn proof bicycle inner tube or double up what you have with a strip of standard inner tube.
Most bike shops will give you popped tubes to play with / use.
Old 06-14-2019, 11:19 AM   #7
apico500
apico500's Avatar
Ok Ill try that. Thank you. Have you ever encountered this problem before?
Old 06-14-2019, 11:42 AM   #8
planetman
planetman's Avatar
For some reason, Volvo used 2 different thicknesses of glass so there are 2 different thicknesses of rubber strips.
VP's website only lists the thinner rubber on the 1 page I checked. The thinner rubber is more common.
VP has the correct thickness rubber strips using part# 1268231.
Eric
Torrance, CA 90502
Old 06-14-2019, 05:06 PM   #9
Yes we wound up squeezing the lift rail channel closed a little in the vise and using single thickness pond liner on a 68 142 passenger side window.
Old 06-14-2019, 10:33 PM   #10
planetman
planetman's Avatar
Don't forgot the spit and bailing wire.
Old 06-14-2019, 10:37 PM   #11
Old 06-15-2019, 12:07 AM   #12
planetman
planetman's Avatar
All braided steel fuel hose with AN fittings, Holley fuel pressure regulator, Custom cable operated throttle linkage with billet arms and throttle shaft mounted return spring and IIRC, we also added a hard to see PCV system using stainless steel tubing with a tap into the under side of each intake runner with the tubing running behind the cylinder head to the breather box.
Old 06-18-2019, 03:52 AM   #13
apico500
apico500's Avatar
According to VP and the Volvo parts manual the correct part is # 96343 544/210/122/140.
Getting confusing. They have part # 1268231 140/164/2/7/900. (maybe its the same gauge rubber?)
VP agreed to send correct one at no cost since it was their mistake.
